Home » Eclipse Projects » Subversive » Installed Subversive & connectors cannot select connectors
Installed Subversive & connectors cannot select connectors [message #47164] Tue, 09 June 2009 13:18 Go to next message
Installed Subversive from
http://download.eclipse.org/technology/subversive/0.7/update -site/ site
then discovered I needed connectors, installed them from
http://community.polarion.com/projects/subversive/download/e clipse/2.0/ganymede-site/
I still cannot see any choice of connectors in wthe
Window>preferences>team>SVN panel It is blank and cannot actvate the
dropdown box for selection of anything
I'm on Ganymeade Version: 3.4.2 Build id: M20090211-1700
Win 64 vista
Re: Installed Subversive & connectors cannot select connectors [message #47206 is a reply to message #47164] Wed, 10 June 2009 04:39 Go to previous messageGo to next message
tombrander@tombrander.com (Tom Brander) writes:
> site then discovered I needed connectors, installed them from
> Win 64 vista
According to
< http://www.polarion.com/products/svn/subversive.php?src=ecli pseproject>
Latest Release – Recommended
* http://download.eclipse.org/technology/subversive/0.7/update -site/ - [required] Subversive plug-in
* http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/ - [required] Subversive SVN Connectors
You may have more success with that connectors site.
When installing connectors I tend to install only the "Subversive SVN
Connectors" plugin and the latest SVNKit (currently 1.3.0).
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: Installed Subversive & connectors cannot select connectors [message #47262 is a reply to message #47206] Wed, 10 June 2009 14:15 Go to previous messageGo to next message
That did it Thanks,
Re: Installed Subversive & connectors cannot select connectors [message #47290 is a reply to message #47206] Wed, 10 June 2009 14:19 Go to previous message
That did it thanks!
Previous Topic:Can not select SVN Connector
Next Topic:Functionality of Compare With ... Branch/Tag
Current Time: Tue Nov 18 00:19:04 EST 2025
Powered by FUDForum. Page generated in 0.04725 seconds
