Home » General (non-technical) » Eclipse Foundation » Eclipse automated tests failing
Eclipse automated tests failing [message #46702] Mon, 25 June 2007 07:16 Go to next message
I'm not sure if this is the right place to post this message. If not,
please point me to the right group.
I'm running the automated test suite for eclipse on a port for HP-UX IPF.
However, some of the test suites like pdeui, jdtapt, swt etc. are not
running at all. The messages that appear on the console are as follows.
Any clues ?
Virender.
pdeui
Buildfile: test.xml
pdeui:
init:
runtests:
junit:
setup:
setup-zip:
[delete] Deleting directory
/home/sharan/eclipseTest/eclipse-testing/test-ecl
ipse
[mkdir] Created dir:
/home/sharan/eclipseTest/eclipse-testing/test-eclipse
installTestPlugins:
[exec] caution: excluded filename not matched:
eclipse/*/org.eclipse.test.
source*/*
configureTeamTest:
init:
suite:
ui-test:
eclipse-test:
[echo] Running org.eclipse.pde.ui.tests.AllPDETests
[java] !SESSION 2007-06-18 17:48:37.344
[java] eclipse.buildId=I20061102-1715
[java] java.version=1.4.2.03
[java] java.vendor=Hewlett-Packard Co.
[java] BootLoader constants: OS=hpux, ARCH=ia64_32, WS=motif, NL=en
[java] Framework arguments: -application
org.eclipse.test.uitestapplicatio
n
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter
,org.eclipse.pde.ui.tests.AllPDETests.xml -testPluginName
ts -className org.eclipse.pde.ui.tests.AllPDETests
[java] Command-line arguments: -application
tion -dev bin -data
/home/sharan/eclipseTest/eclipse-testing/test-eclipse/eclips
e/pde_sniff_folder
itResultFormatter,org.eclipse.pde.ui.tests.AllPDETests.xml -testPluginName
org.e
clipse.pde.ui.tests -className org.eclipse.pde.ui.tests.AllPDETests -os
hpux -ws
motif -arch ia64_32 -consolelog
[java] !ENTRY org.eclipse.osgi 2 0 2007-06-18 17:48:59.664
[java] !MESSAGE The following is a complete list of bundles which are
not r
esolved, see the prior log entry for the root cause if it exists:
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-18 17:48:59.665
[java] !MESSAGE Bundle
update@plugins/org.eclipse.jdt.apt.ui_3.3.0.v2006100
3-2100.jar [28] was not resolved.
[java] !SUBENTRY 2 org.eclipse.jdt.apt.ui 2 0 2007-06-18 17:48:59.665
[java] !MESSAGE Missing required bundle
org.eclipse.jdt.apt.core_[3.2.0,4.0
0).
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-18 17:48:59.666
update@plugins/org.eclipse.jdt.junit4.runtime_1.0.10
0.v20061101-0800.jar [33] was not resolved.
[java] !SUBENTRY 2 org.eclipse.jdt.junit4.runtime 2 0 2007-06-18
17:48:59.6
66
[java] !MESSAGE Missing required bundle org.junit4_[4.1.0,4.2.0).
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-18 17:48:59.667
update@plugins/org.eclipse.jdt.apt.core_3.3.0.v20061
003-2100.jar [91] was not resolved.
[java] !SUBENTRY 2 org.eclipse.jdt.apt.core 2 0 2007-06-18
17:48:59.667
[java] !MESSAGE Missing Constraint:
Bundle-RequiredExecutionEnvironment: J2
SE-1.5
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-18 17:48:59.668
[java] !MESSAGE Bundle update@plugins/org.junit4_4.1.0.1/ [110] was
not res
olved.
[java] !SUBENTRY 2 org.junit4 2 0 2007-06-18 17:48:59.668
SE-1.5
[java] SIGSEGV 11* segmentation violation
[java] si_signo [11]: SIGSEGV 11* segmentation violation
[java] si_errno [0]: Error 0
[java] si_code [1]: SEGV_MAPERR [addr: 0xef2b9c78]
[java] Aborting...
[java] Unexpected Signal : 11 occurred at PC=0x7AC20721
[java] Function=[Unknown.]
[java] Library=(N/A)
[java] NOTE: We are unable to locate the function name symbol for the
error
[java] just occurred. Please refer to release documentation for
possi
ble
[java] reason and solutions.
[java] Current Java thread:
[java] "main" prio=7 tid=000662a0 nid=1 lwp_id=-1 runnable
[0x00000000..0x7
fffe728]
[java] Dynamic libraries:
[java] /opt/java1.4/jre/bin/IA64N/java
[java] text:0x00001000-0x000119d0 data:0x00012000-0x00012648
[java] /usr/lib/hpux32/libpthread.so.1
[java] text:0xc008d000-0xc011fcb0 data:0x7efef000-0x7eff1508
[java] /opt/java1.4/jre/lib/IA64N/server/libjvm.so
[java] text:0xc490f000-0xc58b4cd0 data:0x7ed00000-0x7ef36b78
[java] /usr/lib/hpux32/libdl.so.1
[java] text:0xc039f000-0xc03a1660 data:0x7efec000-0x7efec068
[java] /usr/lib/hpux32/libc.so.1
[java] text:0xc0120000-0xc039e300 data:0x7efb0000-0x7efc10f8
[java] /usr/lib/hpux32/libm.so.1
[java] text:0xc0521000-0xc0686ba0 data:0x7efcf000-0x7efcf5d8
[java] /usr/lib/hpux32/librt.so.1
[java] text:0xc1c76000-0xc1c7c1f0 data:0x7efcc000-0x7efcc1a8
[java] /usr/lib/hpux32/libuca.so.1
[java] text:0xc10a4000-0xc10abaf0 data:0x7efcb000-0x7efcb150
[java] /usr/lib/hpux32/libunwind.so.1
[java] text:0xc105d000-0xc10a3470 data:0x7efc9000-0x7efca1f0
[java] /usr/lib/hpux32/libcl.so.1
[java] text:0xc1c7d000-0xc1c7d304 data:0x7efc8000-0x7efc8018
[java] /usr/lib/hpux32/libCsup.so.1
[java] text:0xc082f000-0xc08760f0 data:0x7efa9000-0x7efafbe8
[java] /usr/lib/hpux32/libIO77.so.1
[java] text:0xc22fd000-0xc2399410 data:0x7ef9c000-0x7efa6918
[java] /opt/java1.4/jre/lib/IA64N/native_threads/libhpi.so
[java] text:0xc23db000-0xc23f6d80 data:0x7ef96000-0x7ef97880
[java] /opt/java1.4/jre/lib/IA64N/libverify.so
[java] text:0xc23a6000-0xc23c4a10 data:0x7ef92000-0x7ef930a8
[java] /opt/java1.4/jre/lib/IA64N/libjava.so
[java] text:0xc23f7000-0xc243e630 data:0x7ef8d000-0x7ef913b0
[java] /opt/java1.4/jre/lib/IA64N/libzip.so
[java] text:0xc243f000-0xc246d180 data:0x7ef87000-0x7ef88880
[java] /opt/java1.4/jre/lib/IA64N/libnet.so
[java] text:0xc2ec6000-0xc2ee8f60 data:0x7ef86000-0x7ef866b8
[java] /usr/lib/hpux32/libnm.so
[java] text:0xc10ac000-0xc10cb3a0 data:0x7ef83000-0x7ef83458
[java] /opt/java1.4/jre/lib/IA64N/libnio.so
[java] text:0xc08bb000-0xc08c6d20 data:0x7ef82000-0x7ef82488
[java]
/home/sharan/eclipseTest/eclipse-testing/test-eclipse/eclips e/config
uration/org.eclipse.osgi/bundles/107/1/.cp/libswt-motif-3314 .so
[java] text:0xc7562000-0xc765a4f0 data:0x7ef58000-0x7ef5caa0
[java] /usr/lib/hpux32/libXm.so.1
[java] text:0xc9625000-0xc9a192b0 data:0x7ec00000-0x7ec332d0
[java] /usr/lib/hpux32/libXext.so.1
[java] text:0xc9a1a000-0xc9a4d410 data:0x7ef37000-0x7ef37b38
[java] /usr/lib/hpux32/libXt.so.1
[java] text:0xc9561000-0xc9624820 data:0x7ef39000-0x7ef3faf0
[java] /usr/lib/hpux32/X11R6/libSM.so.1
[java] text:0xc27ed000-0xc2800db0 data:0x7ef38000-0x7ef38df0
[java] /usr/lib/hpux32/X11R6/libICE.so.1
[java] text:0xc2f72000-0xc2fa1b00 data:0x7ecfc000-0x7ecff7c0
[java] /usr/lib/hpux32/libX11.so.1
[java] text:0xc765b000-0xc7881180 data:0x7ef40000-0x7ef4f7e8
[java] /usr/lib/hpux32/libXp.so.1
[java] text:0xc27d9000-0xc27ecfc0 data:0x7ef5d000-0x7ef5d770
[java] /usr/lib/hpux32/libXtst.so.1
[java] text:0xc0d3a000-0xc0d46f30 data:0x7ef81000-0x7ef81370
[java]
uration/org.eclipse.osgi/bundles/45/1/.cp/os/hpux/ia64_32/li blocalfile_1_0_0.so
[java] text:0xc0d47000-0xc0d497c0 data:0x7ece7000-0x7ece7080
[java] /usr/lib/hpux32/libnss_dns.so.1
[java] text:0xc0cb9000-0xc0cc6f00 data:0x7ece6000-0x7ece6370
[java] Heap at VM Abort:
[java] Heap
[java] def new generation total 21184K, used 16673K [66800000,
67ef0000,
6bd50000)
[java] eden space 18880K, 76% used [66800000, 676086f0, 67a70000)
[java] from space 2304K, 100% used [67cb0000, 67ef0000, 67ef0000)
[java] to space 2304K, 0% used [67a70000, 67a70000, 67cb0000)
[java] tenured generation total 46828K, used 29306K [6bd50000,
6eb0b000,
76800000)
[java] the space 46828K, 62% used [6bd50000, 6d9eead0, 6d9eec00,
6eb0b0
00)
[java] compacting perm gen total 34816K, used 34622K [76800000,
78a00000,
7a800000)
[java] the space 34816K, 99% used [76800000, 789cf858, 789cfa00,
78a000
00)
[java] Local Time = Mon Jun 18 18:08:18 2007
[java] Elapsed Time = 1183
[java] #
[java] # HotSpot Virtual Machine Error : 11
[java] # Please report this error to HP customer support.
[java] #
[java] # Java VM: Java HotSpot(TM) Server VM (1.4.2
1.4.2.03-040402-00:47-I
A64N IA64 mixed mode)
[java] #
[java] # An error report file has been saved as hs_err_pid28421.log.
[java] # Please refer to the file for further information.
[java] #
[java] Unhandled signal occurred at 0x200000007ac20721
[java] Java Result: 6
cleanup:
run:
collect:
[junitreport] [Fatal Error] :-1:-1: Premature end of file.
[junitreport] The file
ipse/org.eclipse.pde.ui.tests.AllPDETests.xml is not a valid XML document.
It is
possibly corrupted.
[copy] Copying 1 file to
/home/sharan/eclipseTest/eclipse-testing/results/x
ml
genHtml:
[style] Transforming into
/home/sharan/eclipseTest/eclipse-testing/results/h
tml
[style] Processing
/home/sharan/eclipseTest/eclipse-testing/results/xml/org.
eclipse.pde.ui.tests_hpux.motif.ia64_32.xml to
testing/results/html/org.eclipse.pde.ui.tests_hpux.motif.ia6 4_32.html
[style] Loading stylesheet
/home/sharan/eclipseTest/eclipse-testing/JUNIT.XS
L
BUILD SUCCESSFUL
BUILD SUCCESSFUL
Total time: 23 minutes 1 second
swt
Buildfile: test.xml
swt:
init:
runtests:
junit:
setup:
setup-zip:
ipse
installTestPlugins:
source*/*
configureTeamTest:
init:
suite:
core-test:
eclipse-test:
[echo] Running ${class-tests}
[java] !SESSION 2007-06-19 12:17:54.211
org.eclipse.test.coretestapplicat
ion
er,${class-tests}.xml -testPluginName org.eclipse.swt.tests -className
${class-t
ests}
cation -dev bin -data
pse/swt_sniff_folder
UnitResultFormatter,${class-tests}.xml -testPluginName
assName ${class-tests} -os hpux -ws motif -arch ia64_32 -consolelog
[java] !ENTRY org.eclipse.osgi 2 0 2007-06-19 12:18:14.085
not r
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-19 12:18:14.085
[java] !SUBENTRY 2 org.eclipse.jdt.apt.ui 2 0 2007-06-19 12:18:14.086
0).
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-19 12:18:14.086
[java] !SUBENTRY 2 org.eclipse.jdt.junit4.runtime 2 0 2007-06-19
12:18:14.0
86
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-19 12:18:14.087
[java] !SUBENTRY 2 org.eclipse.jdt.apt.core 2 0 2007-06-19
12:18:14.087
SE-1.5
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-19 12:18:14.088
not res
olved.
[java] !SUBENTRY 2 org.junit4 2 0 2007-06-19 12:18:14.088
SE-1.5
[java] Class not found "${class-tests}"
[java] Java Result: 2
cleanup:
run:
collect:
ml
genHtml:
tml
[style] Processing
eclipse.swt.tests_hpux.motif.ia64_32.xml to
ting/results/html/org.eclipse.swt.tests_hpux.motif.ia64_32.h tml
L
BUILD SUCCESSFUL
BUILD SUCCESSFUL
Total time: 2 minutes 19 seconds
jfacedatabinding
Buildfile: test.xml
jfacedatabinding:
init:
runtests:
junit:
setup:
setup-zip:
ipse
installTestPlugins:
source*/*
configureTeamTest:
init:
suite:
core-test:
eclipse-test:
[echo] Running org.eclipse.jface.tests.databinding.BindingTestSuite
[java] !SESSION 2007-06-20 12:52:37.046
ion
er,org.eclipse.jface.tests.databinding.BindingTestSuite.xml
eclipse.jface.tests.databinding -className
indingTestSuite
pse/databinding_sniff_folder
nit.XMLJUnitResultFormatter,org.eclipse.jface.tests.databind ing.BindingTestSuite
xml -testPluginName org.eclipse.jface.tests.databinding -className
org.eclipse.
jface.tests.databinding.BindingTestSuite -os hpux -ws motif -arch ia64_32
-conso
lelog
[java] !ENTRY org.eclipse.osgi 2 0 2007-06-20 12:53:08.952
not r
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-20 12:53:08.952
[java] !SUBENTRY 2 org.eclipse.jdt.apt.ui 2 0 2007-06-20 12:53:08.953
0).
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-20 12:53:08.953
[java] !SUBENTRY 2 org.eclipse.jdt.junit4.runtime 2 0 2007-06-20
12:53:08.9
54
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-20 12:53:08.954
[java] !SUBENTRY 2 org.eclipse.jdt.apt.core 2 0 2007-06-20
12:53:08.955
SE-1.5
[java] !SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-20 12:53:08.955
not res
olved.
[java] !SUBENTRY 2 org.junit4 2 0 2007-06-20 12:53:08.956
SE-1.5
[java] Ignoring disabled test:
org.eclipse.jface.tests.databinding.scenario
s.BindingScenariosTestSuite.null
[java] SIGBUS 10* bus error
[java] si_signo [10]: SIGBUS 10* bus error
[java] si_code [1]: BUS_ADRALN [addr: 0x3bfa2d]
[java] Aborting...
[java] An unexpected exception has been detected in native code
outside the
VM.
[java] Unexpected Signal : 10 occurred at PC=0xC76AAFD0
[java] Function=XSaveContext
[java] Library=/usr/lib/hpux32/libX11.so.1
[java] "main" prio=6 tid=0004dae0 nid=1 lwp_id=-1 runnable
[0x7fffd000..0x7
fffe6f8]
[java] at
org.eclipse.swt.internal.motif.OS._XtAppCreateShell(Native Me
thod)
[java] at
org.eclipse.swt.internal.motif.OS.XtAppCreateShell(OS.java:3 7
01)
[java] at org.eclipse.swt.graphics.Device.init(Device.java:668)
[java] at org.eclipse.swt.widgets.Display.init(Display.java:1948)
[java] at org.eclipse.swt.graphics.Device.<init>(Device.java:189)
[java] - locked <6c2aff68> (a java.lang.Object)
[java] at org.eclipse.swt.widgets.Display.<init>(Display.java:406)
[java] at org.eclipse.swt.widgets.Display.<init>(Display.java:398)
[java] at
org.eclipse.swt.widgets.Display.getDefault(Display.java:1328 )
[java] - locked <76fcade8> (a java.lang.Class)
[java] at
org.eclipse.jface.tests.databinding.scenarios.BindingScenari o
sTestSuite$1.setUp(BindingScenariosTestSuite.java:51)
[java] at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
[java] at
junit.framework.TestResult.runProtected(TestResult.java:124)
[java] at junit.extensions.TestSetup.run(TestSetup.java:25)
[java] at junit.framework.TestSuite.runTest(TestSuite.java:230)
[java] at junit.framework.TestSuite.run(TestSuite.java:225)
[java] at
org.eclipse.test.EclipseTestRunner.run(EclipseTestRunner.jav a
:327)
[java] at
:201)
[java] at
org.eclipse.test.CoreTestApplication.runTests(CoreTestApplic a
tion.java:35)
[java] at
org.eclipse.test.CoreTestApplication.run(CoreTestApplication .
java:31)
[java] at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl a
tformActivator.java:78)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .
runApplication(EclipseAppLauncher.java:104)
[java] at
start(EclipseAppLauncher.java:74)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS t
arter.java:348)
[java] at
arter.java:165)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[java] at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce s
sorImpl.java:39)
[java] at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe t
hodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:324)
[java] at
org.eclipse.core.launcher.Main.invokeFramework(Main.java:341 )
[java] at org.eclipse.core.launcher.Main.basicRun(Main.java:285)
[java] at org.eclipse.core.launcher.Main.run(Main.java:987)
[java] at org.eclipse.core.launcher.Main.main(Main.java:962)
[java]
[java] text:0xc28a9000-0xc28bcdb0 data:0x7ef38000-0x7ef38df0
[java] text:0xc27e6000-0xc27f9fc0 data:0x7ef5d000-0x7ef5d770
[java] text:0xc27d9000-0xc27e5f30 data:0x7ef81000-0x7ef81370
[java] Heap
[java] def new generation total 12288K, used 6141K [66800000,
67550000,
6bd50000)
[java] eden space 10944K, 48% used [66800000, 66d3c8e0, 672b0000)
[java] from space 1344K, 57% used [672b0000, 67372c68, 67400000)
[java] to space 1344K, 0% used [67400000, 67400000, 67550000)
[java] tenured generation total 27328K, used 7102K [6bd50000,
6d800000,
76800000)
[java] the space 27328K, 25% used [6bd50000, 6c43f9c8, 6c43fa00,
6d8000
00)
[java] compacting perm gen total 16384K, used 8699K [76800000,
77800000,
7a800000)
[java] the space 16384K, 53% used [76800000, 7707edd0, 7707ee00,
778000
00)
[java] Local Time = Wed Jun 20 12:53:28 2007
[java] Elapsed Time = 58
[java] #
[java] # The exception above was detected in native code outside the
VM
[java] #
[java] #
[java] # An error report file has been saved as hs_err_pid4476.log.
[java] #
[java] Unhandled signal occurred at 0x60000000c76aafd0
cleanup:
run:
collect:
ipse/org.eclipse.jface.tests.databinding.BindingTestSuite.xm l is not a
valid XML
document. It is possibly corrupted.
ml
genHtml:
tml
[style] Processing
eclipse.jface.tests.databinding_hpux.motif.ia64_32.xml to
st/eclipse-testing/results/html/org.eclipse.jface.tests.data binding_hpux.motif.i
a64_32.html
L
BUILD SUCCESSFUL
Re: Eclipse automated tests failing [message #46728 is a reply to message #46702] Mon, 25 June 2007 08:22 Go to previous message
Originally posted by: alex_blewitt.yahoo.com
This isn't the right forum. Try eclipse.platform instead.
Alex.
Previous Topic:Board Meeting Minutes
Next Topic:Eclipse Summit Europe CFP
Current Time: Thu Jul 17 22:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.11684 seconds
