Home » Eclipse Projects » Remote Application Platform (RAP) » Updating a View in an other Session
Updating a View in an other Session [message #47333] Mon, 17 September 2007 05:08 Go to next message
I've implemented an logview for my RAP-App. It works with an static
LogCache that stores any entry an notifys all registered Logviews when
an entry is added.
My Problem is, that when I have two sessions running, that both have the
Log View visible, only the LogView will be refreshed that is in the same
Session, the LogView in the other Session will show the change only when
an Entry is logged in that session. I've verifyed that the
view.refresh() is called anytime on all open views, but that has no
effect on views in other sessions.
Is it possible to refresh an view in an other session?
thx
Lars
Re: Updating a View in an other Session [message #47491 is a reply to message #47333] Tue, 18 September 2007 03:04 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
I would think activation of the UICallBack mechanism may do the trick.
Insert the following line into the IEntryPoint#createUI() implementation:
UICallBack.activate( getClass().getName() );
If you update your views via Display#asyncExcec(Runnable) all sessions
should be refreshed. Note currently we are doing some work on those
mechanims, so there is temporarily some unexpected behaviour possible. But
the work should be finished by the end of the week.
Hope that helps!
Ciao
Frank
"Lars Gehrken" <gehrken@orbital-computer.de> schrieb im Newsbeitrag
news:fcme8l$4nq$1@build.eclipse.org...
> an entry is added.
> thx
> Lars
Re: Updating a View in an other Session [message #47825 is a reply to message #47491] Wed, 19 September 2007 04:21 Go to previous messageGo to next message
Hi Frank,
does this mean, that everytime I use the UICallBack mechanisms to trigger ui
refreshes, all sessions are notfified?
Do I have to specifiy a application-wide unique id as parameter in the
activate() call to make this work?
Stefan.
"Frank Appel" <fappel@innoopract.com> schrieb im Newsbeitrag
news:fcnt9i$d0h$1@build.eclipse.org...
> Hope that helps!
> Ciao
> Frank
>> an entry is added.
>> thx
>> Lars
Re: Updating a View in an other Session [message #48928 is a reply to message #47491] Sat, 22 September 2007 05:59 Go to previous messageGo to next message
Hi Frank,
I have a similar UseCase. I want to refresh a JFace tree view in all
user sessions. I'm not sure where exactly I should add the UICallback.
The API states that each UICallback.activate() needs a
UICallback.deactivate(). Where to put this when the activate() call is
in the createUI?
I first thought about putting the callback calls into the create and
dispose methods of my View where the tree viewer is in, but that would
create a dependency to RAP for my view which could not be used in RCP
then anymore.
Can you give a some hints on how to use the UICallbacks?
Markus Wolf
> emedia-solutions wolf web: http://www.emedia-solutions-wolf.de
> Eimsbüttler Straße 115 mail: markus@emedia-solutions-wolf.de
> 22769 Hamburg pgp: http://wwwkeys.de.pgp.net
> +49 40 432 635 83 taxid: 57 / 126 / 16123
Re: Updating a View in an other Session [message #62626 is a reply to message #48928] Fri, 23 November 2007 11:47 Go to previous messageGo to next message
Originally posted by: benedikt.arnold.beyondsoft.de
Hi!
I've exactly the same problem. Is there any solution?
Thanks!
Greetings,
Ben
"Markus Wolf" <markus@emedia-solutions-wolf.de> schrieb im Newsbeitrag
news:fd2p2f$gvf$1@build.eclipse.org...
> Hi Frank,
>> But
> in the createUI?
> then anymore.
> Thanks
> Markus Wolf
>> Eimsb
Re: Updating a View in an other Session [message #62650 is a reply to message #62626] Fri, 23 November 2007 12:25 Go to previous messageGo to next message
I have implemented this in the demo application - unfortunately the
UICallBack is deactivated at the moment in the online version, but each
changes of the datamodel are propagated to all sessions and visible as soon
as a user triggers a serverside turnaround. To activate the viewer updates
without user interaction the UICallBack#activate(String) must be called
right from the start. That's how it's done in the demo:
public class RMS implements IEntryPoint {
static {
EntityAdapter.editorInputRegistry = new EditorInputRegistry();
public Display createUI() {
Activator.getDefault().initializeImageRegistry(
"org.eclipse.rap.rms.ui" );
UICallBack.activate( RMS.class.getName() );
Display result = PlatformUI.createDisplay();
RMSWorkbenchAdvisor workbenchAdvisor = new RMSWorkbenchAdvisor();
PlatformUI.createAndRunWorkbench( result, workbenchAdvisor );
return result;
In the demo the underlying data model fires model events to inform observers
about such changes and I use the content providers of each 'Navigator' tree
viewer to listen to such events. To avoid invalid thread access problems use
Display#asyncExec(Runnable).
viewer.getControl().getDisplay().asyncExec( new Runnable() {
public void run() {
// do actual viewer refresh
Hope that helps.
Ciao
Frank
"Benedikt Arnold" <benedikt.arnold@beyondsoft.de> schrieb im Newsbeitrag
news:fi706u$kpg$1@build.eclipse.org...
> Hi!
> Thanks!
> Greetings,
> Ben
>> Hi Frank,
>>> implementation:
>>> But
>> in the createUI?
>> then anymore.
>> Thanks
>> Markus Wolf
>>> Eimsb
Re: Updating a View in an other Session [message #62838 is a reply to message #62650] Sun, 25 November 2007 09:28 Go to previous messageGo to next message
Hi!
I've implemented it the same way but the problem is, that if I call
UICallback#activate it is not possible anymore to close the equinox
framework. I hope the problem will be solved if I call the
UICallback#deactivate. But where should I do this? I think all
UICallback-methods must be called from within the UI thread.
Greetings,
Ben
Re: Updating a View in an other Session [message #63901 is a reply to message #62838] Mon, 03 December 2007 08:30 Go to previous messageGo to next message
you are right, but this seems to be a bug within the UICallBack mechanism.
It seems that the callback thread isn't release at the end of a session.
This is one of my tasks for this week and hopefully there will be a solution
with the service release available on friday...
Ciao
Frank
news:4c9175f1b3e2c6624a44a70d73a73689$1@www.eclipse.org...
> Hi!
> Greetings,
> Ben
Re: Updating a View in an other Session [message #67144 is a reply to message #63901] Thu, 20 December 2007 05:16 Go to previous messageGo to next message
Hi Frank,
is there any progress on this issue or is there a bugzilla entry regarding
this issue? It seems that the service release did not include a solution.
Right?
Greetings and "Frohe Weihnachten",
Ben
news:fj10dl$jtr$1@build.eclipse.org...
> solution with the service release available on friday...
> Ciao
> Frank
>> Hi!
>> Greetings,
>> Ben
Re: Updating a View in an other Session [message #69387 is a reply to message #67144] Wed, 09 January 2008 11:37 Go to previous message
unfortunately I catched a bad cold before the service release, so I didn't
have that time to check out this problem thoroughly. I did some improvements
of the callback thread stuff - but obviously not enough. My schedule will
bring me back to this problem at the end of this /beginning of next week.
Ciao
Frank
news:fkdfdk$clm$1@build.eclipse.org...
> Hi Frank,
> Right?
> Ben
>> mechanism. It seems that the callback thread isn't release at the end of
>> a session. This is one of my tasks for this week and hopefully there will
>> be a solution with the service release available on friday...
>> Ciao
>> Frank
>>> Hi!
>>> Greetings,
>>> Ben
Previous Topic:JSP page communicating with a RAP application
Next Topic:Session Issues
Current Time: Sat Oct 25 06:50:02 EDT 2025
Powered by FUDForum. Page generated in 0.07585 seconds
