| Number of references and details does not show up [message #46539] | Wed, 14 December 2005 10:41  |  |
| Eclipse User  |  |  |  |  | Originally posted by: dh-discuss.antivir.de
 I'm having a problem when searching for memory leaks using the TPTP 4.1.0.
 In the "Object References" table the "Number of References" and
 "Details" columns are allways empty.
 This is what I do:
 Start the application (a workflow server) with profiling switched off.
 It needs to be switched off until the client has connect to the server
 as connecting fails if profiling is on.
 The application appears in the Profiling Monitor.
 Start Profiling.
 Use the client to send a request to the server and let the server do its
 work.
 In the Profiling Monitor right click on the application entry and select
 "Collect Object References". Then again right click on the application
 entry and select "Open With > Object References".
 The "Object References" tab opens/updates with the columns "Show
 Referenced By", "Package", "Size (bytes)", "Number of References" and
 "Details".
 The table body shows class names, package names and sizes but no
 reference counts nor details and the rows do not start with a [+] to
 expand sub trees.
 Here are the settings of the profiling set:
 In the "Overview" tab:
 Profiling Types
 [x] Memory Analysis
 [x] Basic Memory Analysis
 with [x] Collect instance level information
 [x] Time Analysis
 [x] Execution Time Analysis
 with [x] Collect boundary classes excluded by the filter set
 Boundary class depth [1]
 (*) Show execution flow graphical details
 Filter Set
 Class		Method Name	Rule
 myPackage.*	*		INCLUDE
 *		*		EXCLUDE
 In the "Limits" tab:
 Checked nothing.
 Would be very glad if somebody could tell me what I might been missing.
 Dirk
| Re: Number of references and details does not show up [message #49915 is a reply to message #46566] | Tue, 10 January 2006 15:54  |  |
| Eclipse User  |  |  |  |  | Originally posted by: david.lowe.airplaynetwork.com
 I'm having much the same problem but unfortunately without your success.
 I've enabled very verbose/full profile criteria (as per your description,
 for example), including instrumentation of object instances.  I've viewed
 object references a variety of ways, including right clicking "Collect
 Object References", and Open With -> Object Reference, but my object
 reference window never contains a tree and the "Number of References"
 column is always blank.
 The "Show Reference By" column contains only class names (there is never a
 '+' or tree indicator I can find), the 'Package' and 'Size' columns are
 always populated.  The 'Number of References' and 'Details' columns are
 always blank.  I can't seem to figure out how drill down to see where the
 instances are actually being allocated.
 In Eclipse help, e.g.:
 http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. tptp.platform.doc.user/tasks/tefilter.htm
 There is a page entitled 'Object References table' with an example tree
 structure in the "Show Reference By" column.  What am I missing in order
 to enable that view?
 I'm using Eclipse 3.1.0 with TPTP 4.1.0 and JDK 1.5.0_04.
FUDForum. Page generated in 0.04059 seconds
