Home » Language IDEs » AspectJ » AJDT and Plugin Development
AJDT and Plugin Development [message #47267] Tue, 01 February 2005 12:09 Go to next message
Originally posted by: sinleeh.nowhere.com
Dear All,
As a newbie, I have problem using AspectJ (via AJDT) and Plugin
Development together.
My current problem is while trying to use JUnit Plugin Test on a AJDT
project, I got the following error message. I used the default AJDT
setting throughout. Any help appreciated. Thanks. --Sinleeh
!SESSION Feb 01, 2005 16:59:22.676
eclipse.buildId=unknown
java.version=1.4.2_05
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Command-line arguments: -version 3 -application
org.eclipse.pde.junit.runtime.coretestapplication -port 50435
-testpluginname AJDT Test -classnames HelloWorld
!ENTRY org.eclipse.osgi Feb 01, 2005 16:59:22.677
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/aspectj/lang/Signature
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:1655)
at java.lang.Class.getMethod0(Class.java:1901)
at java.lang.Class.getMethod(Class.java:984)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.getTe st(RemoteTestRunner.java:357)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:398)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:305)
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:30)
org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestApplication.java:26)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Re: AJDT and Plugin Development [message #47318 is a reply to message #47267] Tue, 01 February 2005 12:23 Go to previous message
Dear All,
Please ignore this email. I found out the problem. It was because the
plugin.xml was not configure properly. It is missing the runtime XML tag.
I did a "convert to plugin project" and forgotten to check the plugin.xml
file.
Thanks and sorry for the inconvenience caused.
Sinleeh
Re: AJDT and Plugin Development [message #586381 is a reply to message #47267] Tue, 01 February 2005 12:23 Go to previous message
Dear All,
file.
Sinleeh
Previous Topic:Open Editor for IProgramElement
Next Topic:ajdt_1.2.0M2 content assist does not work
Current Time: Thu Jul 17 22:05:21 EDT 2025
Powered by FUDForum. Page generated in 0.05389 seconds
