| eclipse don't want to work on my Kubuntu [message #46458] |
Thu, 21 June 2007 05:48  |
Originally posted by: massimiliano.pasqualoni.it
Hy everybody!
My Eclipse wan't to start! :-(
I've setup eclipse 3.2.2 following these instructions:
https://help.ubuntu.com/community/EclipseIDE
but wen I try to start it, eclipse show me an error.
This is the log file:
"!ENTRY system.bundle 4 0 2007-06-21 11:30:32.828
!MESSAGE FrameworkEvent.ERROR
!STACK 0
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(File.java:1345)
at java.io.File.createTempFile(File.java:1434)
at org.eclipse.osgi.storagemanager.StorageManager.createTempFil e(StorageManager.java:720)
at org.eclipse.osgi.storagemanager.StorageManager.getOutputStre am(StorageManager.java:782)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveBundle Datas(BaseStorage.java:493)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveAllDat a(BaseStorage.java:386)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.access$1(B aseStorage.java:376)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage$StateSaver .run(BaseStorage.java:1095)
at java.lang.Thread.run(Thread.java:595)
!ENTRY system.bundle 4 0 2007-06-21 11:30:32.849
!STACK 0
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveStateD ata(BaseStorage.java:543)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveAllDat a(BaseStorage.java:387)
!ENTRY system.bundle 4 0 2007-06-21 11:30:32.850
!STACK 0
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.frameworkS top(BaseStorage.java:763)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStop(BaseA daptor.java:273)
at org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.stop(SystemBundleActivator.java:64)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1032)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1028)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.s uspendAllBundles(StartLevelManager.java:650)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:599)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:283)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:256)
at org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:190)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:546)
at org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:449)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:423)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:193)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY system.bundle 4 0 2007-06-21 11:30:32.853
!STACK 0
Some ideas???
Thanks!!!
/home/maddmax/siganture
| Re: eclipse don't want to work on my Kubuntu [message #46515 is a reply to message #46488] |
Thu, 21 June 2007 07:28  |
Well, I'm sorry!
Thank you for suggestion, bye!
On Thu, 21 Jun 2007 06:43:55 -0400, Ed Merks wrote:
> Massimiliano,
> This newsgroup is for discussing the operations of the Eclipse
> organization itself, not for technical questions. Please use
> news://news.eclipse.org/eclipse.newcomer or
> news://news.eclipse.org/eclipse.platform for technical questions.
> Massimiliano PASQUALONI wrote:
>> Hy everybody!
>> !STACK 0
>> !STACK 0
>> !STACK 0
>> at java.security.AccessController.doPrivileged(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> !STACK 0
>> Some ideas???
>> Thanks!!!
FUDForum. Page generated in 0.03478 seconds
