Home » Modeling » GMF (Graphical Modeling Framework) » "Extending" the generated Property view
"Extending" the generated Property view [message #47163] Wed, 13 September 2006 08:53 Go to next message
Originally posted by: natorion.gmx.at
I am working on a project for modelling processes. The nodes have the
following important attributes:
-associatedClass (EString)
-customProperties (EMap)
I have two questions:
-How can I extend/edit/overwrite/whatever the default GMF/EMF Property
view? I want to select the value for associatedClass from a dropdown list
(similar to EEnum).
-How can I add an additional tab in the Property view, which should be
able to edit the customProperties attribute?
If this questions do not belong to this newsgroup, please forgive me ;)
Thanks in advance,
Michael
Re: "Extending" the generated Property view [message #47489 is a reply to message #47163] Wed, 13 September 2006 17:58 Go to previous messageGo to next message
Hi Michael
Check out the tabbed properties view article
http://www.eclipse.org/articles/Article-Tabbed-Properties/ta bbed_properties_view.html
It tells you how to add tabs and sections (fields) to the tabbed properties
view.
Cheers...
Anthony
"Michael H." <natorion@gmx.at> wrote in message
news:c3b77749e115def821f7029522f217c0$1@www.eclipse.org...
> Hello,
> (similar to EEnum).
> Thanks in advance,
> Michael
Re: "Extending" the generated Property view [message #48501 is a reply to message #47489] Fri, 15 September 2006 02:25 Go to previous messageGo to next message
Thanks very much. I must be blind because I did not find this tutorial
alone.
Michael
On Wed, 13 Sep 2006 23:58:06 +0200, Anthony Hunter <anthonyh@ca.ibm.com>
wrote:
> Hi Michael
> properties
> view.
> Cheers...
> Anthony
>> Hello,
>> list
>> (similar to EEnum).
>> Thanks in advance,
>> Michael
Re: "Extending" the generated Property view [message #49438 is a reply to message #47489] Sun, 17 September 2006 09:43 Go to previous messageGo to next message
Finally, I found somewhere in this newsgroup the solution for my problem:
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg00890.html
I have set up a test model with only a Diagram class and a Node class. The
Node class contains two attributes:
-name (EString)
-info (EMap)
The code works fine for the name attribute, but the info attribute is not
saved. I am using a Hashtable for the Map interface implementation. The
model is notified and sets the new Map but the info attribute is not saved
in the XML file. I don't have a clue where the error might be.
Thanks in advance,
Michael
wrote:
> Hi Michael
> properties
> view.
> Cheers...
> Anthony
>> Hello,
>> list
>> (similar to EEnum).
>> Thanks in advance,
>> Michael
Re: "Extending" the generated Property view [message #53054 is a reply to message #47163] Thu, 21 September 2006 10:28 Go to previous message
I've put some details about how to deal with property sheet in M2 here
http://wiki.eclipse.org/index.php/GMF_GenModel_Hints#Tuning_ property_sheet
Artem
> Hello,
> (similar to EEnum).
> Thanks in advance,
> Michael
Previous Topic:Missing methods in a generated Class
Next Topic:modify properties view
Current Time: Fri Nov 07 00:08:28 EST 2025
Powered by FUDForum. Page generated in 0.03758 seconds
