Home » Newcomers » Newcomers » how to dynamically change the layout by pressing a button
how to dynamically change the layout by pressing a button [message #47288] Tue, 05 April 2005 03:50 Go to next message
Originally posted by: patrick.kaegi.netcetera.ch
Hello
We like to design a search-mask with some operators (on a toggle button).
If the selected operator is one like <> or >< we like to have 2 text's
instead of only 1 text in case of = or < or >.
does anybody know if this is possible and how?
thanks a lot for any hint
patrick
Re: how to dynamically change the layout by pressing a button [message #47775 is a reply to message #47288] Wed, 06 April 2005 03:42 Go to previous messageGo to next message
Originally posted by: user.server.net
Patrick,
I am not exactly sure, of what you are trying to design. Is it, that the
user has to select (via e.g. Combobox) the operator and then either one
or two text boxes should appear? In this case I would catch the change
event of the Combobox with an eventlistener and evaluate the user input
to decide if one or two boxes should appear.
Again I am absolutely not sure, if this is what you are looking for. you
can find an easy example under
http://java.sun.com/docs/books/tutorial/uiswing/learn/exampl e5.html (I
know it is swing, but is does the job).
hope this helps,
Kai
Patrick Kaegi wrote:
> Hello
> patrick
Re: how to dynamically change the layout by pressing a button [message #52289 is a reply to message #47775] Fri, 15 April 2005 05:37 Go to previous message
Hi Kai and thanks for you tip.
now i have a working solution. the way is to use GridLayout with the
exclude parameter and the horizontal span
so i have 2 text's text1 and text2 - if i click on the button i set
text2's GridData.exclude to true and the text1's GridData.horizontalspan =
2. and also text2.setVisible(false).
if i click the button the second time i do the "turned around"
hope this help others!
greetz and thanks
patrick
Previous Topic:web services / loginhandler service
Next Topic:button.setEnabled(false) - how to control the button image?
Current Time: Sat Nov 15 09:45:38 EST 2025
Powered by FUDForum. Page generated in 0.07416 seconds
