| How to use API tools in headless mode? [message #46950] |
Fri, 13 February 2009 14:36  |
I am trying to get API analysis working on command line (batch mode), but
couldn't find any helpful document. I found this article
http://wiki.eclipse.org/index.php/PDE_UI_Incubator_ApiTools_ Compare but am
not sure it is valid. I could not find a way to get the API Tools dialogs
and don't know where is the "ApiTools" utility.
In the article
http://www.ibm.com/developerworks/opensource/library/os-ecli pse-api-tools/
the author mentioned that there is a way to run in headless mode but
didn't provide a link. He also mentioned Ant tasks in
org.eclipse.pde.api.tools plug-in. I found there are some apitooling.* Ant
tasks available in Preferences->Ant Runtime. But I couldn't make it work.
When I run apitooling.apitoolsverification task in ant, if I don't use
"taskdef" (it's supposed to work without taskdef) it complains "failed to
create task or type apitooling.apitoolsverification
Cause: The name is undefined.". If I add "taskdef", then it complains
"taskdef A class needed by class
org.eclipse.pde.api.tools.internal.tasks.APIToolsVerificatio nTask cannot
be found". Adding apitooling-ant.jar to the ant classpath doesn't help.
Probably I missed something here. Anyone has experience on API tools or
know how to use ant tasks provided by Eclipse? Some documents will help
too.
Zhongyu
| Re: How to use API tools in headless mode? [message #47240 is a reply to message #47159] |
Mon, 16 February 2009 21:14  |
Chris Aniszczyk wrote:
> However, if you download say the Eclipse 3.5M5 build, you can see the
> API Tooling Ant Tasks at:
> Plug-in Development Environment Guide -> Reference -> API Tools and Ant
> Tasks
Thank you very much for this information. I tried this build and it works.
I will read the document you mentioned about how to use these ant tasks. I
tried apitooling.analysis first and pointed it to a build of our
application. But it just report all of our plug-ins are non-API bundles
although we already set some with apiAnalysisNature. What step did I miss
here?
> Regarding your weird problems regarding missing taskdefs, I think you
> have to ensure that the JRE you run your Ant tasks with is the same as
> the running Eclipse. In the JRE tab of your Ant launch configuration,
> there should be an option to use "Run in the same JRE as the workspace."
> That should solve your problems.
I indeed missed this option in eclipse 3.4. But after I checked this
option, I only went a little further. Then I got this error
"build.34.xml:48: Could not unzip SDK into :
C:\DOCUME~1\zzhang\LOCALS~1\Temp\reference"
Do you know what is the problem?
Thank you very much,
Zhongyu
| Re: How to use API tools in headless mode? [message #592055 is a reply to message #46950] |
Mon, 16 February 2009 12:58  |
> too.
Sure, we run API Tools heedlessly at Eclipse for our builds. The
documentation isn't available at help.eclipse.org because Galileo hasn't
been released yet and that release will contained updated documentation.
Tasks
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/caniszczyk | http://twitter.com/eclipsesource
| Re: How to use API tools in headless mode? [message #592067 is a reply to message #47159] |
> Tasks
here?
Zhongyu
FUDForum. Page generated in 0.07352 seconds
