Home » Eclipse Projects » GEF » Problem with logic editor
Problem with logic editor [message #46731] Mon, 02 December 2002 23:32 Go to next message
Originally posted by: enigma69.swbell.net
Part of my original message got clipped.
Additional info.
Running Java 1.4.1 under Redhat Linux 8.
Re: Problem with logic editor [message #57514 is a reply to message #46731] Thu, 23 January 2003 05:17 Go to previous messageGo to next message
I've got the same problem with Eclipse 2.0.2 (stable), and GEF I20030121
under Linux/GTK2. I can't add new components from the palette (but I can
perfectly move around existing components on the editor - once brought onto
the editor via the 4bit-adder wizard).
David Nimmons wrote:
> I am trying to run the logic editor example, but, when I try to drag a
> symbol from the palette, nothing shows up. I am running version 2.0.2,
> build 200211071448
> Additional info.
Re: Problem with logic editor [message #59641 is a reply to message #57514] Wed, 29 January 2003 11:43 Go to previous message
GTK does not work on Eclipse 2.0.2.
"contus" <contus@web.de> wrote in message news:b0oecm$r8u$1@rogue.oti.com...
onto
> > build 200211071448
> > Additional info.
Previous Topic:Is it possible to have two figures attached to the same model?
Next Topic:ContextMenu activation pixel
Current Time: Thu Nov 13 04:56:29 EST 2025
Powered by FUDForum. Page generated in 0.03630 seconds
