| Re: Return of IBM Infrastructure [message #587238 is a reply to message #46845] |
Mon, 01 September 2008 08:35  |
Hi Sarah!
Thanks a lot!
It is perfect to have another Registry Testserver - in addition to the
official NIST Public Registry - for testing our Repository Implementation!
I just have two short questions:
- I tried registering a document for a created test patient, but when I
try to search the registry
(http://xds-ibm.lgs.com:9081/IBMXDSRegistry/query_docs.jsp) I get an
error. I suppose it is a server error, because my HTML output just shows
the number "500" on the upper left corner. (My patient hast the ID
4711^^^^...)
- I am unable to open the site
http://ihe-kudu.wustl.edu/na2008/certificates.php in order to download the
SSL Certificate for a secure connection. Are they located somewhere else,
too?
Thanks in Advance for your help!
Greetings
Stefan
| Re: Return of IBM Infrastructure [message #587250 is a reply to message #46971] |
Tue, 02 September 2008 11:09  |
Hi Stefan,
1. I think there's a problem with the metadata that you're registering.
In the past there has been a bug in the web app at
/IBMXDSRegistry/query_docs.jsp that when certain metadata elements are
incorrectly populated or missing, it causes errors when displaying the
simple query. I'll pass the info along to the guys that run the server
and see if they can investigate. But, if you're getting this error,
there was metadata registered for the patient. Try using an XDS
consumer to query directly.
2. I took a look at the certificates and the server does not appear to
have the Connectathon certificates loaded (which is from the page you
listed below). Again I'll contact the guys that run the server and ask
for them to either publish the certificates they're using or to load the
Connectathon certificates. Once they do that I'll send you a private mail.
-Matt
Stefan S. wrote:
> Hi Sarah!
> Thanks a lot!
> 4711^^^^...)
> the SSL Certificate for a secure connection. Are they located somewhere
> else, too?
> Greetings
> Stefan
FUDForum. Page generated in 0.06166 seconds
