Home » Archived » Visual Editor (VE) » Error while creating a Visual Class (Swing)
| Error while creating a Visual Class (Swing) [message #46735] |
Sun, 04 July 2004 15:09  |
--------------030803050607040907010308
Content-Type: text/plain; charset=us-ascii; format=flowed
I tried to create a Visual Class (based on JPanel) and when it goes to
the editor, it raises an "NullPointerException".
Attached are two stacks:
stack_creating_visual_class.txt = the stack when I try to create the
Java Visual Class and when I try to open the class from the Package Explorer
stack_selecting_from_package_explorer.txt = the stack when I try to open
the class from the package explorer (after closing it from the editor).
And also, I cannot put any component on the JPanel.
Any ideas?
Thanks in advance
I donloaded:
VE-runtime-S20040628 (VE-runtime-S20040628.zip)
GEF-runtime-3.0 (GEF-runtime-3.0.zip)
emf-sdo-runtime-2.0.0 (emf-sdo-runtime-2.0.0.zip)
Alessandro
name="stack_selecting_from_package_explorer.txt"
Content-Disposition: inline;
filename="stack_selecting_from_package_explorer.txt"
!ENTRY org.eclipse.core.runtime 4 2 Jul 04, 2004 16:06:01.578
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.runtime".
!STACK 0
at org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:816)
at org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:752)
at org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean Proxy(BeanProxyUtilities.java:307)
at org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean Proxy(BeanProxyUtilities.java:287)
at org.eclipse.ve.internal.jfc.core.RootPaneContainerTreeEditPa rt.getChildJavaBeans(RootPaneContainerTreeEditPart.java:97)
at org.eclipse.ve.internal.jfc.core.RootPaneJMenuBarContainerTr eeEditPart.getChildJavaBeans(RootPaneJMenuBarContainerTreeEd itPart.java:88)
at org.eclipse.ve.internal.java.core.JavaBeanTreeEditPart.getMo delChildren(JavaBeanTreeEditPart.java:256)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:718)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:686)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:219)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:182)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:736)
at org.eclipse.gef.editparts.RootTreeEditPart.setContents(RootT reeEditPart.java:120)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:557)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorOutlinePage.createControl(JavaVisualEditorOutlinePage.ja va:236)
at org.eclipse.ve.internal.java.codegen.editorpart.BeansList.do CreatePage(BeansList.java:32)
at org.eclipse.ui.part.PageBookView.createPage(PageBookView.jav a:310)
at org.eclipse.ui.part.PageBookView.partActivated(PageBookView. java:591)
at org.eclipse.ui.internal.PartListenerList$1.run(PartListenerL ist.java:49)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.PartListenerList.firePartActivated(P artListenerList.java:47)
at org.eclipse.ui.internal.WorkbenchPage.firePartActivated(Work benchPage.java:1371)
at org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2695)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:457)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2215)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2134)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2126)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2113)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2108)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:299)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:137)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:115)
at org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 0)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:212)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:188)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:289)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:490)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:429)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:427)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:635)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:731)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:211)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:206)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:238)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!ENTRY org.eclipse.core.runtime 4 2 Jul 04, 2004 16:06:01.984
!STACK 0
at org.eclipse.gef.editparts.AbstractTreeEditPart.setWidget(Abs tractTreeEditPart.java:180)
at org.eclipse.gef.editparts.RootTreeEditPart.setWidget(RootTre eEditPart.java:138)
at org.eclipse.gef.ui.parts.TreeViewer.hookControl(TreeViewer.j ava:179)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setControl(A bstractEditPartViewer.java:578)
at org.eclipse.gef.ui.parts.TreeViewer.createControl(TreeViewer .java:104)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorOutlinePage.createControl(JavaVisualEditorOutlinePage.ja va:227)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.openVCEViewersIfRequired(JavaVisualEditorPart.java: 418)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$23.run(JavaVisualEditorPart.java:455)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
at org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:295)
at org.eclipse.jface.util.SafeRunnable.handleException(SafeRunn able.java:52)
at org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalPlatform.java:349)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:617)
!ENTRY org.eclipse.ve.java.core 4 0 Jul 04, 2004 16:06:03.656
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.ve.internal.java.core.CompositionComponentsTreeE ditPart.refreshVisuals(CompositionComponentsTreeEditPart.jav a:99)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:685)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:354)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:753)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$9.run(JavaVisualEditorPart.java:1450)
!ENTRY org.eclipse.ui 4 4 Jul 04, 2004 16:06:03.671
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Jul 04, 2004 16:06:03.718
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:2691)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:109)
!ENTRY org.eclipse.ui 4 4 Jul 04, 2004 16:06:03.734
!MESSAGE *** SWT nested exception
!ENTRY org.eclipse.ui 4 0 Jul 04, 2004 16:06:03.843
!MESSAGE java.lang.NullPointerException
!STACK 0
name="stack_creating_visual_class.txt"
filename="stack_creating_visual_class.txt"
!ENTRY org.eclipse.core.runtime 4 2 Jul 04, 2004 16:04:10.609
!STACK 0
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2091)
at org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard$1.run(NewVisualClassCreationWizard.java:364)
!ENTRY org.eclipse.core.runtime 4 2 Jul 04, 2004 16:04:11.140
!STACK 0
!ENTRY org.eclipse.ve.java.core 4 0 Jul 04, 2004 16:04:12.890
!STACK 0
!ENTRY org.eclipse.ui 4 4 Jul 04, 2004 16:04:12.906
!ENTRY org.eclipse.ui 4 0 Jul 04, 2004 16:04:12.937
!STACK 0
!ENTRY org.eclipse.ui 4 4 Jul 04, 2004 16:04:12.953
!ENTRY org.eclipse.ui 4 0 Jul 04, 2004 16:04:13.62
!STACK 0
--------------030803050607040907010308--
| Re: Error while creating a Visual Class (Swing) [message #47087 is a reply to message #46908] |
Mon, 05 July 2004 10:38   |
Alessandro, Francesc,
Please try deleting the configuration directory in your eclipse
directory and see if that fixes the problem. If that does not fix your
problem, please open a bugzilla report explaining what platform, what
versions of eclipse, gef, emf and ve you are using, what you did to
cause the error and the stack trace included in the report.
- Jeff
Francesc Rosés Albiol wrote:
> I have the same problem than Alessandro.
> Francesc Rosés
> Alessandro Fragnani wrote:
>>Hi,
>>Any ideas?
>>Thanks in advance
>>I donloaded:
>>Alessandro
| Re: Error while creating a Visual Class (Swing) [message #47190 is a reply to message #47087] |
Mon, 05 July 2004 23:29   |
Hi Jeff,
Yes.. it seems work now.. thanks for your help.
And it?s working to SWT too.
Alessandro
> - Jeff
>> Regards,
>> Francesc Rosés
>>> Hi,
>>> to the editor, it raises an "NullPointerException".
>>> Explorer
>>> open the class from the package explorer (after closing it from the
>>> editor).
>>> Any ideas?
>>> Thanks in advance
>>> I donloaded:
>>> Alessandro
| Re: Error while creating a Visual Class (Swing) [message #47293 is a reply to message #47087] |
Tue, 06 July 2004 05:36  |
Hi Jeff!
It seems to work for me, but I lost all Eclipse settings...
Francesc
> - Jeff
> > Hi,
> > Regards,
> > Francesc Rosés
> >>Hi,
Explorer
> >>Any ideas?
> >>Thanks in advance
> >>I donloaded:
> >>Alessandro
| Re: Error while creating a Visual Class (Swing) [message #594093 is a reply to message #46792] |
Sun, 04 July 2004 20:46  |
> do have the eclipse-SDK-3.0-win32.zip version ?
Exactly,
The oficial release (not RC). Downloaded 2 days ago.
What do you think that should be?
At the documentation page of VEP, I understood that it should work with.
Alessandro
| Re: Error while creating a Visual Class (Swing) [message #594139 is a reply to message #46735] |
Mon, 05 July 2004 05:34  |
Francesc Rosés
> Any ideas?
> Thanks in advance
> I donloaded:
> Alessandro
| Re: Error while creating a Visual Class (Swing) [message #594209 is a reply to message #46908] |
- Jeff
> Francesc Rosés
>>Hi,
>>Any ideas?
>>Thanks in advance
>>I donloaded:
>>Alessandro
| Re: Error while creating a Visual Class (Swing) [message #594248 is a reply to message #47087] |
Hi Jeff,
Alessandro
> - Jeff
>> Regards,
>> Francesc Rosés
>>> Hi,
>>> Explorer
>>> editor).
>>> Any ideas?
>>> Thanks in advance
>>> I donloaded:
>>> Alessandro
| Re: Error while creating a Visual Class (Swing) [message #594281 is a reply to message #47087] |
Hi Jeff!
Francesc
> - Jeff
> > Hi,
> > Regards,
> > Francesc Rosés
> >>Hi,
Explorer
> >>Any ideas?
> >>Thanks in advance
> >>I donloaded:
> >>Alessandro
Current Time: Mon Nov 03 18:11:24 EST 2025
Powered by FUDForum. Page generated in 0.06512 seconds
