Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Live mode constraint not working correctly
Live mode constraint not working correctly [message #47330] Tue, 29 August 2006 03:12 Go to next message
I have two questions:
1)AFAIU, the difference between constraints under Node/Link Mapping
element and constraints in Audit Container is that the former controls
whether a node/link can be created, and the latter checks whether the
existing model is semantically correct?
2)I created a simple constraint(checks whether name's length is greater
than 2) in Audit Container, it works fine in batch mode, but when I
switched it to live mode, there seems to be some problem. For example, I
can get warning decorator when I enter name in properties view, but can
not get it by direct editing. I wonder that in live mode, for which
situations would the constraint be checked?
Re: Live mode constraint not working correctly(Sorry, wrong place) [message #47405 is a reply to message #47330] Tue, 29 August 2006 03:23 Go to previous message
Sorry, I just realized that I mistakenly posted this in emft newsgroup,
pls remove it if this is possible...
Zhang Hao
Re: Live mode constraint not working correctly(Sorry, wrong place) [message #586681 is a reply to message #47330] Tue, 29 August 2006 03:23 Go to previous message
Zhang Hao
Previous Topic:Live mode constraint not working correctly
Next Topic:OCL and MetaModels
Current Time: Fri Nov 07 14:12:08 EST 2025
Powered by FUDForum. Page generated in 0.03223 seconds
