Home » Archived » M2M (model-to-model transformation) » [ATL] Problems with a lazy rule
| [ATL] Problems with a lazy rule [message #47169] |
Mon, 18 June 2007 04:41  |
Originally posted by: erik_becker.gmx.de
Hi all,
I'm looking for a way to control when the particular source model
elements are transformed by a declarative rule, because during the
transformation some information is needed, which is produced while the
transformation / execution of another matched rule.
To solve my problem I tried to use a lazy rule, but if I change my
normal matched rule to a lazy rule by adding the keyword 'lazy' (in
front) I get some errors from the compiler.
Unfortunately I did not found much information an how to use lazy rules.
I searched in the Manual version 0.7 and the wiki, but there a only
spare infomation on that.
Can any one help?
Greetings
Erik
P.S.:
Here's my lazy rule:
lazy rule ObjOcc2RoutingXOR {
from
element : XML!Element(
element.representsRouting()
using {
activityGUID : String = element.getObjectGUID();
activityName : String = element.getObjectName();
activityAttributes : Map(String, String) = Map{
('Id', element.getNumericId().toString()),
('Name', activityName)
linkedObjects : Sequence(XML!Element) = element.getLinkedObjects();
to
activity : XML!Element(
name <- 'Activity',
children <- OrderedSet{
thisModule.createExtendedAttribute('GUID', activityGUID),
thisModule.createAttributes(activityAttributes),
route,
priority,
documentation,
transitionRestrictions
route : XML!Element(
name <- 'Route'
priority : XML!Element(
name <- 'Priority'
documentation : XML!Element(
name <- 'Documentation'
transitionRestrictions : XML!Element(
name <- 'TransitionRestrictions',
children <- transitionRestriction
transitionRestriction : XML!Element(
name <- 'TransitionRestriction',
children <- OrderedSet{join, split}
join : XML!Element(
name <- 'Join',
children <- joinTypeAttribute
split : XML!Element(
name <- 'Split',
splitTypeAttribute,
transitionRefs
joinTypeAttribute : XML!Attribute(
name <- 'Type',
value <- 'TODO:SetType'
splitTypeAttribute : XML!Attribute(
name <- 'Type',
transitionRefs : XML!Element(
name <- 'TransitionRefs',
children <- transitionRef
transitionRef : distinct XML!Element foreach(object in linkedObjects)(
name <- 'TransitionRef',
children <- transitionRefIdAttribute
transitionRefIdAttribute : distinct XML!Attribute foreach(object in
linkedObjects)(
name <- 'Id',
value <-
if object.isInbetweenEvent()then
thisModule.MappingTransition2Id.debug('Mapping')->get(
Tuple{
src = activity.getAttrVal('Id').toInteger(),
tgt= thisModule.ObjOccsMap->get(
object.getElemsByName('CxnOcc')->first().getAttrVal('ToObjOcc.IdRef')
).getNumericId()
).toString().debug('TransRefId')
else
thisModule.MappingTransition2Id->get(
Tuple{
tgt= object.getNumericId()
endif
And this are the error messages I get:
Warning, could not find mathing node for ForEachOutPatternElement in
mode applyLazyCreate
ERROR: no slot reserved for variable: transitionRef used at 525:37-525:50.
****** BEGIN Stack Trace
exception:
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor28.invoke(Unknown Source)
org.atl.engine.vm.InstanceNativeOperation.exec(InstanceNativ eOperation.java:69)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 60)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 50)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:21 4)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:155)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:30 9)
at org.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:276)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:1 36)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:9 4)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:6 8)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:6 0)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:5 6)
at org.atl.eclipse.engine.Atl2004Compiler.compile(Atl2004Compil er.java:116)
at org.atl.eclipse.engine.AtlCompiler.compile(AtlCompiler.java: 75)
org.atl.eclipse.adt.builder.AtlBuildVisitor.visit(AtlBuildVi sitor.java:71)
at org.eclipse.core.internal.resources.Resource$2.visit(Resourc e.java:105)
org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:57)
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:81)
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:85)
org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:126)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:67)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:103)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:87)
at org.atl.eclipse.adt.builder.AtlBuilder.fullBuild(AtlBuilder. java:43)
at org.atl.eclipse.adt.builder.AtlBuilder$1.run(AtlBuilder.java :32)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at org.atl.eclipse.adt.builder.AtlBuilder.run(AtlBuilder.java:5 3)
at org.atl.eclipse.adt.builder.AtlBuilder.build(AtlBuilder.java :35)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:603)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:167)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:230)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:233)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:252)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:285)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:145)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:208)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Caused by: java.lang.NullPointerException
org.atl.engine.vm.ASMOperation.addVariableInstruction(ASMOpe ration.java:96)
at org.atl.engine.vm.ASMEmitter.emit(ASMEmitter.java:115)
... 185 more
A.main(1 : S, 2 : S) : ??#40 null
local variables = {debug='false', self=ATL To ASM Compiler : ASMModule,
WriteTo='D:/Programme/EclipseForATL/eclipse/workspace/AML2XP DL/Transformations/aml_xml2xpdl_xml.asm'}
local stack = []
A.compile(1 : J) : ??#3 null
local variables = {self=ATL To ASM Compiler : ASMModule,
root=temp!aml_xml2xpdl_xml}
local stack = []
A.apply(1 : J, 2 : S) : ??#6 null
local variables = {mode='', self=ATL To ASM Compiler : ASMModule,
me=temp!aml_xml2xpdl_xml}
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#41 null
local variables = {mode='', me=temp!aml_xml2xpdl_xml, self=ATL To ASM
Compiler : ASMModule, name='Module'}
local stack = ['Module']
A.applyModule_(1 : J) : ??#961 null
local variables = {mode='', context='Module', self=ATL To ASM Compiler
: ASMModule, localenv=Tuple {self = temp!aml_xml2xpdl_xml, eoi2 = 79,
eoi = 77, thn = 76, thn2 = 78}, me=temp!aml_xml2xpdl_xml}
local stack = []
local variables = {mode='apply', self=ATL To ASM Compiler : ASMModule,
me=temp!ObjOcc2RoutingXOR}
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#2743 null
local variables = {mode='apply', me=temp!ObjOcc2RoutingXOR, self=ATL To
ASM Compiler : ASMModule, name='LazyMatchedRule'}
local stack = ['LazyMatchedRule']
A.applyLazyMatchedRule_apply(1 : J) : ??#24 null
local variables = {mode='apply', context='LazyMatchedRule', self=ATL To
ASM Compiler : ASMModule, localenv=Tuple {self =
temp!ObjOcc2RoutingXOR}, me=temp!ObjOcc2RoutingXOR}
local stack = []
local variables = {mode='apply_refining_false', self=ATL To ASM
Compiler : ASMModule, me=temp!ObjOcc2RoutingXOR}
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#2771 null
me=temp!ObjOcc2RoutingXOR, self=ATL To ASM Compiler : ASMModule,
A.applyLazyMatchedRule_apply_refining_false(1 : J) : ??#24 null
context='LazyMatchedRule', self=ATL To ASM Compiler : ASMModule,
localenv=Tuple {self = temp!ObjOcc2RoutingXOR}, me=temp!ObjOcc2RoutingXOR}
local stack = []
local variables = {mode='apply_unique_false', self=ATL To ASM Compiler
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#2799 null
A.applyLazyMatchedRule_apply_unique_false(1 : J) : ??#59 null
local stack = []
local variables = {mode='apply_unique_common', self=ATL To ASM Compiler
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#2813 null
A.applyLazyMatchedRule_apply_unique_common(1 : J) : ??#182 null
local stack = []
local variables = {mode='applyLazyInit', self=ATL To ASM Compiler :
ASMModule, me=temp!<unnamed>}
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#2995 null
local variables = {mode='applyLazyInit', me=temp!<unnamed>, self=ATL To
ASM Compiler : ASMModule, name='OutPattern'}
local stack = ['OutPattern']
A.applyOutPattern_applyLazyInit(1 : J) : ??#32 null
local variables = {mode='applyLazyInit', context='OutPattern', self=ATL
To ASM Compiler : ASMModule, localenv=Tuple {self = temp!<unnamed>},
me=temp!<unnamed>}
local stack = []
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#3009 null
ASM Compiler : ASMModule, name='SimpleOutPatternElement'}
local stack = ['SimpleOutPatternElement']
A.applySimpleOutPatternElement_applyLazyInit(1 : J) : ??#47 null
context='SimpleOutPatternElement', self=ATL To ASM Compiler : ASMModule,
localenv=Tuple {self = temp!<unnamed>}, me=temp!<unnamed>}
local stack = []
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#3023 null
ASM Compiler : ASMModule, name='Binding'}
local stack = ['Binding']
A.applyBinding_applyLazyInit(1 : J) : ??#53 null
local variables = {mode='applyLazyInit', context='Binding', self=ATL To
me=temp!<unnamed>}
local stack = []
me=temp!<notnamedyet>}
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#1819 null
local variables = {mode='', me=temp!<notnamedyet>, self=ATL To ASM
Compiler : ASMModule, name='VariableExp'}
local stack = ['VariableExp']
A.applyVariableExp_(1 : J) : ??#24 null
local variables = {mode='', context='VariableExp', self=ATL To ASM
Compiler : ASMModule, localenv=Tuple {self = temp!<notnamedyet>},
local stack = []
local variables = {mode='thisModule_false', self=ATL To ASM Compiler :
ASMModule, me=temp!<notnamedyet>}
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#1847 null
local variables = {mode='thisModule_false', me=temp!<notnamedyet>,
self=ATL To ASM Compiler : ASMModule, name='VariableExp'}
A.applyVariableExp_thisModule_false(1 : J) : ??#24 null
local variables = {mode='thisModule_false', context='VariableExp',
self=ATL To ASM Compiler : ASMModule, localenv=Tuple {self =
temp!<notnamedyet>}, me=temp!<notnamedyet>}
local stack = []
local variables = {mode='self_false', self=ATL To ASM Compiler :
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#1875 null
local variables = {mode='self_false', me=temp!<notnamedyet>, self=ATL
A.applyVariableExp_self_false(1 : J) : ??#25 null
local variables = {mode='self_false', context='VariableExp', self=ATL
To ASM Compiler : ASMModule, localenv=Tuple {self = temp!<notnamedyet>},
local stack = []
NativeOperation public void
org.atl.engine.vm.ASMEmitter.emit(java.lang.String,java.lang .String)
args = [org.atl.engine.vm.ASMEmitter@22f08f, 'load', 'transitionRef']
****** END Stack Trace
Trying to continue execution despite the error.
mode applyLazyInit
mode applyLazyInit
org.atl.engine.vm.nativelib.ASMString.evalSOTSBrackets(ASMSt ring.java:303)
at sun.reflect.GeneratedMethodAccessor26.invoke(Unknown Source)
org.atl.engine.vm.ClassNativeOperation.exec(ClassNativeOpera tion.java:59)
ERROR: variable id not defined:
exception:
at sun.reflect.GeneratedMethodAccessor38.invoke(Unknown Source)
org.atl.engine.vm.ASMOperation.endLocalVariableEntry(ASMOper ation.java:434)
at org.atl.engine.vm.ASMEmitter.endLocalVariableEntry(ASMEmitte r.java:95)
... 163 more
local stack = []
local stack = []
local stack = []
local stack = []
local stack = []
local stack = []
local stack = []
local stack = []
local stack = []
local stack = []
local stack = []
A.applyLazyMatchedRule_apply_unique_common(1 : J) : ??#237 null
local stack = []
local variables = {mode='applyLazy_free', self=ATL To ASM Compiler :
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#3037 null
local variables = {mode='applyLazy_free', me=temp!<unnamed>, self=ATL
To ASM Compiler : ASMModule, name='OutPattern'}
A.applyOutPattern_applyLazy_free(1 : J) : ??#32 null
local variables = {mode='applyLazy_free', context='OutPattern',
local stack = []
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#3079 null
To ASM Compiler : ASMModule, name='ForEachOutPatternElement'}
local stack = ['ForEachOutPatternElement']
A.applyForEachOutPatternElement_applyLazy_free(1 : J) : ??#13 null
context='ForEachOutPatternElement', self=ATL To ASM Compiler :
ASMModule, localenv=Tuple {self = temp!<unnamed>}, me=temp!<unnamed>}
local stack = []
A.applyOutPatternElement_applyLazy_free(1 : J) : ??#24 null
local variables = {mode='applyLazy_free', context='OutPatternElement',
local stack = []
local variables = {mode='endLocalVariable', self=ATL To ASM Compiler :
local stack = []
A.applyWithName(1 : S, 2 : J, 3 : S) : ??#1721 null
local variables = {mode='endLocalVariable', me=temp!<unnamed>, self=ATL
A.applyForEachOutPatternElement_endLocalVariable(1 : J) : ??#13 null
local stack = []
A.applyOutPatternElement_endLocalVariable(1 : J) : ??#13 null
context='OutPatternElement', self=ATL To ASM Compiler : ASMModule,
local stack = []
A.applyPatternElement_endLocalVariable(1 : J) : ??#13 null
local variables = {mode='endLocalVariable', context='PatternElement',
local stack = []
A.applyVariableDeclaration_endLocalVariable(1 : J) : ??#16 null
context='VariableDeclaration', self=ATL To ASM Compiler : ASMModule,
local stack = []
org.atl.engine.vm.ASMEmitter.endLocalVariableEntry(java.lang .String)
args = [org.atl.engine.vm.ASMEmitter@22f08f, '']
| Re: [ATL] Problems with a lazy rule [message #47215 is a reply to message #47169] |
Mon, 18 June 2007 05:39  |
You cannot use distinct-foreach in a lazy rule. This is what the
"warning" messages are about. I am going to change them into error
messages reported in the editor, thanks for pointing this out ;-).
Lazy rules can generally be used to achieve the same result you obtained
with distinct-foreach.
Frédéric Jouault
Erik Becker wrote:
> Hi all,
> Can any one help?
> Greetings
> Erik
> P.S.:
> from
> using {
> to
> name <- 'Activity',
> route,
> priority,
> documentation,
> name <- 'Route'
> name <- 'Priority'
> join : XML!Element(
> name <- 'Join',
> name <- 'Split',
> splitTypeAttribute,
> transitionRefs
> name <- 'Type',
> name <- 'Type',
> linkedObjects)(
> in linkedObjects)(
> name <- 'Id',
> value <-
> Tuple{
> ).getNumericId()
> else
> Tuple{
> endif
> exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 185 more
> ASMModule,
> local stack = []
> local stack = []
> local stack = []
> ASM Compiler : ASMModule, name='Module'}
> Compiler : ASMModule, localenv=Tuple {self = temp!aml_xml2xpdl_xml, eoi2
> = 79, eoi = 77, thn = 76, thn2 = 78}, me=temp!aml_xml2xpdl_xml}
> local stack = []
> local stack = []
> To ASM Compiler : ASMModule, name='LazyMatchedRule'}
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> To ASM Compiler : ASMModule, name='SimpleOutPatternElement'}
> local stack = []
> local stack = []
> To ASM Compiler : ASMModule, name='Binding'}
> me=temp!<unnamed>}
> local stack = []
> local stack = []
> local stack = []
> : ASMModule, me=temp!<notnamedyet>}
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> mode applyLazyInit
> mode applyLazyInit
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 163 more
> ASMModule,
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
> local stack = []
Current Time: Wed Nov 05 12:02:06 EST 2025
Powered by FUDForum. Page generated in 0.04474 seconds
