Home » Eclipse Projects » GEF » Change the Container Size as the child size changed?
Change the Container Size as the child size changed? [message #46024] Wed, 27 November 2002 12:11 Go to next message
Originally posted by: radienssmgs2.hotmail.com
I put a label within a container using Flowlayout.
As I editing the label by putting more text in it, the location of the label
shift. Is it possible to prevent that?
Attached is the screen shot 1.jpg is the initial position, 2.jpg is the
shift position as I put more text.
Is it possible for me to change the container's size as I enter more text?
The DirectEditPolicy can get the host figure( in this case the label), but
can the directory edit policy get the container figure of the host figure?
Thank you.
  • Attachment: 1.jpg
    (Size: 24.00KB, Downloaded 106 times)
  • Attachment: 2.jpg
    (Size: 24.55KB, Downloaded 110 times)
Re: Change the Container Size as the child size changed? [message #46084 is a reply to message #46024] Wed, 27 November 2002 19:33 Go to previous message
It depends on the context of the figure and which layouts you are using.
In you example, create another Flow container that is really large, and put
the flow container from your example inside it.
Or, set your flow containers width and height to -1 using the property
sheet.
"Jack R." <radienssmgs2@hotmail.com> wrote in message
news:as2u9l$v8o$1@rogue.oti.com...
label
> Thank you.
Previous Topic:Container Highlight edit policy
Next Topic:scrolling graphical viewer
Current Time: Thu Nov 06 07:42:22 EST 2025
Powered by FUDForum. Page generated in 0.03160 seconds
