Home » Language IDEs » Java Development Tools (JDT) » -> JFace and SWT component testing
-> JFace and SWT component testing [message #46062] Sat, 31 May 2003 17:04 Go to next message
Hi there,
I try to add automated tests to my JFace and SWT
based Plugin-Components. Therefore I would like to
know:
Q1: Can anyone give me any advice or suggestion?
Q2: How does your component testing works?
Thanks for reading,
Martin (Kersten)
Re: -> JFace and SWT component testing [message #48053 is a reply to message #46062] Tue, 03 June 2003 23:01 Go to previous messageGo to next message
Martin,
Have you seen
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/jdt- ui-home/plugins/org.eclipse.jdt.junit/index.html
I've been meaning to try it, but haven't yet had a chance. Let me know
if this helps you. Good luck,
David Saff
Martin Kersten wrote:
> Hi there,
> know:
> Thanks for reading,
> Martin (Kersten)
Re: -> JFace and SWT component testing [message #48301 is a reply to message #48053] Wed, 04 June 2003 02:28 Go to previous messageGo to next message
Hi David,
I use JUnit all the time for every method I write (test-first way).
(You may try it too, it gives you more speed and selfconfidence (my xp)).
But I am looking for ways to test SWT/JFace components. By checking the
SWT/JFace implementations
I noticed setSelection(..) and setFocus methods I think
a suitable test case would be like:
setUp: - set up environment
- set up component
- implement a test interface (package/protected)
test: Trigger the methods of the test interface or
setSelection etc.
tearDown: - tear down the component/environment
But before I try this I would like to know if someone
can shorten my voyage by providing me shortcuts ;)
Bye
Martin (Kersten)
"David Saff" <saff@mit.edu> schrieb im Newsbeitrag
news:bbjndg$q8d$3@rogue.oti.com...
> Martin,
> Have you seen
> David Saff
> > Hi there,
> > know:
> > Thanks for reading,
> > Martin (Kersten)
Re: -> JFace and SWT component testing [message #48823 is a reply to message #48301] Wed, 04 June 2003 10:45 Go to previous messageGo to next message
Martin,
I apologize for my confusion. I also am an avid Junit user, but haven't
yet used Junit on my graphical plugins, because of the need to get
components from the Workbench. The link I forwarded seemed to provide a
way to do that. Once you get the components, you're right, there's
still work to be done, and I don't know of a tool that makes it quicker.
Good luck,
David Saff
> Hi David,
Re: -> JFace and SWT component testing [message #49004 is a reply to message #48823] Wed, 04 June 2003 13:18 Go to previous messageGo to next message
Hi David,
Well I read about a Swing Testing Framework some time
ago. It head some nice features like recording events
and providing a easier Swing testing by offering
something like skripted events. So you just create
statements like: mouse.click(Component) etc.
Therefore I wondered if something like that exists in swt.
Well I will also check out some tests of the Eclipse
plugins. Maybe there are a lot of things to learn ;)
> Good luck,
Well I hope there isn't much luck involved... ;-)
Martin (Kersten)
> David Saff
> > Hi David,
xp)).
Re: -> JFace and SWT component testing [message #52211 is a reply to message #49004] Fri, 06 June 2003 23:42 Go to previous message
> Well I read about a Swing Testing Framework some time ago. It head
> some nice features like recording events and providing a easier
> Swing testing by offering something like skripted events. So you
> just create statements like: mouse.click(Component) etc.
Actually, there are several nice whitebox (or unit-test) GUI test
automation frameworks: see
http://www.superlinksoftware.com/cgi-bin/jugwiki.pl?TestingG UIs
Unfortunately there is nothing at the moment. Note that this is
probably due to neglect, not infeasibility. There is a blackbox (or
function-test) tool for SWT, Rational XDE Tester (formerly known as
RobotJ). Being blackbox, it lacks JUnit integration, but it does
demonstrate that SWT can be automated.
I'm part of a group that is attempting to extend one of the tools
listed above to handle SWT/JFace. If you'd like to learn more about
the effort, or about the issues involved, check out
http://groups.yahoo.com/group/java-gui-testing/
If you'd like to help out, please let me know.
Previous Topic:ClassPathContainer enhancement suggestion
Next Topic:[ANN] Eclipse Checkstyle v3.1 is available for download
Current Time: Sat Nov 08 17:00:32 EST 2025
Powered by FUDForum. Page generated in 0.03707 seconds
