Home » Modeling » Epsilon » [Epsilon] Default values in HUTN
[Epsilon] Default values in HUTN [message #394] Mon, 13 October 2008 06:36 Go to next message
Hello again!
I'm using your trunk version of epsilon ir order to support links to
external elements, but I have noticed that I have to specify a lot more of
properties. Before those values where filled by default, but now I have to
made it by myself.
Is there a reason for that? Will it be fixed?
Many thanks,
Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #399 is a reply to message #394] Mon, 13 October 2008 06:51 Go to previous messageGo to next message
Hi Hector,
As a temporary workaround you can comment out lines 32-36 in
/org.eclipse.epsilon.hutn.engine/src/org/eclipse/epsilon/hut n/validation/model/ValidateIntermediateModel.evl
I'll talk to Louis and see if it is sensible to remove/modify this
constraint.
Dimitrios
Héctor Iturria wrote:
> Hello again!
> of properties. Before those values where filled by default, but now I
> have to made it by myself.
> Many thanks,
> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #404 is a reply to message #394] Mon, 13 October 2008 08:48 Go to previous messageGo to next message
Hi Héctor
Because a sensible default value can be inferred for all attribute
types, we've changed this constraint to apply only to references.
If you update the org.eclipse.epsilon.hutn.engine plugin from our SVN
repository, you'll receive this change.
Does this fix your problem?
Louis.
> Hello again!
> Many thanks,
> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #814 is a reply to message #404] Mon, 13 October 2008 10:51 Go to previous messageGo to next message
As you have said, it has solved my problems except for the references. Do
I really need to change the hutn files and add the information or is
something that is going to be fixed too?
For example, in associations I still have to specify the endType and
relatedElement, before I had not.
Many thanks,
Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #843 is a reply to message #814] Mon, 13 October 2008 11:24 Go to previous messageGo to next message
Hi Héctor,
In UML 2.1,, the endType and relatedElement features of Assocation have
a lowerbound of 1, signifying that a value is required, when
instantiating a valid UML model.
We are now enforcing this constraint with HUTN, so you'll need to update
your HUTN source files accordingly.
We don't have any plans to change this, but let us know if you find it
too restrictive - we'll consider your feedback carefully.
Louis.
> Do I really need to change the hutn files and add the information or is
> Many thanks,
> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #900 is a reply to message #843] Wed, 15 October 2008 10:05 Go to previous messageGo to next message
--------------080408030309040308050801
It is not too much restrictive, but I was adding the definition of the
properties in the HUTN files and I got some errors. I get no errors when
coding, just when I save the file to generate the model.
The error:
org.eclipse.epsilon.hutn.exceptions.HutnGenerationException: Internal
error: java.lang.UnsupportedOperationException
raises from the property endType or relatedElement of an Association
element.
I send you a HUTN file and the console output.
Many thanks,
H
Re: [Epsilon] Default values in HUTN [message #928 is a reply to message #900] Wed, 15 October 2008 13:55 Go to previous messageGo to next message
Hi Hector,
This happens because relatedElement and endType are both derived (and
thus unsettable references). I've updated the validation module to
handle such cases and committed the changes to the SVN. Now saving your
HUTN file should bring up 3 errors:
1) Association1 must specify a value for the following reference
features: memberEnd (as memberEnd has a lower-bound of 2)
2) Feature endType is not changeable
3) Feature relatedElement is not changeable
Thanks a lot for reporting this!
Dimitrios
> The error:
> element.
> Many thanks,
> Héctor Iturria
> Louis Rose escribió:
>> Hi Héctor,
>> have a lowerbound of 1, signifying that a value is required, when
>> update your HUTN source files accordingly.
>> Cheers,
>> Louis.
>>> Hi,
>>> references. Do I really need to change the hutn files and add the
>>> information or is something that is going to be fixed too?
>>> Many thanks,
>>> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #958 is a reply to message #928] Thu, 16 October 2008 03:43 Go to previous messageGo to next message
--------------010709060007030601090102
Hi!
I got the 3 errors and I have already updated all my models. I am almost
there...but not yet :)
Now what it raises an error are enumerations. For example, in one of my
HUTN files (based on the UML 2.1 metamodel) I have this fragment of code:
Property "dst"{
type: Class "Class2"
aggregation: composite
upper: 1
I have followed the example of your blog to specify the property
aggregation, but I don't know if it is really a bug or I missed something.
Again, I attach the output with the info of the error.
Many thanks!
H
Re: [Epsilon] Default values in HUTN [message #988 is a reply to message #958] Thu, 16 October 2008 04:24 Go to previous message
Hi Hector,
Thanks (again) for reporting this! Should be fixed now :)
Dimitrios
> Hi!
> Property "dst"{
> upper: 1
> Many thanks!
> Héctor Iturria
> Dimitrios Kolovos escribió:
>> Hi Hector,
>> your HUTN file should bring up 3 errors:
>> Cheers,
>> Dimitrios
>>> Hi,
>>> the properties in the HUTN files and I got some errors. I get no
>>> errors when coding, just when I save the file to generate the model.
>>> The error:
>>> element.
>>> Many thanks,
>>> Héctor Iturria
>>>> Hi Héctor,
>>>> it too restrictive - we'll consider your feedback carefully.
>>>> Cheers,
>>>> Louis.
>>>>> Hi,
>>>>> and relatedElement, before I had not.
>>>>> Many thanks,
>>>>> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #560924 is a reply to message #394] Mon, 13 October 2008 06:51 Go to previous message
Hi Hector,
constraint.
Dimitrios
> Hello again!
> Many thanks,
> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #560937 is a reply to message #394] Mon, 13 October 2008 08:48 Go to previous message
Hi Héctor
Louis.
> Hello again!
> Many thanks,
> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #560988 is a reply to message #404] Mon, 13 October 2008 10:51 Go to previous message
Many thanks,
Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #561001 is a reply to message #814] Mon, 13 October 2008 11:24 Go to previous message
Hi Héctor,
Louis.
> Many thanks,
> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #561022 is a reply to message #843] Wed, 15 October 2008 10:05 Go to previous message
The error:
element.
Many thanks,
H
Re: [Epsilon] Default values in HUTN [message #561038 is a reply to message #900] Wed, 15 October 2008 13:55 Go to previous message
Hi Hector,
Dimitrios
> The error:
> element.
> Many thanks,
> Héctor Iturria
>> Hi Héctor,
>> Cheers,
>> Louis.
>>> Hi,
>>> Many thanks,
>>> Héctor Iturria
Re: [Epsilon] Default values in HUTN [message #561049 is a reply to message #928] Thu, 16 October 2008 03:43 Go to previous message
Hi!
Property "dst"{
upper: 1
Many thanks!
H
Re: [Epsilon] Default values in HUTN [message #561065 is a reply to message #958] Thu, 16 October 2008 04:24 Go to previous message
Hi Hector,
Dimitrios
> Hi!
> Property "dst"{
> upper: 1
> Many thanks!
> Héctor Iturria
>> Hi Hector,
>> Cheers,
>> Dimitrios
>>> Hi,
>>> The error:
>>> element.
>>> Many thanks,
>>> Héctor Iturria
>>>> Hi Héctor,
>>>> Cheers,
>>>> Louis.
>>>>> Hi,
>>>>> Many thanks,
>>>>> Héctor Iturria
Previous Topic:[HUTN] Null value on a reference
Next Topic:Re: Available Extension Points for UML2Tools
Current Time: Tue Nov 18 21:36:17 EST 2025
Powered by FUDForum. Page generated in 0.34029 seconds
