Home » Eclipse Projects » Mylyn » BugzillaTask to RepositoryTaskData? (Tutorial outdated)
BugzillaTask to RepositoryTaskData? (Tutorial outdated) [message #47334] Fri, 18 April 2008 12:48 Go to next message
Originally posted by: Michail.Greshishchev.klocwork.com
The Mylyn wiki for headless use has the following example:
// Post modified report to repository
connector.getTaskDataHandler().postTaskData(repository,
task.getTaskData());
connector is a BugzillaConnector class.
task is a BugzillaTask class.
However, in the latest version of Mylyn task no longer has the
getTaskdata() method.
My question is, how do I convert a BugzillaTask into RepositoryTaskData so
I can send it to a Bugzilla bug tracking database via postTaskData()?
Thank you
Re: BugzillaTask to RepositoryTaskData? (Tutorial outdated) [message #47471 is a reply to message #47334] Thu, 24 April 2008 12:23 Go to previous message
Originally posted by: rob.elves.eclipse.org
If you've already synced the task, you can get the task data for it from
the TaskDataManager.
TasksUiPlugin.getTaskDataManager().getNewTaskData(String repositoryUrl,
String id);
Then modifiy the task data as you see fit then submit it via postTaskData().
If this doesn't clear things up, please let me know and I can elaborate.
-Rob
Michail Greshishchev wrote:
> Hello,
> so I can send it to a Bugzilla bug tracking database via postTaskData()?
> Thank you
Re: BugzillaTask to RepositoryTaskData? (Tutorial outdated) [message #589201 is a reply to message #47334] Thu, 24 April 2008 12:23 Go to previous message
String id);
-Rob
> Hello,
> Thank you
Previous Topic:General overview of Task history?
Next Topic:Is it possible to report a bug from the Problems view?
Current Time: Tue Jul 08 21:00:57 EDT 2025
Powered by FUDForum. Page generated in 0.03927 seconds
