Home » Eclipse Projects » Plugin Development Environment (PDE) » headless build - avoid jaring of a plugin being available as directory
headless build - avoid jaring of a plugin being available as directory [message #46285] Tue, 10 February 2009 10:49 Go to next message
currently i am trying build a product using pde-headless build which
should contain plugins which should NOT be jared by the headless build ...
with no success (The plugin in question contains an embedded jetty+h2
database).
I defined my product using a *.product file which works fine already. But
i cannot manage to avoid jaring the plugin containing the embedded jetty.
Could anybody give me a hint where to set the correct switch :-) ?
Any help is appreciated,
Thomas E.-E.
Re: headless build - avoid jaring of a plugin being available as directory [message #46317 is a reply to message #46285] Tue, 10 February 2009 11:23 Go to previous messageGo to next message
Thomas Eichstädt-Engelen wrote:
> ... with no success (The plugin in question contains an embedded
> jetty+h2 database).
> But i cannot manage to avoid jaring the plugin containing the embedded
> jetty.
> Thomas E.-E.
http://eclipsesource.com/blogs/2009/01/20/tip-eclipse-bundle shape/
Does this help?
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/caniszczyk | http://twitter.com/eclipsesource
Re: headless build - avoid jaring of a plugin being available as directory [message #46445 is a reply to message #46317] Wed, 11 February 2009 02:24 Go to previous message
Hi Chris
> Does this help?
yes and no ;-)
Yes: this blog provides the "recognition algorythm" but
No: I do use Ganymede (unfortunately)
But anyhow, many thanks for this link,
Thomas E.-E.
Re: headless build - avoid jaring of a plugin being available as directory [message #591769 is a reply to message #46285] Tue, 10 February 2009 11:23 Go to previous message
> jetty+h2 database).
> jetty.
> Thomas E.-E.
Does this help?
Re: headless build - avoid jaring of a plugin being available as directory [message #591814 is a reply to message #46317] Wed, 11 February 2009 02:24 Go to previous message
Hi Chris
> Does this help?
yes and no ;-)
Thomas E.-E.
Previous Topic:How to test my plugin
Next Topic:quick fix only suggest to require bundle
Current Time: Fri Nov 07 14:15:39 EST 2025
Powered by FUDForum. Page generated in 0.04112 seconds
