Home » Eclipse Projects » Technology Project and PMC » Debugging in eclipse
Debugging in eclipse [message #47050] Thu, 27 February 2003 10:48 Go to next message
Originally posted by: abraham_cherian.reyrey.com
We\'re planning to use Eclipse as the IDE for iView development using SAP
portal PDK. I\'m not quite sure how to run a debugger against iViews that
I am creating. Help!!!
Re: Debugging in eclipse [message #47822 is a reply to message #47050] Mon, 03 March 2003 12:37 Go to previous message
Abe wrote:
> We\\\\\\\'re planning to use Eclipse as the IDE for iView development using
SAP
> portal PDK. I\\\\\\\'m not quite sure how to run a debugger against iViews
that
Here\\\'s what I\\\'ve got so far:
I started Tomcat in debug mode (the port under the debugserver option was
5000).
Went into Eclipse, Debug...->Remote Java Application -> New; Connection
Type = Standard (socket), Host = localhost; Port = 5000. Then clicked
Debug;
I get a Launch configurartion error that said \\\"Failed to connect to
remote VM as connection was refused\\\".
Any ideas what I\\\'m doing wrong? This does not work for other port
numbers as well (I\\\'ve tried 8000, 9000).
Re: Debugging in eclipse [message #591169 is a reply to message #47050] Mon, 03 March 2003 12:37 Go to previous message
SAP
that
5000).
Debug;
Previous Topic:Add JARs offers wrong libraries
Next Topic:SWT And Eclipse.
Current Time: Fri Nov 07 16:26:32 EST 2025
Powered by FUDForum. Page generated in 0.05023 seconds
