Home » Newcomers » Newcomers » button.setEnabled(false) - how to control the button image?
button.setEnabled(false) - how to control the button image? [message #47317] Tue, 05 April 2005 04:35 Go to next message
Originally posted by: patrick.kaegi.netcetera.ch
Hi everybody
i've a problem with the image set on the button. if i setEnabled(false) on
the button, the button
lost the image and makes a dark-grey 16x16 square on the button.
does anybody know how to control that - or is the something like a bug? ;-)
thanks in advance
patrick
Re: button.setEnabled(false) - how to control the button image? [message #47895 is a reply to message #47317] Wed, 06 April 2005 06:49 Go to previous messageGo to next message
Originally posted by: arstrube.web.de
i'm no expert on this but couldn't it be that the button takes another image
when disabled? Then you would need to supply that image as well.
Arnd
"Patrick Kaegi" <patrick.kaegi@netcetera.ch> wrote in message
news:e91ee57a0da49c66d312ce0073015009$1@www.eclipse.org...
> Hi everybody
> thanks in advance
> patrick
Re: button.setEnabled(false) - how to control the button image? [message #48014 is a reply to message #47895] Wed, 06 April 2005 08:19 Go to previous messageGo to next message
Actually, only toolbar buttons get different images for the disabled and the
'hot' state. With ordinary buttons, the behavior you noticed seems to be
intended. A workaround in your case would be to make a toolbar and use a
ToolItem instead of a button, with all 3 images supplied.
Arnd
"Arnd" <arstrube@web.de> wrote in message
news:d30f7g$4ni$1@news.eclipse.org...
> Arnd
> > Hi everybody
on
> > thanks in advance
> > patrick
Re: button.setEnabled(false) - how to control the button image? [message #52314 is a reply to message #48014] Fri, 15 April 2005 05:39 Go to previous message
thanks a lot for your answer arnd!
hope this would be possible in further versions!
greetz
patrick
Previous Topic:how to dynamically change the layout by pressing a button
Next Topic:Problems with new eclipse installation
Current Time: Tue Nov 18 12:38:57 EST 2025
Powered by FUDForum. Page generated in 0.11081 seconds
