Home » Eclipse Projects » Subversive » PDE Fetch using SVN
| PDE Fetch using SVN [message #46456] |
Fri, 15 May 2009 04:48  |
Originally posted by: mickael.istria.openwide.fr
I am trying to set up a PDE build that fetches source SVN. I've seen
that Subversive is able to do it (bug 227115), but I couldn't find any
documentation about how to use it...
Is there a wiki page or something like that that details requirements
and usage? What should a SVN fetch line look like in my product.map file?
Thanks in advance for your help
Mickael
| Re: PDE Fetch using SVN [message #46519 is a reply to message #46456] |
Fri, 15 May 2009 06:18   |
I thought I searched well before asking the mailing-list, but I forgot
googling "+subversive pde fetch" =>
http://dev.eclipse.org/newslists/news.eclipse.technology.sub versive/msg00384.html
Then I tried what was descibed in the message, and got the following
result while trying to fetch a plugin:
#map file
plugin@org.eclipse.jwt.we.model.owl=SVN,url= svn://svn.forge.objectweb.org/svnroot/scarbo,tag=trunk,path= tools/owl-model
#result
FetchFromCVS:
[CVS - path=tools/owl-model] rsh: Could not resolve hostname url=svn:
Name or service not known
[CVS - path=tools/owl-model] cvs [export aborted]: end of file from
server (consult above messages if any)
I have subversive 0.7.8.I20090506 installed on a Galileo m6, and svn
binaries are in my path.
Does anyone have an idea of the meaning and reason of this error?
By the I started a wiki page for Subversive, you can find it at
http://wiki.eclipse.org/Subversive. I'll try to report there my
experience to write a basic user documentation of PDE SVN fetch
Mickael
| Re: PDE Fetch using SVN [message #46547 is a reply to message #46519] |
Fri, 15 May 2009 10:22   |
Hello Mickael,
I suppose that you didn't install 'org.eclipse.team.svn.pde.build' plugin in
Eclipse where you run PDE build (this is because you have FetchFromCVS
instead of FetchFromSVN). You can install it from following update site:
http://download.eclipse.org/technology/subversive/0.7/pde-up date-site/,
unfortunately it is not published on Subversive site and so you probably
didn't find it.
Note that you don't necessary should have Subversive SVN Team Provider and
SVN Connectors to be installed in eclipse where you run PDE buid, you just
need 'org.eclipse.team.svn.pde.build' plugin.
Also there was a request from a user to add features/fix bugs related to SVN
Fetch, for more details please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=273230, probably you'll need
some of the fuctionality from there, but I didn't yet propogate latest
changes to pde update site.
It would be great if you create a wiki page about PDE SVN Fetch,
unfortunately we don't have detailed info about it now. If it's possible
please add this wiki page to 'Subversive' category, e.g.
http://wiki.eclipse.org/Subversive_New_and_Noteworthy or
http://wiki.eclipse.org/Subversive_Plan, as a result we'll have all
Subversive related pages list when we click on 'Subversive' category or go
to it by url: http://wiki.eclipse.org/Category:Subversive; if you experience
any problems with it, I can help/do it.
>> I am trying to set up a PDE build that fetches source SVN. I've seen that
>> Is there a wiki page or something like that that details requirements and
> #map file
> #result
> FetchFromCVS:
> [CVS - path=tools/owl-model] rsh: Could not resolve hostname url=svn: Name
> [CVS - path=tools/owl-model] cvs [export aborted]: end of file from server
> http://wiki.eclipse.org/Subversive. I'll try to report there my experience
> Best regards,
> Mickael
| Re: PDE Fetch using SVN [message #46742 is a reply to message #46547] |
Fri, 15 May 2009 11:20   |
Great! Thanks a lot! It works quite well!
I created a new page http://wiki.eclipse.org/Subversive_PDE_Fetch where
I wrote some few things.
My question is now: why don't you distribute this plugin with your other
plugins? As a p2 installable unit?
This is a very useful piece of code, and people who want to use SVN in
automated build always have to deal with the pde-svn from sourceforge.
The Athena CBI from Dash project would probably prefer use your plugin
that downloading pde-svn, for licence, community and technical reasons...
This could be made a component of Subversive project, what do you think
about that?
Mickael
Igor Burilo a écrit :
> Hello Mickael,
> didn't find it.
>> #map file
>> #result
>> FetchFromCVS:
>> Best regards,
>> Mickael
| Re: PDE Fetch using SVN [message #509093 is a reply to message #508280] |
Thu, 21 January 2010 06:28  |
Hello joel,
I don't know what the problem could be, as it works on Windows it could mean
that your configuration is correct. Did you try to install Subversive PDE
from update site:
http://download.eclipse.org/technology/subversive/0.7/pde-up date-site/ (but
not just unpacking it to dropins folder)?
> Hello, Igor
> Sorry, I'm not good at english.^^;
> The related error is below as I wrote before
> fetchElement:
> [eclipse.fetch] Could not retrieve feature.xml and/or build.properties:
> java.io.IOException: java.io.IOException: cvs: not found.
> BUILD FAILED
> /home/pan/workspace/org.eclipse.nexbuild.builder/build.xml:4 9: The
> following error occurred while executing this line:
> /home/pan/app/eclipse3_4/plugins/org.eclipse.pde.build_3.4.1
> .R34x_v20081217/scripts/build.xml:23: The following error occurred while
> .R34x_v20081217/scripts/build.xml:51: The following error occurred while
> /home/pan/workspace/org.eclipse.nexbuild.builder/build/custo
> mTargets.xml:9: The following error occurred while executing this line:
> .R34x_v20081217/scripts/genericTargets.xml:44: Could not retrieve
> feature.xml or build.properties for feature nexcore.tool.feature.core.
> I think If org.eclipse.team.svn.pde.build_0.7.8.I20090525-1500.jar plugin
> is activated
> then SVN PDE build should exeute SVN Fetch not to CVS Fetch
> I copied this plugin into ECLIPSE_HOME/dropin folder
> But that wasn't even installed in OSGi when i executed PDE build
> My Platform is linux.
Current Time: Sun Nov 16 12:39:35 EST 2025
Powered by FUDForum. Page generated in 0.04493 seconds
