Home » Archived » XML Schema Definition (XSD) » XSDConstrainingFacet.getEffectiveValue().toString()
XSDConstrainingFacet.getEffectiveValue().toString() [message #46993] Thu, 03 June 2004 11:59 Go to next message
Originally posted by: NOpcooperSPAM.uk.ibm.com
I've been playing with Facets on simple types and I've encountered
exceptions being thrown when I call the toString() method on the
effective values of certain types of facet. For example, if I call it
for a hexBinary value in an enumeration as in the following example:
<schema targetNamespace="http://com/schemas/Example"
xmlns="http://www.w3.org/2001/XMLSchema">
<complexType name="CAType">
<sequence>
<element name="el60" type="xsd1:type60"/>
</sequence>
</complexType>
<simpleType name="type60">
<restriction base="hexBinary">
<enumeration value="0FB7ff01"/>
<enumeration value="0F56CCAABBAA"/>
<enumeration value="CABBA9E5000000"/>
</restriction>
</simpleType>
</schema>
I get:
java.lang.ArrayIndexOutOfBoundsException: -5
at org.eclipse.xsd.impl.type.DataValue$HexBin.encode(DataValue. java:454)
org.eclipse.xsd.impl.type.XSDHexBinaryType.getCanonicalLiter al(XSDHexBinaryType.java:44)
org.eclipse.xsd.impl.type.XSDAnySimpleType$ByteSequence.toSt ring(XSDAnySimpleType.java:73)
at java.lang.String.valueOf(String.java:2516)
at org.eclipse.emf.common.util.BasicEList.toString(BasicEList.j ava:1112)
Is there a better way for me to query these values or is this a bug?
I've also seen oddities when querying the value of time related simple
types, for example:
<simpleType name="type50">
<restriction base="gMonthDay">
<minInclusive value="--01-31+01:00"/>
<maxExclusive value="--02-07"/>
</restriction>
</simpleType>
The timezone seems to be replaced with an undisplayable character such
as the values: '--1-30Z' or '--2-7?'
Is there a way that I can retrieve those values from a schema in a
displayable way that doesn't require special logic for each data type?
Paul.
Re: XSDConstrainingFacet.getEffectiveValue().toString() [message #47025 is a reply to message #46993] Thu, 03 June 2004 12:11 Go to previous messageGo to next message
Paul,
I'll have a look. We've recently moved the implementation of the simple types from XSD to
Ecore and upgraded to using a copy of a more current Xerces implementation...
> <sequence>
> </sequence>
> </complexType>
> </restriction>
> </simpleType>
> </schema>
> I get:
> at
> at
> types, for example:
> </restriction>
> </simpleType>
> Paul.
Re: XSDConstrainingFacet.getEffectiveValue().toString() [message #47055 is a reply to message #46993] Thu, 03 June 2004 13:12 Go to previous message
Paul,
Now that I look more closely, I see that the stack is showing that you are using the older
implementation of the datatypes, not the newer ones that are in Ecore now. I think it's
working properly in the latest driver.
> <sequence>
> </sequence>
> </complexType>
> </restriction>
> </simpleType>
> </schema>
> I get:
> at
> at
> types, for example:
> </restriction>
> </simpleType>
> Paul.
Re: XSDConstrainingFacet.getEffectiveValue().toString() [message #588083 is a reply to message #46993] Thu, 03 June 2004 12:11 Go to previous message
Paul,
> <sequence>
> </sequence>
> </complexType>
> </restriction>
> </simpleType>
> </schema>
> I get:
> at
> at
> types, for example:
> </restriction>
> </simpleType>
> Paul.
Re: XSDConstrainingFacet.getEffectiveValue().toString() [message #588100 is a reply to message #46993] Thu, 03 June 2004 13:12 Go to previous message
Paul,
> <sequence>
> </sequence>
> </complexType>
> </restriction>
> </simpleType>
> </schema>
> I get:
> at
> at
> types, for example:
> </restriction>
> </simpleType>
> Paul.
Previous Topic:XSDConstrainingFacet.getEffectiveValue().toString()
Next Topic:XSDSimpleTypeDefinition - facets, syntheticFacets, and facetContents
Current Time: Fri Nov 07 11:21:38 EST 2025
Powered by FUDForum. Page generated in 0.03468 seconds
