Home » Archived » M2M (model-to-model transformation) » [ATL] UseCase 2 HighLevel rules
[ATL] UseCase 2 HighLevel rules [message #47336] Mon, 18 June 2007 07:53 Go to next message
Originally posted by: hein..fokus.fraunhofer
Hi all,
I've a problem in formulating the right ATL rules. My source model is an
UML model that contains UseCases, Actors as well as Associations between
them. My target model is also an UML based model that should contains
the same usecases, actors and associations and furthermore classes which
are derived from the usecase, actors and associations information. The
classes should be created in a new package named "ClassPackage".
The transformation of the several entities isn't very difficult
rule Actor{
from a1:UML2!Actor
to a2:UML2!Actor(
name<-a1.name,
general<-a1.general
c1:UML2!Class(
name<-a1.name,
general<-if a1.general->size()>0 then
UML2!Class.allInstances()->select(x|x.name=a1.general->first().name)
else Set{} endif
or...
rule UseCase{
from u1:UML2!UseCase
to u2:UML2!UseCase(
name<-u1.name,
--owner<-u1.owner,
include<-u1.include
c1:UML2!Class (
name<-u1.name,
useCase<-u1,
nestedClassifier<- if u1.include->size()>0 then
UML2!Class.allInstances()->select(c |
u1.include->collect(i|i.addition.name)->includes(c.name) )
else Set{} endif
However, my problem are the creation of the associations. I need to
create two associations that have different association ends in each
cases. Here is my initial rule for association
rule Asscociation{
from a1:UML2!Association
to a2:UML2!Association(
name<-a1.name,
memberEnd<-a1.memberEnd,
ownedEnd<-a1.ownedEnd
a3:UML2!Association(
name<-a1.name+'source_target',
a2 should be a simple copy of a1 (Actor<->UseCase), but a3 should be a
new association between the generated Classes in the target model from
an Actor and an UseCase. How to specify the right OwnedEnd member for
the association a3 with ATL.
Thanks in advance for any help
Christian
Re: [ATL] UseCase 2 HighLevel rules [message #47373 is a reply to message #47336] Mon, 18 June 2007 09:44 Go to previous messageGo to next message
general spoken you need thisModule.resolveTemp(..) for that purpose
(see user manual, pp. 38-40).
Maybe like this:
rule Asscociation{
name<-a1.name,
-- ownedEnd<-a1.ownedEnd
do { -- this do part is new
a3.ownedEnd <- thisModule.resolveTemp(a1.ownedEnd, 'c1');
a3.memberEnd <- thisModule.resolveTemp(a1.memberEnd, 'c2');
assumed I've understood your transformation...
Jens
Re: [ATL] UseCase 2 HighLevel rules [message #47402 is a reply to message #47373] Mon, 18 June 2007 09:45 Go to previous message
Sorry, typo:
a3.memberEnd <- thisModule.resolveTemp(a1.memberEnd, 'c1');
Jens
Previous Topic:[ATL] Sequence as a source pattern ?
Next Topic:[ATL] Problem with inter-model references
Current Time: Wed Nov 05 18:18:11 EST 2025
Powered by FUDForum. Page generated in 0.04082 seconds
