Home » Modeling » M2T (model-to-text transformation) » Acessing elements from a list
Acessing elements from a list [message #46022] Wed, 21 May 2008 10:04 Go to next message
Originally posted by: wickers.jonathan.gmail.com
I created a meta model extending ecore to add attributes to eClass. One
of my attribute is a list extending eStructuralFeature.
I created my plugin using EMF, and it worked well, and then, created my
model.
My problem is how to get my datas in the list ? How can I iterate on
this list ?
I tried this, but without any succes :
<c:iterate select "$currentClass/MappedAttribute" var=currentElem">
<c:get select "$currentElem/@hashcodeList" />
</c:iterate>
Thanks for help
Jonathan
Re: Acessing elements from a list [message #46145 is a reply to message #46022] Wed, 21 May 2008 21:03 Go to previous messageGo to next message
Jonathan:
I think I'll need more information. Here's what I think I understand:
1) You have an EClass MyEClass which extends EClass
2) You have an EClass MyEStructuralFeature which extends EStructuralFeature
3) In MyEClass there is an EReference feature [0..*] of type
MyEStructuralFeature. (I'll call this feature 'foo').
Am I right so far?
But then I start to get (really) confused (which goes with the territory
when building meta-meta models).
Assuming $c is a MyEClass instance, then JET will have no idea what to do
with the '$c/foo' or '$c/@foo' . The XPath engine has an assumption that
EStructuralFeatures are either EReferences or EAttributes. It is completely
undefined what would happen with a third kind of EStructuralFeature.
One last question? What code goes EMF generate for your new kind of feature?
Paul
Re: Acessing elements from a list [message #46343 is a reply to message #46145] Thu, 22 May 2008 10:58 Go to previous messageGo to next message
Paul Elder a écrit :
> Jonathan:
> Am I right so far?
I'm sorry, I'm not very good in English, I'll try to explain myself
better. Actually, my problem is that MyEclass has a EReference feature
[0..*] (and not a MyEStructuralFeature), and this is this list of
EReference feature which I need to get values.
Ok, thanks for the tip :)
> Paul
I'm not sure to understand what you want to say. EMF generate an Ecore
model which I use to create plug-in. I export this plug-in to ecplise to
be able to create models based on my meta model.
This is an extract from my model :
<eClassifiers xsi:type="MyEClass" name="Capability"
dbTableName="capability" equalsAttributesList="//Capability/id
//Capability/name">
The equalsAttributesList is the result of the EReference feature in
MyEClass.
I hope I've been clear this time.
Thanks for your help Paul.
Jonathan
(I think I should listened my teacher with more attention during english
classes ;))
Re: Acessing elements from a list [message #46625 is a reply to message #46343] Thu, 29 May 2008 13:24 Go to previous message
Jonathan:
I'm glad I misunderstood. This is definitely easier...
Let's assume $myEClass points to your MyEClass instance your described here:
> //Capability/name">
So, $myEClass/@name would return 'Capability' and $myEClass/@dbTableName
would return 'capability'
But, equalsAttributeList is a manifestation of an EReference, so
$myEClass/@equalsAttributesList WOULD NOT return anything.
Instead, the list is referenced as if 'equalsAttributesList' were XML child
elements $myEClass/equalsAttributesList, with each element being an entry in
the list. Typically, you'd write JET code like this:
<c:iterate select="$myEClass/equalsAttributesList" var="ea">
<%-- do something with $ea --%>
</c:iterate>
This is a case were looking at the XMI saved by EMF can be misleading. JET
is not reading the XMI! It is looking at in-memory EObjects and their
corresponding EClass's. If a feature of the EObject is delcared as an
EAttribute, you access it with @. If it is an EReference, you access it like
a 'child'.
Hope this helps.
And, your English is excellent :-)
Paul
Previous Topic:JavaDocs from JET
Next Topic:problems with jet editor and some emf/jet1 include files
Current Time: Thu Sep 18 22:34:21 EDT 2025
Powered by FUDForum. Page generated in 0.05646 seconds
