Home » Eclipse Projects » Nebula » Getting SWT working on 3.2.2 (Synaptec install)
Getting SWT working on 3.2.2 (Synaptec install) [message #47104] Sat, 19 January 2008 19:04 Go to next message
Originally posted by: jorgen.uoguelph.ca
I'm having a hell of a time getting swt working on the standard linux
install.
I'm admittedly new to eclipse and it's resource/cvs system but this is
nightmareish...
logfile available.
Re: Getting SWT working on 3.2.2 (Synaptec install) [message #47134 is a reply to message #47104] Sun, 20 January 2008 04:43 Go to previous message
You should write to eclipse.newcomer. Most of the time the reason is
that standard java on linux is gcj. You should use a Sun JDK.
Tom
> install.
> nightmareish...
> logfile available.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Getting SWT working on 3.2.2 (Synaptec install) [message #587860 is a reply to message #47104] Sun, 20 January 2008 04:43 Go to previous message
Tom
> install.
> nightmareish...
> logfile available.
Previous Topic:Getting SWT working on 3.2.2 (Synaptec install)
Next Topic:Suggestions for display of editable and non-editable cells in Grid
Current Time: Fri Oct 17 02:51:58 EDT 2025
Powered by FUDForum. Page generated in 0.04357 seconds
