Home » Archived » Visual Editor (VE) » ve cvs
ve cvs [message #46938] Mon, 05 July 2004 10:15 Go to next message
I try VE cvs (cvs co ve-all), build with eclipse 3.0, gef 3.0 and
emf-xsd-sdo 2.0.0
When I create Visual class I get nullpointer exception without stack trace
What is a problem ?
regards
Haris Peco
Re: ve cvs [message #47719 is a reply to message #46938] Tue, 06 July 2004 10:26 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Do you really want to use VE from cvs? That is only useful if you are a
VE developer who is changing VE code. You should be using the already
built downloads instead to use VE.
Thanks, Rich Kulp
Re: ve cvs [message #47953 is a reply to message #47719] Tue, 06 July 2004 16:48 Go to previous messageGo to next message
I have 56k modem connection and I can't download every new release from
beginning
I try VE dowload and it work, but cvs have new features
VE cvs isn't changed in last 7-8 days, but I can't build it
Is it work or not ?
Re: ve cvs [message #48013 is a reply to message #47953] Tue, 06 July 2004 16:51 Go to previous messageGo to next message
I am sorry. I can build it, but I get nullpointer when I open visual class
regards
> beginning
> Is it work or not ?
> Thanks
Re: ve cvs [message #48304 is a reply to message #48013] Tue, 06 July 2004 16:45 Go to previous messageGo to next message
Are you using Export Feature, or are you trying to run it as a Runtime
Workbench?
Thanks, Rich Kulp
Re: ve cvs [message #48363 is a reply to message #48304] Tue, 06 July 2004 20:16 Go to previous messageGo to next message
Both.it is same.
I can't import jem-feature - I get duplicate plugins (com.ibm.* plugins are
in ve-all directory and jem-fature , too)
> Workbench?
Re: ve cvs [message #48393 is a reply to message #48363] Tue, 06 July 2004 20:18 Go to previous messageGo to next message
I can't compile plugin org.eclipse.ve.swt (linux) without add swt-win32.jar,
too
regards
snpe wrote:
> Both.it is same.
> are in ve-all directory and jem-fature , too)
> Thanks
>> Workbench?
Re: ve cvs [message #48441 is a reply to message #48393] Tue, 06 July 2004 18:20 Go to previous messageGo to next message
Two things:
1) Just import ve-all, don't import jem-feature because ve-all already
includes jem-feature.
2) We currently only compile against win32 eclipse. You can compile ON
Linux, but your target Eclipse needs to be a win32 eclipse.
Thanks, Rich Kulp
Re: ve cvs [message #48518 is a reply to message #48441] Tue, 06 July 2004 22:02 Go to previous messageGo to next message
Hello Rich,
I work with manual cvs on linux :
cvs co ve-all
then, import all plugina in ve-all with plugin for import plugin multiple
project
I get error for duplicate plugin and all com.ibm.* plugin are in first
directory in ve-all and in org.eclipse.jem-feature
I try ve on windows , too - it is same - when make visual class I get error
in visual editor - nullpointer exception
I see new pallete (show it when hover), but isn't there frame in visual
editor
Does it mean : compile ve for win32 target on linux and it should work on
linux, too ?
I compile complete eclipse from cvs (without standard 'cvs export' than
manual 'cvs co ..'); emf, gef,cdt , lomboz ... too, but have problem with
ve
It is important for me - does it current ve cvs work ?
Rich Kulp wrote:
> Two things:
Re: ve cvs [message #48812 is a reply to message #48518] Wed, 07 July 2004 10:48 Go to previous messageGo to next message
I suggest using the CVS support in Eclipse. It is great and it would
solve your problem and you would not be doing multiple steps. It would
be just one step, check out from CVS through Eclipse. We do some special
stuff where we have a few projects embedded within another project.
Eclipse CVS checkout of ve-all understands this and does it correctly.
> linux, too ?
No, this means compile on Linux, but in your
Windows->Preferences->Plugin Development->Target Platform you point to a
win32 version of Eclipse.
I can't help unless you do it through Eclipse CVS because it requires a
special setup that Eclipse understands when Eclipse extracts from CVS.
Thanks, Rich Kulp
Re: ve cvs [message #48873 is a reply to message #48812] Wed, 07 July 2004 13:11 Go to previous message
I like special cvs out of eclipse workspace - I work all in my cvs
repository and often delete workspace
One question yet, only:
current ve cvs work fine (open simple visual class without exception) ?
>> linux, too ?
Re: ve cvs [message #48903 is a reply to message #48873] Wed, 07 July 2004 11:03 Go to previous message
Yes, the current cvs code works fine. The Integration build made last
night for the testpass we're in was built from the latest cvs source.
- Jeff
snpe wrote:
Re: ve cvs [message #594440 is a reply to message #46938] Tue, 06 July 2004 10:26 Go to previous message
Thanks, Rich Kulp
Re: ve cvs [message #594501 is a reply to message #47719] Tue, 06 July 2004 16:48 Go to previous message
beginning
Is it work or not ?
Re: ve cvs [message #594517 is a reply to message #47953] Tue, 06 July 2004 16:51 Go to previous message
regards
> beginning
> Is it work or not ?
> Thanks
Re: ve cvs [message #594608 is a reply to message #48013] Tue, 06 July 2004 16:45 Go to previous message
Workbench?
Thanks, Rich Kulp
Re: ve cvs [message #594622 is a reply to message #48304] Tue, 06 July 2004 20:16 Go to previous message
Both.it is same.
> Workbench?
Re: ve cvs [message #594632 is a reply to message #48363] Tue, 06 July 2004 20:18 Go to previous message
too
regards
snpe wrote:
> Both.it is same.
> Thanks
>> Workbench?
Re: ve cvs [message #594642 is a reply to message #48393] Tue, 06 July 2004 18:20 Go to previous message
Two things:
Thanks, Rich Kulp
Re: ve cvs [message #594667 is a reply to message #48441] Tue, 06 July 2004 22:02 Go to previous message
Hello Rich,
cvs co ve-all
project
editor
linux, too ?
ve
Rich Kulp wrote:
> Two things:
Re: ve cvs [message #594748 is a reply to message #48518] Wed, 07 July 2004 10:48 Go to previous message
> linux, too ?
Thanks, Rich Kulp
Re: ve cvs [message #594766 is a reply to message #48812] Wed, 07 July 2004 13:11 Go to previous message
>> linux, too ?
Re: ve cvs [message #594777 is a reply to message #48873] Wed, 07 July 2004 11:03 Go to previous message
- Jeff
snpe wrote:
Previous Topic:JVM in taskbar
Next Topic:seeing the invisible
Current Time: Fri Nov 14 16:03:53 EST 2025
Powered by FUDForum. Page generated in 0.07416 seconds
