Home » Archived » XML Schema Definition (XSD) » Unique Particle Attribution
Unique Particle Attribution [message #46630] Wed, 02 June 2004 06:44 Go to next message
Hey folks,
is there a simple way of checking wether a schema violates this rule or not?
Thanks for your answers in advance
greets Joachim Lusiardi
Re: Unique Particle Attribution [message #46650 is a reply to message #46630] Wed, 02 June 2004 06:54 Go to previous messageGo to next message
--------------574DD4982E3CFB6498A84D5F
Content-Type: text/plain; charset=us-ascii
Joachim,
The XSD model does validate this rule. The sample in org.eclipse.xsd.test/test
supports
xsd-test.bat -validate <*.xsd>
that will produce messages for all the problems in the schema. You can also
call validate() programmatically on an XSDComplexTypeDefinition to just check
it. You can even call XSDParticle.getDFA to look at the state machine itself.
Joachim Lusiardi wrote:
> Hey folks,
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Joachim,
<p>The XSD model does validate this rule.&nbsp;&nbsp; The sample in org.eclipse.xsd.test/test
supports
<blockquote>xsd-test.bat -validate&nbsp; &lt;*.xsd></blockquote>
that will produce messages for all the problems in the schema.&nbsp; You
can also call validate() programmatically on an XSDComplexTypeDefinition
to just check it.&nbsp; You can even call XSDParticle.getDFA to look at
<br>&nbsp;
<p>Joachim Lusiardi wrote:
<blockquote TYPE=CITE>Hey folks,
<br>is there a simple way of checking wether a schema violates this rule
or not?
<br>Thanks for your answers in advance
<br>greets Joachim Lusiardi</blockquote>
</html>
--------------574DD4982E3CFB6498A84D5F--
Re: Unique Particle Attribution [message #46667 is a reply to message #46650] Wed, 02 June 2004 07:58 Go to previous messageGo to next message
Ok this works, i get diagnotic messages from a schema via
schema.validate();
EList diags = schema.getAllDiagnostics();
but in this EList all message appear twice. what do i do wrong?
greets joachim
Ed Merks wrote:
> Joachim,
> org.eclipse.xsd.test/test supports
> also call validate() programmatically on an XSDComplexTypeDefinition to
> just check it. You can even call XSDParticle.getDFA to look at the
>> Hey folks,
>> or not?
Re: Unique Particle Attribution [message #46682 is a reply to message #46667] Wed, 02 June 2004 08:11 Go to previous messageGo to next message
Joachim,
That's not what I see. Can you provide more details?
> schema.validate();
> greets joachim
> Ed Merks wrote:
> > Joachim,
> >> Hey folks,
> >> or not?
Re: Unique Particle Attribution [message #46751 is a reply to message #46682] Wed, 02 June 2004 08:15 Go to previous messageGo to next message
ok i have the following XSD:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.w3.org/2001/XMLSchema
file:/home/shing19m/bin/Exchanger%20XML%20Editor/types/XML%2 0Schema/Validation/XMLSchema.xsd ">
Definition eines Elements mit Verweis auf den SimpleType
<xs:element name="Name" type="MyComplexType" />
Definition eines simplen Typs
<xs:complexType name="MyComplexType">
<!--minOccurs="2" maxOccurs="3"-->
<xs:sequence>
<xs:element name="a" type="xs:string" />
<xs:choice minOccurs="1" maxOccurs="2">
<xs:sequence>
<xs:element name="b" type="xs:string" />
<xs:element name="f" type="xs:string" />
</xs:sequence>
<xs:sequence>
<xs:element name="d" type="xs:string" />
</xs:sequence>
<xs:sequence>
<xs:element name="t3" type="xs:byte" />
</xs:sequence>
</xs:choice>
</xs:sequence>
<xs:attribute name="att" type="xs:string" />
</xs:complexType>
</xs:schema>
and the following code here:
private void validateSchema(XSDSchema schema) {
schema.validate();
int count = diags.size();
for (int i = 0; i < count; i++) {
XSDDiagnostic diag = (XSDDiagnostic) diags.get(i);
System.out.println(i
+ diag.getMessage()
+ diag.getLocation()
+ diag.getLine()
+ diag.getColumn()
+ diag.getAnnotationURI());
if i call the code i get as result these 2 lines:
0 XSD: The element '#b' may not overlap with another element ll1.xsd 15
4 null
1 XSD: The element '#b' may not overlap with another element ll1.xsd 15
4 null
the XSDDiagnostic Objects are not equal (hashvalue different)
tell me what details you need and i will try to get them.
greets joachim
Ed Merks wrote:
> Joachim,
>> schema.validate();
>>greets joachim
>>Ed Merks wrote:
>>>Joachim,
>>>>Hey folks,
>>>>or not?
Re: Unique Particle Attribution [message #46786 is a reply to message #46751] Wed, 02 June 2004 09:46 Go to previous message
Joachim,
Each "b" overlaps with the other "b". It's hard to give good locations for these errors because
by using model group references or element references, it's possible that none of the stuff that
causes a problem actually appears nested in the complex type but rather is only referenced and
appears elsewhere.
> <xs:sequence>
> <xs:sequence>
> </xs:sequence>
> <xs:sequence>
> </xs:sequence>
> <xs:sequence>
> </xs:sequence>
> </xs:choice>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> schema.validate();
> + diag.getMessage()
> + diag.getLine()
> + diag.getColumn()
> 4 null
> 4 null
> greets joachim
> Ed Merks wrote:
> > Joachim,
> >> schema.validate();
> >>greets joachim
> >>Ed Merks wrote:
> >>>Joachim,
> >>>>Hey folks,
> >>>>or not?
Re: Unique Particle Attribution [message #587957 is a reply to message #46630] Wed, 02 June 2004 06:54 Go to previous message
Joachim,
supports
> Hey folks,
<html>
Joachim,
supports
<br>&nbsp;
or not?
</html>
Re: Unique Particle Attribution [message #587967 is a reply to message #46650] Wed, 02 June 2004 07:58 Go to previous message
schema.validate();
greets joachim
Ed Merks wrote:
> Joachim,
>> Hey folks,
>> or not?
Re: Unique Particle Attribution [message #587978 is a reply to message #46667] Wed, 02 June 2004 08:11 Go to previous message
Joachim,
> schema.validate();
> greets joachim
> Ed Merks wrote:
> > Joachim,
> >> Hey folks,
> >> or not?
Re: Unique Particle Attribution [message #587985 is a reply to message #46682] Wed, 02 June 2004 08:15 Go to previous message
<xs:sequence>
<xs:sequence>
</xs:sequence>
<xs:sequence>
</xs:sequence>
<xs:sequence>
</xs:sequence>
</xs:choice>
</xs:sequence>
</xs:complexType>
</xs:schema>
schema.validate();
+ diag.getMessage()
+ diag.getLine()
+ diag.getColumn()
4 null
4 null
greets joachim
Ed Merks wrote:
> Joachim,
>> schema.validate();
>>greets joachim
>>Ed Merks wrote:
>>>Joachim,
>>>>Hey folks,
>>>>or not?
Re: Unique Particle Attribution [message #587994 is a reply to message #46751] Wed, 02 June 2004 09:46 Go to previous message
Joachim,
appears elsewhere.
> <xs:sequence>
> <xs:sequence>
> </xs:sequence>
> <xs:sequence>
> </xs:sequence>
> <xs:sequence>
> </xs:sequence>
> </xs:choice>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> schema.validate();
> + diag.getMessage()
> + diag.getLine()
> + diag.getColumn()
> 4 null
> 4 null
> greets joachim
> Ed Merks wrote:
> > Joachim,
> >> schema.validate();
> >>greets joachim
> >>Ed Merks wrote:
> >>>Joachim,
> >>>>Hey folks,
> >>>>or not?
Previous Topic:Unique Particle Attribution
Next Topic:xsd plugin directory structure
Current Time: Tue Nov 18 21:43:01 EST 2025
Powered by FUDForum. Page generated in 0.05262 seconds
