| looking for JBuilder event style ... ? [message #46387] |
Sat, 03 July 2004 22:59  |
Hi all,
Is there anyway that I can set the way the VE generate the event
code ? I found out the VE used inner class style, is there anyway that I
can have some thing like JBuilder and 10g style ?
| Re: looking for JBuilder event style ... ? [message #46848 is a reply to message #46387] |
Mon, 05 July 2004 00:27  |
Originally posted by: bug.off.nastyspam.com
Hi Ivan.
Correct me if I'm wrong - I haven't used JBuilder since I discovered
Eclipse, but the last version I used (7 or 8) did exactly the same as
the VE (anonymous inner classes) except that the inner class invoked a
method in the outer class.
You can do this in Eclipse pretty easily. Just add a call to a method
(that doesn't exist yet) from inside the listener's method passing the
event as a parameter, and hit control-1 to start quickfix, then select
the option that declares the method in the outer class.
That leaves you with exactly the same as what JBuilder gives you, and is
a relatively quick and painless way of doing it.
Mark
Ivan wrote:
> Hi all,
> Is there anyway that I can set the way the VE generate the event code
> ? I found out the VE used inner class style, is there anyway that I can
> Thanks
| Re: looking for JBuilder event style ... ? [message #594027 is a reply to message #46387] |
Sun, 04 July 2004 10:19  |
Hello Ivan,
Currently there isn't support for generating other event styles with the
VE. The VE should be able to parse JBuilder's event style though.
Making VE more flexible in the code styles that it generates is a
feature we're planning for future versions.
- Jeff
Ivan wrote:
> Hi all,
> Thanks
| Re: looking for JBuilder event style ... ? [message #594035 is a reply to message #46691] |
Sun, 04 July 2004 13:13  |
ohhh...... but... hey~ thanks~! good to hear bout the future plan~
Jeff Myers wrote:
> Hello Ivan,
> the VE. The VE should be able to parse JBuilder's event style though.
> - Jeff
> Ivan wrote:
>> Hi all,
>> that I can have some thing like JBuilder and 10g style ?
>> Thanks
| Re: looking for JBuilder event style ... ? [message #594113 is a reply to message #46387] |
Hi Ivan.
Mark
Ivan wrote:
> Hi all,
> Thanks
FUDForum. Page generated in 0.09145 seconds
