| Reverse order on Bugzilla comments [message #46279] |
Mon, 31 March 2008 02:44  |
Hi there,
I am using eclipse Europa (Version: 3.3.2, Build id: M20080221-1800) with
the latest Mylyn (2.3.1.v20080312-1300) and the Bugzilla (2.20) connector.
For some bugs the ordering seems to be reversed, i.e. the last comment is
shown as description and the description as last comment. Everything in
between is also reversed. Is this a known bug?
regards
Markus
| Re: Reverse order on Bugzilla comments [message #47623 is a reply to message #46341] |
Sat, 26 April 2008 12:02  |
Originally posted by: rob.elves.eclipse.org
Markus Plail wrote:
> OK, read through it seems like a good idea to allow sorting.
> Unfortunately it is not in the 2.3 releases.
fyi, sort order will be included in the 3.0 release (June 25).
-Rob
| Re: Reverse order on Bugzilla comments [message #588768 is a reply to message #46279] |
Mon, 31 March 2008 14:45  |
eclipse@gitteundmarkus.de (Markus Plail) wrote:
> Hi there,
> regards
> Markus
What are your settings in ../userprefs.cgi for "When viewing a bug, show
comments in this order" and what Version of Bugzilla do you use.
If I remember correctly you must set this setting to "Site Default".
I saw this when I implement the patch for "Bug editor assumes comment ordering
is such that the description is always the first comment"
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=165968)
regards
Frank
| Re: Reverse order on Bugzilla comments [message #588776 is a reply to message #46310] |
Tue, 01 April 2008 04:21  |
Bugzilla version is 2.20 as mentioned above. My preference for ordering is
'Site default'.
BTW: This behaviour is not consistent. For some bugs the order is correct
and for some it is reversed.
ordering
OK, read through it seems like a good idea to allow sorting. Unfortunately
regards
Markus
FUDForum. Page generated in 0.06653 seconds
