syntax error on token(s) [message #46105] |
Sun, 03 April 2005 12:53 |
Originally posted by: majidnakit2005.gmail.com
Hi I have this code, but I got these errors in lines 12, 13 and 14
error in line 12 says :
syntax error on token(s) misplaced construct(s)
syntax error on token(s)"Invalid Character" , delete this token
syntax error , insert ";" to complete LocatVariableDecrationStatement
error in line 13 says :
syntax error on tokens, delete this token
error in line 14 says :
syntax error on tokens, Expression expected instead
1 public boolean validateUser(String username, String password)
2 {
3 boolean valid = false;
4
5 Connection con = null;
6 Statement stmt = null;
7 ResultSet rs = null;
8 try
9 {
10 con = dataSource.getConnection();
11 stmt = con.createStatement();
12 rs = stmt.executeQuery(SELECT * FROM Users +
13 WHERE username = + username +
14 + AND password = + password + );
15
16 if (rs.next())
Could you please help me.
Thank you.
FUDForum. Page generated in 0.13248 seconds
