Home » Archived » Test and Performance Tools Platform (TPTP) » launching AGR test from command line
launching AGR test from command line [message #47122] Fri, 16 December 2005 17:42 Go to next message
Greetings,
for end-to-end automation, we need the ability to launch AGR tests
programmatically, i.e. from a command line/shell. Unfortunately, I have not
been able to find any documentation to this extent, or any posts on this
forum. Apologies if this issue was discussed previously, but I have not
been able to find any posts to this extent. Any input would be highly
appreciated.
Thanks much!
- Stephan
Re: launching AGR test from command line [message #47248 is a reply to message #47122] Sun, 18 December 2005 03:11 Go to previous message
TPTP provides an automation framework that allows the launch of test suites
via light weight clients (e.g. ANT script, shell scripts, and etc...) To
find out more on how you can launch your scripts using this framework see:
1) 'example.xml' OR 'automation-client-adapter.bat' OR
'automation-client-adapter.cmd' OR 'automation-client-adapter.sh' under the
plugin org.eclipse.hyades.execution. You can download the plugin from
TPTP's cvs (http://dev.eclipse.org/cvshowto.html)
2) Read "TPTP Tester guide" > "JUnit testing with TPTP" > "Testing JUnit
Plug-ins with TPTP" > "Launching tests from scripts and applications
Thanks.
"Stephan Lips" <stephan.lips@gmail.com> wrote in message
news:dnvfsr$5di$1@news.eclipse.org...
> Greetings,
not
> appreciated.
> Thanks much!
> - Stephan
Previous Topic:Impossible to remove the plug-in
Next Topic:Profiling. Can't make it work
Current Time: Sun Nov 02 02:13:55 EST 2025
Powered by FUDForum. Page generated in 0.03911 seconds
