Home » Eclipse Projects » Plugin Development Environment (PDE) » Access Restrictions - How to get rid of them?
Access Restrictions - How to get rid of them? [message #46681] Thu, 12 February 2009 09:11 Go to next message
Using Ganymede 3.4, I have several plugins, one (A) of them generates
Access Restriction on classes from another plugin (B). A has a depency to B.
I am looking for a structured way to synchronize the PDE environment
accross all my plugins.
What I understand Access Restrictions come from mismatches in JRE's or
explicitly set restrictions. From what I can see in my manifest files in
each plugin I don't have discrepancies in JRE's or explicit restrictions
set.
So in other words, What's the list of items I need to check, when
encountering Access Restrictions?
Thanks! Christophe
Re: Access Restrictions - How to get rid of them? [message #46729 is a reply to message #46681] Thu, 12 February 2009 11:16 Go to previous messageGo to next message
Check the bundle that exports the package that contains the class you
are referring to.
If the bundle exports the package with x-internal:=true then you get
Access warnings for using things in that package. If it specifies
x-friends, only the listed friends are allowed to use it.
To get rid of the warning, the x-internal must be removed (making the
package API), or your bundle needs to be added as a friend.
-Andrew
Christophe Bouhier wrote:
> to B.
> set.
> Thanks! Christophe
Re: Access Restrictions - How to get rid of them? [message #46748 is a reply to message #46729] Thu, 12 February 2009 17:38 Go to previous messageGo to next message
> are referring to.
Thank you for responding. What you write is also what i gathered from
the documentation.The x-internal is not set by default, and it's not in
my Manifest.MF, still I get the Access Restrictions which is weird?
> -Andrew
Re: Access Restrictions - How to get rid of them? [message #46827 is a reply to message #46748] Fri, 13 February 2009 10:27 Go to previous message
Are you seeing the warnings in the workspace of in a headless build?
Maybe you are using classes in packages that you don't have a
Require-Bundle or Import-Package for? This could happen by using
something from a transitive dependency that you haven't explicitly declared.
In the workspace this would normally result in a Forbidden Access error
(but that can be changed to warning or turned off). In a headless build
there isn't the same flexibility with warnings/errors and the forbidden
access can only be reported as a warning (since it is an osgi thing and
not java.
Forbidden errors/warnings are Bad because you probably won't be able to
load those classes at runtime because of how the class loaders are wired
together. (Discouraged warnings mean you can load the classes unless
osgi was running in strict mode).
-Andrew
>> are referring to.
>> -Andrew
Re: Access Restrictions - How to get rid of them? [message #591920 is a reply to message #46681] Thu, 12 February 2009 11:16 Go to previous message
are referring to.
-Andrew
> to B.
> set.
> Thanks! Christophe
Re: Access Restrictions - How to get rid of them? [message #591923 is a reply to message #46729] Thu, 12 February 2009 17:38 Go to previous message
> are referring to.
> -Andrew
Re: Access Restrictions - How to get rid of them? [message #591946 is a reply to message #46748] Fri, 13 February 2009 10:27 Go to previous message
not java.
-Andrew
>> are referring to.
>> -Andrew
Previous Topic:Open an read XML file trough popup-menu
Next Topic:Settings folder
Current Time: Tue Dec 02 01:39:47 EST 2025
Powered by FUDForum. Page generated in 0.05204 seconds
