| [ODA Ecore]How to sort query [message #46006] |
Wed, 02 July 2008 04:16  |
Originally posted by: d4_g0m3z.hotmail.com
how can i sort my query? Because the order of the output given is always
changing.
Eduard.
| Re: [ODA Ecore]How to sort query [message #46071 is a reply to message #46006] |
Wed, 02 July 2008 12:02   |
--------------030306040402030302030506
Hi Eduard,
Great question. One way would be to use BIRT's sorting and filtering
mechanism for groups
( http://wiki.eclipse.org/index.php/BIRT/FAQ/Data_Access#Optim izing_Filters_.26_Sorting)
since the ODA-Ecore driver does not currently support a SORT BY feature
in the OCL query itself.
Suppose you want to find all the Writers in the object graph and print
their names. In the Wizard to form the DataSet, you would choose
"Writer" from the dropdown, your query would be
"self.oclIsKindOf(Writer)" and you would choose to report on the column
"Writer::name", as you probably expect.
For the report, you could drag the Data Set from the Data Explorer to
the report. In the Detail Row, instead of using "[Writer::name]" (see
the attached screenshot unsorted_name_report.GIF for the preview
output), you would delete the Detail row, right click and select "Insert
Group". On the Group Details wizard, you could select the item to group
on (here, "Writer::name") and the type of sorting you would like to
perform (here, "Writer::name" in ascending order). For this example,
you can take a look at the attached screenshot group_details.GIF for the
configuration in this dialog. The resulting report should consistently
look like the attached screenshot sorted_name_report.GIF, in which
duplicates are removed and writers' names appear alphabetically.
Let me know if this is what you have in mind.
Thanks.
------Tim-------
Eduard wrote:
> changing.
> Thanks:)
> Eduard.
Content-Type: image/gif;
name="unsorted_name_report.GIF"
Content-Disposition: inline;
filename="unsorted_name_report.GIF"
R0lGODlhzQH8APcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAADNAfwAAAj/ AP1Rw0eNmp9/
2/5VU8iQGsOFCx1CbPiQ4sSIFTFe/CexYseJHy16zMiRZEiNIzeeLPmvZSo/ qVIJJCiw4Exq
NXEO1GlzZ86bP30W1ElzKFCjQnsWVcqTaNOjTIMudSr1aVKqSKdCxRo1q1Wt V7eKDUsWrNmv
aKuq9bp26EFq1RxS2yY3Lke6HO3OrSsXL9y+fO8G3psXcGHBhwn/RbxYsV6/ jwdDNtx4MuOX
QwtOyzx0M2dqnjmHzjy682fQp0trTs36s2rUrluLlk2atunYuGfnrr37tu7f vIH7Dk58uPHV
vTO/5bjsFLNTzZ8vk1uSuvXq2K9rz859u/fu4L+L/w9PfvtCP5kJ9iyovmn7 nO+HxmePlP76
nffn43dffz/8/voFCOCA+RHIX4EIHqjgfwkyuKB8BjooIYQNUvigfTxtFtNf 1YTS0octMTNd
XCRyaGKJKJ6oYoosruhiizC+KGOMNLq4DUyp+Bbajjr2iBxsQPL4o5BB+ljk kEYSqWSSTCLp
5JFQLvmklFE2WeWUVlKpZWcC5SgYMyB+eA8zzFDm15lmpskYmmuqqRibb7oJ 55xy1lldKtOc
1RZXfI6lJ1uAdiVon2WlFSihfw7qp6GKFrrnoo86eiikk5JlUInUeNjEFFPc 0cQ/0kzz3F8F
xVXqUKaSqmqqrKLq6qmwrv/6qqyxtlrrrLbSKiunU6DKa64b/licsMcBOayx xb6mrG3ENous
s8sm9+y00QoHLbPUYlvtsdsmS1uOJYIZJoin1GjujOieq66JKKTrLopTtIRe NfH+M6+KqTSD
YXv8Wtjvvv4GDPDA+/1bsMAHE2zwwggzrHDDED8sccIUO1xxxBdP7PBmflSj CjWwZPpPDDfA
cEM1JZ98yschs0yNyzCD/LLMMbdM88025zyzze3WvPPP7eoc9M8wo6CzzzXX +w+nH/Z6dEHB
Xin1llhWPXWWWFtN9dVaZ83111uH7bXYQ3ZporggJtRSKOu2/a6L7a4bN7tv u31QmFPUiGei
iDL/2nekfFPaaOCSDu634H9XSvjihxeeuOFtdWyzhySTTM0Nlp8iNAqcs8y5 0dQEjcLHPd/c
ruich/z56CB/rnrooXMONOyrky47LKu//LnnqbO+Ou6fE42z0kvjLDw1UXd7 rbTKZ8u8ttA/
L721zlPf/PXRW589t9giX5Aq1cCCSkIJLUT+P6G8HH7r3xttdFyjg44C/OCH DAv88+N+f+iq
gI47/+FzX8/8Z6r+ia59+qNfAP+nuwQWZH5Bq8bp1je/761vf9QgHnrUZ78C rg95+vKPhSaE
IRKKsIQjTCEKV3jCFgqoQix84YVcGCEV0hCGN5yhDE24QxvOh2Mem1kf//zi AxzQhS6o+JgS
YUe62AXvdLSb2RJLtzooNpGKTMziFGeGRSxeMXed013/lBg/Mi7xjBkc1xTQ yEao5ahrcATb
2OYYR7LJsY50vKMe7cjHPE7DbOtTxfgY4gMfVAMMYEBfIFtXv/i1LID9w10k iQa6STbSc5Z0
3yVpBklGQrKSoJTkIoEnQdiprpRNrN/PlDaFu9nraKOEWp4axzjA0fKWtsyl 4nC5S11CrpfA
/KUwH0fMmqBHibAYYi7GQY0ibuMLYKCGKJBJOlhUs2f/G6MYX2ZNbmLzm6Hr pvu8Gc5qmrGc
6BynKrL5P6OZU4xlhOc6x9jNeb6sXlOwJj65Sf9NfnITFsnbnremxz2CDlR7 Bl0eQhdaUIYe
tKEQfehD36hEVFCDHN3YBg4MCYYvbKMPUtymNoOXSi1KkXW2GyBJnSjS2KUS pbmzXUp9JzsD
+k53T+RiSJfYyl4p0Q+tbGMbARpCixkVY0fVGFKXqtSmZuypSYUqU6Xq1Kha lakcQ54qUqGK
PsTliHuJiyi4StatmrWsaD2rWtPK1jG29a1rNevo4ErXuJIVBXXNq133utU3 7tGPgMWjYP86
2D4WNrCETayWutQya6LCD6jow2MjO1mQ2vOy9cxsP21KUs2K1LOY3Ww9UQra 0orWpqf1Z2hV
a1rWbnWDviym4xBH29n/2raWwZQtbodZ293qlpcGeZlZ18lVVQwXoMY9bnGV m9ziIte4zl1u
dJtr3OcyF7rVlW52qUtc7lp3utjtbni/u93xale81x1ucBUaUfZK1L3wrV57 5fte+sYXewm1
r37x+xmuWvO/1AQwPwU8TwIDWLMGLnCAQ5vgBjP4wQiG8IIjTOEJW3jA9sRR D2NYQw7jcMM5
5GGHQ+zDEYP4xCZO8YdVrMMOcwy5eo3xXmVM4xnbuMY4vrGO6QrQlwT0sEBW LGINK+QgE/nI
Q/Zjl1K72ia31slMfrKUo0xl11oZyleecpZfG5PeAve3sfVymG/7ZTHn1sy8 JfOYDcLd4br5
/7xvbjOc5yznOoc3znemc57tjOc+69nPfP5zTGBCaB8X+tCGTjSiF63oRjP6 0Y6ONKQnLelK
U/rSls40pjet6U5z+tOWhpqCDzzqUpP61KZONapXrepWs/rVro41rGct61rT +ta2zjWud63r
XvP6174ONrCHbWuO7fjYOU42spet7GYz+9nOjja0py3talP72tbONrbPuuTM oBnMZ1ZzuH37
7XKLO83kPje40V1mdZs73fBu91L8YNz9CvS+97Z3fvk7X37X19/43ne+Aa5v hwbc4AXvd761
GjIUr/jhLYa4iCVeYop7OOIYn3jGK77xi2v84xwHucdDTvKRm5zEJv83tl+R bOQkt/zlRY45
y2XucprDfOY4rzkfu+3unsd7zD8ft7yHDnSiC73oSD+60tmddKaHm80fU7jA p45wglt94Fin
utSrnnWua/3fXd+62ME+FP9S9exXrepU0472tbtd7XBve9zZTve3y/3udZ+7 3fOeMZXr/O83
B7zNB5/zwBue8IIvPOJvzvOoVPHxkI+85CdP+cpb/vKYz/zjfW50p3t+3aB/ d+dDz/mmk37e
9VYNCsbF+ta7/vWwj73sZ0/72rd+Cu0a+8F1n3Cye/33vL/613fv+/ky/ISr Z7HIUc58h3ec
+anA/fOdv3zql7z5yr++9U++fexb3PvTdzH/m1femeQr/vyJByxQc7/49qP/ 8O93f/rhP2Se
ayX5AoGi/qO4//7z///+F4AAOIACWIAEeID+F33sJ3qmx4BLd3qj54CfJ4EQ 2IAFQW9RdxvJ
FzrCB3zF94EHt369R3wkOIIm2IHBF3YgeIIqWIKjYXb/soEJgwJ8V4N7d4NK 1S4KiHc4yIN6
94M+GIQ2CIRDKIQ9mFR+NyTml3urMw25Z0dN6EdPOBRRCHPsJzYiSH9aKH9b GH9eOH9cODWN
RxX4NxAo8BM0+GXtQhALqGa5dxPst4ajJ4e2pIPSF3QTWHoPSIF8qId5iIcV uHQY+CwbCEWw
kTubETwcCDuMmIhU/4gaipg7DyQ7/EeJDwSJk4gCjsiElPhEccg5idiJnQg7 TmiJBiF9KTh8
LKiKKLiCreiCLbiKHlh264R8HNETkVgTNPiGp8OGOJF7vph/ZmgTvfhA/gCM p8OE8SGH7ZIT
yfgfhpiGhhhFwuiLo4iLyCN91Zd93MeN4LeN39d94uiN4xiO5MiNSRgkS4gc mviEp+MZ7ciB
70iFnwOPTeiOiyiPmjGFmaiJ/ciIoAFGAXmJVQSQBdkuocgjWRiGX9iFYNiQ DPmQiWd/T1GG
SnGGvIgPZ2iMu3iMoQOHxmiGaEgTpzMTGEmMU0GHsCOMcbgTUHSM1ugULVkU zeiSTJiNbf8I
iH2ok34YiH8YgT25k0AJdbpRiKMxj1E0kAbJGQjJiPgYh074iP4IkJiYGS3Z lFd5iUkZRY5I
kJ8xlafYlKwYi68oi6k4i2bpimS5lrsBgxQigxoZieohjZbYkvQhh6HDhqIo O3qpjPR4lwUj
kHOZU3kJO3GZhrGTiVrJUr64g0X4mEcYmUQomUY4mZZZmZipHum4I+vIkPwY kYG3kBA5mhLp
kKYJmqi5c1rlbT5RhjypJ28YlLJ5Fnaokj9pga8JlLmJm7rZm7zZdIOoerfI fmkJi2Opigtp
nGhZlszJlsvpnGcZnSt4fPMhgwZ4nQiYndi5ndrZndy5g+AYfub/OJ7iWZ7h eZ7ad47kiZ7d
uB6bWX4cQZqnSZqiWZqpaZ/yeZ/ziZ9cspphsXqgFqCeNqACWqADioo+maBC +Zt7OJu+2aC7
+XSDyBsowCsWeqEYmqEauqEc2qEe+qEgGqIfKpbPeZwleqLSqZwpWpwsym9u aR+aF6MyOqM0
WqOYl5mUCZmXqaM4uqM5+qM+ah/vuZ9Eqp9Gmp9Iyp9FmqRdOIYLCqEPeptQ yqBSWqUK6qBU
eqURKkzBCZ1qaaIr2pxg+qUoSqZh6qUqaqb1RZ3qaZ7puZ5v6qbtKaffGKfs WadzeqflSKd7
yp5DeqRKCqhLGqhMKqiGWqhKQpFZ+qRW/8qoWhqlj7qoWDqllNqoPUeUZzqm abqpLYqmnaqp
n1qmnCqmKPqiPXqqPJqqQIqqq6qqQcqqr+qqsNp340eotjqouHqot6qruYqo /clVrLmlkVqp
w2qpwuqoyDqpxgqpjNqloEqqmSqqoRqt1Kqmo+qp0Gqt08KmcJqndvqt3hqu eDqufQqu5Nqm
eoqu5lqu4vpDtdqru+qr8DqvvFqv8kp4ikqsyXqsylqs/rqvzNqvACuphIOp 2pqt1/qs2Lqw
Ctuw0oqw02qmpmp7FFuxFnuxGJuxGruxHNuxHvuxIBuyIjuyHPueBnqyBJqy KLuyKtuyLPuy
LhuzMDuzMluzNP97s5rmpMhDsjzbsz77s0AbtEI7tERbtBd7gannFka7tEzb tE77tFAbtVLr
eqLWcGU3tVibtVq7tVzbtVBrsl4btmI7tmRbtmbbEvmaCme7tmzbtm77th2L tBl4gXBbt3Z7
t3jLtlW7H2qbt377t2bbD3DwOWMACp+TArfwD8SAAiqQuCDiD6CAuIBLsmA7 uZZ7uVlrD0yA
AjjQEvCAAikQCx/SDGrzuHaQAo2AtoCAuRyrs33LurAbu0W7DKDruIbbuf/Q D4Yge6BwCLKL
sXILJK70u8RbvCHbD5srBi1BuzGQEMwgurBXDCigvMZre3vbHq9bvdq7vRUL uSjQvP//gApw
gLj+MAoJ8bkowAhwoAKnwDmNQLucI7nvwDkqkBD2wDmFsL7bYLg30BKL27n3 iwJhMLhjsLyf
U7//EMADzLn3QMAfMr+MW7pOW7ncW8EWHHvSG7r2AAt2gAJccA+r+w/+MLgq IA0qoA2D67uG
ywUGnLrEAAPbILiMiwqN+78twb8irAkzHMGaC8M47A86rAKusLkxwAwoAMP/ QLsujMRPm7YX
/MRQHCbIO73xcAufGwOo4LjeW8AiPLgujAK+O8IIrMT/oMPUC3tmfL8I/MCc 2xJmLMaxoMbb
IMYJQcZPG7zKEcV6DMWLCwN/8A/3wAQqUAhqA8RgjLYp/A+G/6u8mltFY2DI qQt7hiwGn7vG
howC/TvJgou4lbwNjbw6Z9y013u1e1zK3Iu+kWzGHwLJLSHDX1zAIxy6YaLD vht7acy4iRu5
sfC5uPvG4xvHuBzL0Cu1FGzKxky8Yuy4xCDLiHzIXXzIhrsFqqC435sQxdAI rvwhtIu70pvJ
ZtzJlawNHezN07vJuxzB1Ay+1wy1rnvM7ky8xIC7Cdy4H4K+4Au/N+DJjAu9 i8s5vhvAMaDN
mNwS8wvA8SsFnCMGU5wCqOC+AawCfMA5MNDB0+u/n1PLd0yUoTG879zRHl3K oww1Hz3SJP3E
xVzSKJ3SsevEKt3SLj25eKy0Lz3TNP8NtyG9szWd0zpNtie90z7901HbzkA9 1ETNtMG70UWd
1EoNtDedvUv91FBdsu+KGsMbwN+rDeY7wpE8e4KL0bI3wo8nz1rNemMd1Wa9 0v5ZFK+7zI7b
wCfsxbQH1ltNe8uwxpWcuCPs1R+iw3N91n4NuDFNt/8wv3PdD3JwC4Hc17Cn uXote3VduvcL
vq6X2H9d2YDNrTs7wvkcJqQbyI39esir2LFX147rv5I72Uzw2Za92m0LtprL wqwXyIwwzgbM
OZ0r2+s7xGGswx5c22uszb/9D9J7CGPtDxR920zwxQN9ySwsuIagw9xMv6XN 2tS9tO18v1w8
Lg3MySoQC6H/ncAMTb8JEdr+sAmi69n9UAUtEQ8SnMTBfb/5e8iaUMD32wgN nLqhoMWicN5w
oL77bA+Iew9VkBCkW90GbrRHrbSfC9vandyA3ATDPL+hS9kJnNpWndCB3L+s 99ggMtyhDQ/0
LCZMoL5bfeEoMAaMncAQjrzyfOAuLrRN3cUtDiKeDcipncTl3ASIDQe1/OGb TeODO+PuPd1s
3cCHYA8BTeOb68z/AA+S3coO/t1TrOEvXuU9W7nLPMzLewiUndggnrj20AT2 7eAVfuTB/SH1
HSYc3hL3i9yNAA+oq+SNUAxxPs8SnOIp7rlMbuV8DrIszcr+q7z3Dchw0AgA nrjv/xDgN567
yQ3ESW4PCs3PoezeanPXNu67moC798Dlha7ICAy5j67QUZ7c98DP2d3nqM6x gW0QIAK//py7
g5sChLC5KcAIvK0FS+7PYI24MjzQgcw5VP7MjtzKsR4LYP290kDr7yvevX4D u/4KtA7ttp3q
1K7qmO3U1Z7tI93T2t7t7izU3h7u7pzggi3u5g7S137u6q7H3L7u7m68LP3u 8l69q87R837v
sBvj+L7vsNvu/P7vdyvUVp3kI8vbq9Pds1fWPTvw/zAKAG/g5M7qxD7pIgvn w/y8XM3jPhu5
kYy8If7wq63vbnzqI3voW0u7Xu0PctDeIO/XFAzEDE6ycP+euv4wzVIruEw8 utPd8n4d72Vc
y67evwAOC7frvbh7ydSLvmdu8v7wx2hruBU9woZwu1385ioAC9BtyEcP9UmO vOpLz7yt18ir
2m7MOU/O2+AbyFMPusPM2wXs9frL8+NusOUOxIx843CeCrQOzBocuuWdup4t 4C3RDDuPvtMu
wuZd4fHd97AwuH6g7PeLugBu7JqgvI4uDeKN+OdN5npO8R9iB5ZvB+AL+iIs +kbM9p6euHew
+X6Q+XI/96aavfPd6rVr5ITuu/cgB8C8OlzOBMEOIkzv9CY+Braf+95N6jde 4/cA4fawxuhN
5oaf0MB/4q335VBu9Y4b2rbP6G//XkWiLtqvz+5TzTGrrAmwTbtiEOZjDvgO 7uVPzuabK+Qz
L8I27+QS3OXJzdj4z/5zHuIjnP4AweTQv3/2YGwjmDBhPzg3FCpcpgLhP4Zc Ik6seI9JI4IV
DU4kaE/gQ5IlTZ5EmVLlSpYtXb6EGVPmTJo1bar0Ry2VKmo9qeVMpVATR3sS KTa5pXGg0n9K
i4JUaA8Fx6gpbj18qpCp0n4b78Hh+DUsWKlUGTbqShWeUZOgVMR6uKyR1IH/ /JFFUfduI6Z2
yaq4unDjTcKFDR9GnFjxYsYle/pRxXOaTz//3NaScxVeCrjFOKdtOjitP00H C3K5t4ogMTEP
N8NVSDpG/0gxGjmmVWo7dNiNpI0umy1Sr6YYCOG1jq0pb0JQrf3ZAfyvWPHn 0adv04iDICjq
dor/O9638Xjy5c2fR8+4505Y1PD5DPoOxXKCylH4YTJ/fqH8KPijsIqh+RzS aMCH7EPBIYUE
TPAuAF/pTz/9/vMvP6tIm282BvWCYz7tSlpGQqrqGxAk+25A6KspSiTIQRRw 2DA9GWeksUYb
GZsMslR8yvFGHxfT7UchhySySCPt0okn937S6UgnXxLvSSmnpLJKlh6LzKfH rOSSoALp6zJM
Mce8cT1V2ntvPTLXZLNNN9+cKUdVduypRzjvxDNPPbkESsmegNozUEEHJfQ8 LP8lo6xQRRdl
tNGWzEQTPkcnpbRSQuWkkxo7LeW0U0/D7LOn9wD9tFRTTxXyUC2pqawg/b57 aC+XMJxPrQyh
QjVXXSeFdEk1W4RjjJIcrMslYqxSCB4Ud2W22UUx5ZHVhEjjwqQgXRIOomKd 5bbbO0P1idT6
ttVqJJg0WZagUbxlt102VZ1syxY1EUOqvOw9BLTn5hP2nxBRiA4rZJsyRCE7 5mtNI0bgUKEW
OAxR7kNakXO3YosX6zXNJhPSRFjQcINjoE2uwq0KhJrB1S50CTImsH9GpogJ P+aTSMC37Llw
E7iivLhnn+Nkdc5oW1W52myFsw0eCVFAjYkPTSoGMH///khIaQmbpuroJuZa muKfvwZ7JXBH
3XjcmG/zSiB7ZnuoqwRNumsMZlxe+yGxOhJtI2VTDrtvvx9SVUuiSRvoaIGS Dtg1MONKYQuQ
1nJ5Ny9Hcoqtvy/HPGNJiVFBGzkQihu8qb4aCF3jDrkHNlD6JYn0A5eFB3Vz P+6NONowxx1s
aOuUtphaEyJmPi0iTKERF7X78umSRMH1+A0dTAFCAGNhUMHcr78Y3D/Lxr57 78sMGlF5vye/
fEOTjPRX89dnP7HdNZW2ffnnr2lsJoOiP3/9rwx/VaL3B2AAE6I59QnQgPp7 36YOuED5ae9+
DIRg++CVqAhWkHwE3JjVUMC2/8UgSD+cYYmsyKPB2azLgieMSQLjRxE4VGs8 mxmRMWCjEoaQ
SzGgKN7kEodCHuIkSaJ6IMdsmBicRa5IIRqRXT7XQyamJHAUVJnXFvMau6ii SAzhYEKaYcQm
dpEgGMRfffr1r7etBRYRw5DEQIEwgsgHYLgqol2oNi82MgRiL/JLIzYDizXi wB99pOMG8baw
6NiHdXg7JElOZCIWfeWOb+HYfAbSFUJy0YuXU+HgNGG0kWyGEBbiWvFwFgt/ bIIoh6PCyYyo
QTzaxZQFYUIhOiTKFMCiQ/gBUCjnwhlqqQwG0qAZ6O6ws8FUjWlws4NzvLON 5ygzBsyYTw7d
cgt/DP8zNDN74yW950Bx/UMT2wqRVbZCuSbEwl76GcNXlFeVq0wtJEuT3VLK CbKxhEUO5mSL
WEAjOgl5jS4mKUpg0hJQvPFldhs5J8L2qU3sTXB8pEFOiOo1z8HoJi3wgFVC CrRO8IDQH1YE
T0Ylh5vDVdSkjYhaYOKWrYJksW0NMclFOgIHMciUhbUpJkPqZRqNmouh1wOj UIhilH4gxXVH
DVlWSFIWgRlRqV4KWVNCRtKlUE5tU5lpvooJuZPgcIYEkYvSOKRH+uzFdXnk qmCS+FPMZdIy
DctMRzniGYPyxq6kMY09UFMXYriwajlMTl6xthuknXQ3vkHIMg7C0ud85zj/ sTpYsZpjF+hc
5TrVsWxxsrOd7ji2Xj5lK+bsByirFcs+w5MQhf5zoQ7h8SsGEop+1lk96Elv afvpz2qpuUZB
uogqx4upiGK7QUYSNzQrMq5fPBSj0Gauf4LL3UKbK0H0+Yp7fzvrdNvnVsyJ RJLabR83rwte
8lLKoSssb3odFVT1tpdR3HVvfAc12vHK175weuL47rvfN7GXv/9lE3xdlSFt jIKZYHFJDWfV
Wgk9TYSxQjCA5SveMB4rMF/pXIfWihIHbVglNlVadO4yROV4WMLkPW+rkLig zFxrJSx1iU1d
JdLWFfPE7Q3qXdKlReyAloY2bklEImdhlPDsxuR1/6tI/Go3JjDiYAoiI/Ka zDBXjIRWLvyX
5cCqZd8dQlb7cu1ggve2K7Pwjh/yHcAseeQA0jcoUkmkRuFglbVQbzA4Q0Uw z1ZKYuarCgSJ
B65k7CpZLqdjruILgkOhUlHsDA4LA5g5xWmyf6CMzRDMr7SUtuRyhQUpCQmn nbN21X5qxHpx
4XJeEBc5hUV4wPr5bOHKudlLRzDHcODo5Ko6EIkWNSlRPdve7NYhjgpZIRYm Xd3K9V2CYBQq
tEPb22q9QO4e66v+kp1duWqPrQVJOE+NClYhYjmpSFmPgJ0cSgELbsMVS6zT PiCF6Tgi1ki1
nnF8hzgPajzbFUQM/YBNvf/HPZEQX4UpmvjQPVCHYLeAjju0gXbqVhNneOcv xRCR0CRn+UkA
MeK0EcoL9KjXWgL159Qu6udMp+eiGEgDlFneBm1nKb3o9SfXFaeff3G+8xkJ mOc/N4+bgT50
82T6f0RHemJ0nnSmF8bnTYc6TeQddarT5OJVxzpMlp51rqPk6V0He6x+uCRA nXPH03I1sH7H
4dYm8V9uX/tqPGSSMd+8pceGLUAHRiJxYzy5Yf+U0YElRbVvyx+cSGzfSXL4 xKtFahGGnAi5
gxBQcHTylsn1XWBFjO8Q49QPWaMUlSZSDJkY8JVi7x8JX1CFxEOlKzOJ6+fl EMKFZDa1vztE
bR//K3rtniSiQAUHDx1SvvVDDnwQqT1mti172ADYp/8Ud5sJUB8rpPIsuf49 yhmSbm+/IFtr
LEKKIcXwS4fw8EDpd/CaWE6DmgujTJaTMxoKW5oe+o6aOkTxhS/pxgYU9p+W /wMPttiLtZgI
WekKGPmDlEnAflhA0WmNfgCEf3gHDlInf8iDkxgZnYqKQ4ijpqiCbEi7+7OU q5s+0LANI/MS
SlOJe6A0paohGAQ2qdihcKvBf2gZ6cioEOMb8PiQaaoatIApbHswEizB6tIY /FE9qVqKqQIy
hVg0lojCARQovQmYfeIEbWAYS8rCLVwQ1QipaeEEh9Ey4KkLpgoJXnsL/3/4 HAUzQk6RvmSS
HNuAMYUoBgBMiDvUKO/jNr7gw62xDOS4POsTxIziLeHqq9XgqZ5aGutBP7/A gccqwjecFKFT
mV0LDa3aMHvoF4k7CU70ElISwDD8I7XQkAhjw2dDxSUiiQoEFrNgRVDbFs4J DHuoi3zzA7g4
C0o8Qsjwk8fgHM8BHZqiwNHxMVa6QWPSj+hwNhFqRgSTDeMgPeKQRr65DpX5 DmVLCHtwAlZj
AuR4RFhSkEnkRUYBo7cDHuFhMEgCq0YMDS0jo7xDR1CLO2+6lZKwD8dCAa/B qGnJx2GbHryZ
Dxg4GOMSQA06u3JUlK+riXvAQ4WcrqkjDIawO66IRLH+iRf0skio27qNTDqG 9Mihs8SQbDrB
I8mSREJJOUmmA8mVxDmJdMmhu7qYlMmULCCa5LmWxMlLG8md3DmT9MmftMn6 CspL08milDCY
RMpam8mlZMqhDCOnNMqgyRQFksoj68mrvDGg1MqthMquZLOjBEv3Usqx5K+m NMuz/Mq0BDCx
ZEvyysq3lC+ulMu5XMu6tC+3xMvQKsu9TC+09Mu/vMvAVC+9JMxLCggAOw==
name="group_details.GIF"
filename="group_details.GIF"
R0lGODlhWQLdAvcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAABZAt0CAAj/ AKlR+0cNhsGD
CBMqXMiwocOHVCJKnEixosWLFKto3Mixo8ePIEOK1LilpMmTKFOqXMmypcuX MF3+mUmzps2b
OHPWBMSzp8+fPQ0JHUq0qNGjSJMqXcq0qdOjqqJKnUq1qtWrWKfC2sq1q9ev YMOKFRurrNmz
aNOqXcu2LTU/UwQSfEi3rt27MDDq3bt3pN+/gD/GHEy4sOHDJnUqXqwYqOOf TyNLnky5MtSs
mDNrjjq2s+fPYduKHk2aLbVUcQcWxMu6tV2+sGNHDEy7dkjEuHPrJsy4t+8/ j4MDsky8uHHi
m5Mr1wq6ufPQpaOr/Ue9uvXrU8q+TT0X4R9n4FWR/wL0p4rr83Vlq9dru737 3fDjy/9NX6fw
x8fz699vdLn/zc8FKKB0BJ5FkEAIJoggXNqhJtdqBo2CoHg8zVQFFehluNB6 HFbk3oe0ySfi
iIbVZ6JN9znG34osIvffi1gJKGNzBdZ4oII4oqYdXA8eVAU1+FRDjSoVWmje QdQhid51/6TX
4ZNUgCilXyRWaSVLJ2YJXIqQtejll0zBKGZVM5bZWY0F3ogCCgmuKRCDsZzG HYSqODMheUZe
iGSSMDTpGp94QfnklISCdOWhiGp5Ipddgunoo0KNKSlnZlb6FZoE3kiNm5uy KZCOcfKo2kHg
ORMVnuVpFNGeSfppnUGtNv8JaJ9+ItQqrNXhGhF1VFwnqEWFBssRosRWqaiJ jPoE6bJgTiqp
pdByhal0mnbK6ZvZxYlaKqMaZGeCYKmi5Kt8xkrruXsqRK6rsv6zq7u89uru rxMJa2+x+M53
LH3JBsXsvys6O2a00U4bXbWdKgjqdn50CwN449G0kUS24truuufOWq65uHYc L68fz0vvbPYG
m+/Juu3Lb7/DAexyfgKLSTC0BpdW7ZrXbtfgnKQqGK6SHtdq8XW21soxurG+ K6/SI5NcMqEo
R32Yyr+x3PLLWFsWM4wzW1ozaZpyeu3ConYHQ52k5DmRChWPK3TH6KYbtNxJ Lx1y004/LaXU
fA//RrVvVmctOGVbv9h1pV+PpqanAnEKp5w9GlQFeKleuKoKbAMN69Dswl00 xqz6KW91o8eL
t95Q9616S3/3FvjgsDtV+H+Hm5m4aAjjKOeOPB/0nTPlUYy5hsQjZJHpeOeN +nurN59S64y9
Hvv0Sc3uX+1l3t5W7jg+7qDDktepiuXFl3/Q8SInH+XyIDrvfmLQN8Yy9fRf Zn1y2M+oPVv/
+JGK/wD8nwD9l63tRM58CGyI+vjCvva9z33xk1+/6kfBodxPOfmT0f7WMoUO evCDICzg98yW
wBIab4HsaSDzHti8CNpnfhWk4AXxl8EAbfBrBgSfCU2IwhSq0DYsdJ4L/3Mi vRhSb4YAquFz
blgzyKlGd1CMohSnSMUqWvGKWMyiFrfIxS568YtgDKMYx0jGMprxjGhMoxq7 WLY1uvGNcIyj
HOdIxzra8Y54zKMerzjCPfrxj4AMpCAHSchCGvKQ2HoQIhfJyEY68pGQjKQk t9jHSVrykpjM
pCY3yckrtrGToAylKEdJylKusZKmTKUqV8nKVm4SLg3jnitnScta2vKWaUQl LnfJy1768peJ
fCIwh0nMYhpTk7o8pjKXycxm5vGTzoymNKdJTTAmU0EBzOYAt6nNbnLzm94M JzjHKc5ykvOc
5kwnOtepznay853ujCc85ynPetLznvbMJz73qf/PfvLzn/40pxShqbtUMOmg CE2oQhfK0IY6
9KEQjahEJ0rRilr0ohjNqEY3ytGOevSjIA0pRxsWxWsmyA8iTalKV8rSlrr0 pTCNqUxnStOa
HpRbUSRojmzK05769KdADapQh0pUnpIUiiZdUFGXytSmOvWpUI2qVCGKUyjq VGFTzapWt8rV
rnr1qwo9akHnlFOFogYFUzBoSnGGglhadE3UgStY50rXutr1rhatqu6umiC1 3hSlBEGBX0Eq
11SgYKGnUahc5YrXxjr2sZDlqlhzRFarInRTA2mpXDc1WCYxdqGfjaxoR0va 0spUr92rbEER
6ofDHnRN/qPOWTP7j8X/utZNaX2ta2sL2H8YVrBxxZlsYZtZ21KntcA1rXKX y9zmQnSyClNt
9xAa2uq4iTqYxWxwt1tbwXLWs7strKfYxF1uxXUK3IVra+PaWee6973wjSxq sSldrOo2uMY9
7m0Bm9/Fovc6jJXrFPbLXYKk4rfpPeyAzRvfBjv4wXOFbl/re1KEGtY6+e1u gjesYQCH979s
ze93+3tYagwYrbSFsIpXzOKhzvekFEZQe4dL2wyvl7cc9i94sZvcAe+4wySu zmnQ2uIiG/nI
MZWwjGP8poTChce33W12ydu/EtuWW8nFsGsvTGMcd9jHndrwjduK5DKb+cwb ffGCmJzYhJ41
/63F3a1vO0hbEzfMtt8F75oYPFwy8xilJo5LkH27ZzQb+tCIZqiSP8Xm3qq0 uomOtKQn/VI1
B1OWbV4ppCnN6U57GqOLlpN5B6pZOX/61KhO9UItnUNMz1jVsI61rEMa6qQ2 eda4zrWuL8pq
vsp418AOtrBZK0Vbv2XYyE62rnvN5lcr+9nQlnStGw3QagfU2ti+trazze1t e7vb4P62uMNN
7nGbm9sDZXO0183uSRebzdWMt7zn7Uxf0/ve+M43L42t7377+9+itDfAB07w gj+S3wZPuMIX
/kx4M/zhEI/4GREu8Ypb/OJWFDjGN87xjqOGIJjuuMhHDnGNk/zkKP8HOMVT zvKWxxuWwnS5
zGcu723FnOY4z/kyYR5ynfv857W0ec+BTvSil5LnRk+60lUp9KU7/emdRDrU p071SDa96ljP
uiGlrvWue12PV9fitRj39bKbnYomh+LYzw5Mtk6R7I3DGYLg/va5s52OH7/5 Fdk03riP101j
X/vdN0n3KNKdcYWnYuIH78a0647vjVMQ5KecXcoz3pHdjLzkxYZZudvd7pD/ O+IBD3i/+53s
5059uVev+noOHakOV3vkRT/5vof48lZn0tw5P/u+S75Nnfd954E/e9B/PsXt TqlB2TiFWHLR
9pWvffFxP0lAS3Hyw9c88Ys/ermTHfHRDz//9a1PSTi/HkejD7/vsS986h9y +ddX//HnH/r5
V17+078/4+G/Ra5nMf3WIn1TJnjud0jkJ3vgB36/p3nsZ3zH14AKiHsHmEVh V4DGxH9t4nnW
on0Js3tr932B93cDKHyLZ3YYmEX+Z4HENIEq2EgsyEfm14IXeH4y+EcniEUp WIO99II6WEg8
WEUr14OsdINCSEhEmHGxV4Sr9INK+EdMOEVB2ISldIRS6EdUiHZJmCOtx3pc uIVe2IVgGEDn
94RViEdkWFJZSF8htIZs2IZu+IZwGIdyOId0WId2eId4mId6uIcgpHclFXIB VIZzdIVT5HiU
lXxI5oeWVVJw4UH//yOIcHSGsDdq/fdfiFhkirhasGeJ/9BBNPhFJaiChJhu zld+l2hkmThd
VsWJ2MU9ORNG2NeDkjhWlKhFT/ZoAHaKUZWKWLVXlshYfviKYBSKFjiKOdV8 vIiGWmZdDxVi
r5WL1CVcGGVqukhRyahUY4VfrqV3JCg23kh7Hhh6Guh2EviJE1aLKMiJARZR 1MiMGEZdHLVp
1QhR1/gpuXOLbNWK6MeA24d/2Td8CWh/d2eMq6hIWvRxzHhb+BVXDFlb7riQ 3bVYEEmNhxVl
CsmQ+fiQ82iNY5g7CNlhILePA0h/bheQ3OeA+nd3s0hZBpmO76iQ4eWQMhmT niWTDlmRCf/5
YzG5kw/Zjhv5UPWYWLCnewgTYun3fQv4j/WXf8TYdQTpiy2JRR85kzeZjziJ kw2pjTZ5lVa5
kDR5kzmZlT75kw0VlDxIUtYRlfeHlEjJlPJnkinJdisZXWqJhO8IlqZ2lVvZ k3uJlRrplzyJ
kXxJlhMVlFSIXQiCmEkZfN1neuJXko+pgftnjmtWl0CojtYFmGJ5l32ZkzQZ mJ0pmJtJmBJl
liGXloPUlFo3lxNmmVjImbb1lXI2m8KVkRapZXBFm+FVm9IYkaQZUYZJmXsk mZPJfK4Jhayo
VWP5m/TYkZAoSKy5ZMeZbl+1nMzpUMH5nIH0lKk1ncp4ne5lmtr/CUjRyWje aVXjGUjnx53p
qUbsCWPnqTvg2WCeJJztWUbl6UT2eZ+Q9J78WUb+eWn/mUr5OaBglJ9RaKC5 p6B1FKCtxqCj
9IQDBKFihKBpSKGNRIUE5EH+g6Fe5KCG6KGMdJaeWB2eeEeqKZf2maAi+n7c M5X6uHnCWEax
WIAgeqEtunUemZwx+oBqlKJnZ6HxqXbECYozmqPFdo88GpL9KHoe6JieR44B yJjdB6RLd6ND
KpI0KpBIWlbZeFA3x5YouZYoCYH+aKVKJ6RBuZjTF6WgR5xwx3fj2KV9paSX dTPAd3sEGIBm
epJueXZYuqb9GHfa16dkmqefh6b8SaJE/6ml/5iBh+qjAQmXimp0aiqcThqB htqWZUqnO4VU
ciFk3Jio9Bepm6qU4meC9hmiTZqqp2p/DeipFRZFiplZjyeZURqCUJqo3heZ R5p1l9pFlNqp
EVioxhqXLUqIqIlIlVp0gbqfkPmkpzel6EeA7delBQpIRep1wUpHzSqrdQqu ALqqOAqL4vpF
2Xqus8pFLKqueeSg7hquXMSq8WqG+1mvx9ZF7YqveHev9fqs/IpI6Rqv3Rqw hQSv+AqwlPSF
DBuGDtuwXlgtE5UaVTSw7lqw6ciHGruxHNuxHvuxIJuHN/eJogKEEPuwKHuy Kpuy30SuWTph
8ylUVxQXEkuBFP9LRTELX/partuRs0CFfBZGswqCaR2EejdrsINEr4zmsz+V jDxSs1A0YCyJ
tAfLs7fItDyVjA4Ctd3ZtVSbtDw7lbKZi9aJtaXZc087tFF7tOb5tYO0r1e7 l1nJmWabUVor
tAmCMB4kjCXrtuQZtpi5mXopjYRLlQ2Zkb7pmwEmj9H2REbJOGmbt7I3Vn4r SHDLioObXnJb
lYP5laIJkxqZfMJ0e9LJtQkitVBZuX/7sktGtmAZmhGZm6Dljl1Jlc54ijFH nJGbmLojtbjl
Kd+julZotZiLl4IbutYJmlgJuhsZpixpupJamX7UrN9ahkorJzU5mq8Lu3Kr vIarmbj/i7Z4
y7ubJ61O5EVS+nzCiqSXm72bG2UTCZujWbsX2ZuXeLcjW63m27fqy4Fit745 er0wWrcx5bTj
a5Dpi33Bi3bcdKzjmKtx6qZOuquVx7Ire8EWjE8rSrwEXFP4C73l6zhs+4fX cazEWqq9Z8J+
GqodnFcuK6it28IyZcD5K5UjvIjVGoIQmMBlSo4lWb1lh7E4uKQyrFJvsU4H LKj8m6SPl5SG
6sSpaqw1qoMKe5BEXMQiRYcjK083vFe5E6cnzIHD6pbXWoMWio44WK/Vgod8 9MU5DI4bmIG8
55hTWqw1WMVZhMVOJUfZCsT3KcTCe0cBuq2yiseBfEcWq66A/3zI/crISPXC /urIXpTI57rI
kgxHCPuvkHzJdkTJC5vBGBzK1RbJk7zBrMvJYZTJ6BqyrNzKruzKMDyuxhnL b+THCurJVsxu
M0vLY2TJijejfmzLBqrKk3zFwQa0B7W7dmTIWJR4wexy6Xt0pLyzutxzW/tM G0xeAOzD37jC
E1zGHWfHo0TMzFfNWMjLYnSj2ty/Yxx8Kpx9wuxvmvqNVUrH8WxG0fmrNmvO yInOYWSh67xF
JBh90cqUvdpy4nyqCnjPsiyjzkxGcSuPZUtpNDzN7EquAf2/Z7qYAvioKJfA B42qpGuARcml
8Sy2YznR7nYgj1u62LyzGf1/Uhy92/9nkgydbwNNxmO6SDe40N0cx7W3p2tG u4Ibm6c2uumr
zA26yQJdegz4zRx90DeNbwsdxqiKrH7Egj7cqSn8mF/6vWG5uZyWu694zfa6 s6fsfm1Z0HA8
pwdb0r0X0pQazfRF1LDruRSNp/Tlz9bE1J461Wuk1TutqVH8btoou6Ip1nlN RWaNyKbM12VI
yIjU01bdzuCMjy8Z1ni90uds0ZTk16gcR1r9wO3npuZbeAg5m1oJZIyLaB/8 0uzKs6Gtr55t
i8YMbBX9ruRairMdibW9z+v22mcd22nd25/dcLrMTkncyPMatqL83KDchb/9 SLgM3NGmxdNd
n9RMy434yt7//d3g3co3B939tJ7ZnXFJd95ASK5MmsvXucvVghrhHbLiiUc5 C9umyN23Hb4M
1djBdEnm3ds32t7W/Zu53ZqY5JyzbaEEPsTgKdzSC+BtLODsTcsDTFMq7WAH Lp0Jrt0LvsEN
7kkgttl0G7oUleH0ac1JvMSRFOCzPeAWPuImzlAonlA1rrMsbZSVGd9d7EgK LsjkHd1Brk7q
jXYgrt+fC5EJSbhGbbyHK5FnhtSS6d85JOFWRM7NPd9avuVaDtkfWuHCmdq2 +5d3veTam9hl
RtZwp9QLPEk/vsz7rWvwjd+5jORj7rmauZu1mdlaeePv5bx0WS0sDkkujshx nmvI/8wkSs3c
lRjiVw5igonnZU63yxvWaS6+N9fmkvTmDXrouAbhnXzkwonZ2yXp3ovm72uT l87YK97jjVTo
nezps7bhywzmsS2Wt8nnM5nreYmbfrnqhZjEmt7iHv7LEyfrsgbqdcTgds6c yj7ojwTrkPrO
B6qOKT3rmF7kUGjrpvje2U6XHZ5xrkjYZITSNo7tp6eBVE5HzD7qyB7c6tTq mSTt/LiBENym
dnm4RZ3rniblObPog8jt7s2c2K0wmsTp9U7u7uy/3wnWiU3ikabmgU7n+8zd ZyexYDXhIpnT
fIrV1Knvk67qiz2oBqTtTNzcjl5FelzCtzTabA2r3W6UIf/v55io4l7ORqJu 3JgM13/qjx4P
Y3Ob54PZabS+1OV88zpPao4aiz/NqcgZ9Kvd5P1u8ybvpbeO9En/yMgd3N+O RzBe9b1d3TbM
z++G9baY81nvnmDvi8mdTssd8Ee/9qEt9jDIbgU/3Pk96uck98nK9yeV3rod 97HdhmZPsH6f
mDFL8WOv31I0zR16kH/feCjIapHoTFgurl9P3LRq8AviSZkVal78a270lG4F hAWVyocPSXSP
rWhv242PTTdCkPxHg/y3+k2m8VaEMOlq+5x0+eCa+eX3+vKarwL0Jo94Uo/Y MEdFUsX/KQAU
+wC0IMd/xMz/+DJ2/dRvj1WFU9H/j/zVz/1v0Ven0f3NT/6ncf6fYvzMTxCg z0u836Lt3tzC
j43aT1tuJVZ+tXzKPxAMxi39fyMA4effQD/UDBKkVnDgv1TUBjY0mPCfQYEH /xUUWFGiwosR
qaVa2PDhR4URMy7EiNJhRz8iNWpEWBGkR5o1bd7EmVPnTp49cc70GVToUKJF jR5FmlTpUqJA
ifqZMnFi0yk5p0Z0mhEiyVQtr76cWrLl2IthrwKdORZkV5Ndu15NGHeiWoZ1 Da6la9IsxbJw
1079e5cuyLByE7q165DpYsZJNTb26VbtZMmVKV+2nBnzZs2dOX/2HBr0aNGh 4ULe+XhoqqiK
n1bFefrx/0yGKReeBZz77u3EWc1yrHixIeGFHgMDLwtW4G2suj8m1qvc7O3Z dpGrRp1d+02n
23FCnRJe/Hjy5c2fR59e/Xr27d2/h+/etfefp4NClVqUtVWavpuj9QisjwaU iKICD3xuN7S+
KsvA/hRbMLDnANSLL76wkzBDwBLECsLc0qIvRO2wExGrqHhDMUUVV2SxRRdf hDFGGWdU0aeq
7CsRwdVaw5EnqPjrbyyH3IKwpfkihJAituZCrC0jJ5JMOLGWpGk2smQii6sj v1qyu432YkvL
BisU7C2ZeswxTaG8TBM/Gt+EM04556STuRd/RDNENn3Cb741dcKRuZWuKs4j Qv/nm6rQQeES
dNFBI1LUUEOLS7TQSP20tKb8DrLIokRpYpRSTtUktSgSc2StTlVXZbXVGf3k 7sZSLdSPx6Je
nDVXXXflFbU9S3TTVWGHJZZOWG3CM9dffbS1V2efhTZaEU8tCgWqisU2W21Z PLam/fKkj1qe
Uu1WWnPPRTdd7uxDod2drPUIXqGC/afdFVHYNl993yw3QFlnXTa1ZtUluGCD nz1V3qAUjuzE
gexVEd99J6Z4Rdfaxdjdu/4tVdydyAX3YJFHJnmxPeHNOCKMqUF5ZZY1Zjmn YCWmeSF8MX4Y
4op33na+jBVOFuCQvxu4ZKOPRtpUHFFWOeam5bUWaoP/GO7P4ZrrtRnrh7Pm ueti/XTZxH5D
9FgnkJNGO221bTp56qelhjtlgbm+GmuJtcbba71ZhZXqoEsNWKc+h167cMPP TdhtxV+OGe41
T/z55qzvpnxvy1cde+PMvSs7p7OfKo000UMnfXTTS0f9dNVTZ31110snnEOa mF68cadtV5xq
f7eevHfe8748eH5D/pvUwGUuOijW4mO+eeefhz566aenvnr2NiczXnfjpl3u sHU38XetM845
57uFR//VkL/NtfOfkucTtsPnp/+o2I/fjt7098d28+LVxN9NBler+hXQgD6J nfu0kyr+NfBr
6+MYqRTINvj15EcHxGAGQRWZ/9ihRn8OBKGquPKZCAKwg1Wq4Ljkp0EWGjCB J2wMA0M4wzq9
B3sjgmH4bliTC7bQh/S7Xw4XU5Afqk2ITAkgslL4sRUW0Yloe2GuaDhFirXv iJ8bSg+fuMWj
BZGLXyxZEnm4RLM1EYxnVFcU0bjGdE3QW2REHhvleC4vztGOzhIjCje1ozv2 kVdq9GMg1eTG
qu1xXmYUZCK9U0dFNnI7edzdDqvmSEpqB5CVxORSCGkcOBItk59cCiOx8pkj gpKNkDRJJ2Nl
Slbeik/2Ac95JNnKOW5Sh0LUIi11CaRx2UeGKJrlrsC3S+MdcYBNIWYyY/PK MaYIX30LW1Ko
prBh3v+kmsqc1hVVaRMqdtOb3+TgG1Fkr741TSnTjJdQrolN+qCSIttkZzwd A8uoUI6cp5Ha
1DQmt5dBbZ8wu53Tvgcz7+0zoPKEjC03ZkiENtRkvqznzSBWztw9zaK1w532 UpbPi2Y0aut0
qFHcmRB4htSkgqNnvcg3EGgSdKNvc9lLZ5fOn+lzezC96Ukbo9CPlFSnPzUO RM1np5nejmGO
S6fb0NnRxUWNqQcFKlJGesyoVjU1KRUfQ/OJVI8aFarU9CpXnapUqyqFp1gs a1r7I9Qa4TOp
MR2oP/+Z1Ny59J93xaha12RMn47SM6XU6xdJRMRlqjOwajtrX9+JnmAe9oz/ bMKVYR2btKkq
tqcWgyFIj6LZyeqKp53VYGIZGj/MFpWsdLUJP2syzLGC9lwjdS0GKzvanvyS NxTNK1TpCr5r
cja2gwTsb+sn2saStLSoHWtBj/pWvPbztMKFFmyhS7/ZFte2RNXoylq7XeSG NbUZnW6vPhve
wxEXlw4Dplstyj2AgrWm1NSubskLuODOV23VFeJ1RdVd7vKWpqZ1nG/ti8MB c9G8pkLvbdVL
VrHutqleZXCBdSVdCVOWr7RV4XHNeVrlzi6aA7WpUwVcYca8zsStQ/GJVZxi Fq/YxS0WjTYx
nBpAkRiM38Rxjh1oFKoKJbI2BnKQRYRWIRfZyOrq//GRlbxkPFqWyU+GMlOS HGUqVzk7RLZy
lrXsGCdv2ctexvKXxTxmAXaZzGdecpjRvGYvT5nNb86ymuE85ye7mc53VrKc 8bxnINuZz3+u
sJ4BPWjy+pnQh4auoBG96M4amtGPPqyiIT1pqzqa0pcGqqQxvWmHWprTn5an pkE9amJ6mtSn
pqWoUb3qTJqa1a+mpKphPetAuprWt76jrHG9azTaOrovBjaMgz1sYRebNPXl 9a507axYWs/Z
z4Z2tKUNn+ImG2FmVlaCdbxt/lXb2r1atni1zW1yB8/b396Vr5+l33K322vn Rne2ZyzNzTLL
3fe2HLzj3TF4qjYnI0bt+//wPfCu6XvfAOz3hv9d77kR3OETM/jBc+Tqrdq1 otqVa4QFSsGH
dzxfEZf4kPsd046KuKIH/ehzdfdBj7e8VSAPebgSrvKwbrWuOWVcGV2+c2HB POaPnHlXA3zy
/j61mTxHugiR/XOZzxvA3uXwxoVuTtoVMulXl5PPme6rkVvcpk3tXoghDN5U Yt3sw9s6krEN
sHGf3e1tTXu6ws0rlr/d7tiNu7nU3eS79z1FWs87EtfeMUAvPfA7HTyp/L74 vx8+WnN3fOSl
tXfJVz66ibd85tuEec13vp2c93zoPQh60Zde8E43feo3j3rVt/7zrHd97EcP e9nX/vSAt33u
9Yj/e933HvK9Bz7RaB984jNx+MVHvhKP35PlLgzgyWf1smu6WtPyhLfRxAln nw99LVNevihf
2HfDz3zu/1nPl0HuXbsH0K87V+EqU3/74drcsBnb/sTG//31n3/+79///QfA /xNA1ckTQyOO
SNGdouMoqAs4BuQumltAT2G8CaTACrycgDk/NIEvnBMx1eKq93NAo5Ipj9q+ 8pMwjzFADdww
BbQmo1uqqcOoD8w5E6QyDCQjceEoFqwdGYzBkhu7oqs+GqyzAiSjZdnAjzIo 99Oo3Oqnlqm6
lpE/qkNCIawyG5y38aLCtEPBIjS8LJQ4KxwbLPTCn9vCeaOwMYw5MCzA/y5E Q3Qrw7E5wzY8
ODWUGTYkmADEwwHUwzx0ndN4E0SitTfMkzgUmeWZtkNExERUxOeBlRPKJVyj w++wQ7WzwLtr
xMf5NkH0nEmUu7arRKS7RJwID6ABxFmLRAHiRHSpu0/kuVC0iSmgmv2wNk2s Dx9iNxjBGcmh
IcnBGQp0RRRSom87RWRhF5xTJ39bjBJcxRepHF3Em/Oxm65xRmj0u1/0iPCg oEwkQjNcGiZ8
l06Uk2Z8Rq7hDWrcl2msQGukBvFgP5ISxkG8wW50v/mbwR5UKpJzQvjLx3xs QhA0Lt/pxatx
xtuonK3hRZWiGYjRxYJcKYQcKp3pxXFKRz9swf9snMVthEN5zEGpO8KLipsH AysftDlxspm6
WUiDjJhoTEiU/B2JIkeTLMfxYUngyapqpMiagMUye0fPiUfxk6ucqjrd2sif TDl9Ekl/LLuX
7J2DNEeVlMmZ/BmajEneIR+BREidIciJ3CCcTLmc7CltRB5u9Mn3Czt/HEqz 9CcY/L7LUkqU
ZMqUPMhxLEhyTEmofMqBdCatlBTqe65HvLVh5CGNXEGObMDk8sEd/K8G0y16 mUuYlMqWVMrG
zBuG9J1olMm5zEpfvEnt0UexuciwzMjVmqt5PLkQ6y+S68x5TELUlDqrE5+I pMy6HEeqTMi6
mU2GzEWqHKq81Myt5Mz/9nNHawPMKknF7PMsT2TGdmtKu3NFD7wdWUw2WlwX NSnBpbhFZsTK
b4pIxlNHztQYv6S14QyQ4tQ75GTFlutOngRL4QvNFtqKPdtMCypFWBPP7NGg 87REQzmd+Xw1
6WQb8lS95tlJgQtDAJVDWPNPbzHQA40+eLzCBWVQVEvQtYrQ0KtPWqlQzZvQ oLJFPtzDD/XQ
EE0xCD20C9WRDGq2RVTRFWXRFk0P3pu0DW0OWzRP/HQ4G4FRSDNRMRwZ/ICB HwXSIBXSISXS
IjXSI0XSJFXSJWXSJnXSJ4VSJpUKF2EfppPR3aDRf4jSLeXSLvXSLwXTMHVS 1PufL3TQAvUh
/x8V0zVl0zZ10zfdUtSrUjLEyEEspepkOy2F0z3l0z71Uy8l0xIyU5580NSK r4rs0aj400Vl
1EZ1VDkV1IO7UtkhS+MkmVRx1EzV1E0N002JHHkp0zk80zXky85Equ9pI0Xl 1FVl1VY90j2a
Ps0hUUKb1JNJQu8ayddSVVfl1V7lVEPCvlDdtx3Nk9bCHSRsx/LUU19l1mb1 U616oxx9tFot
1oAyTDxFuGV11m3lVjENVGllNGJduObrqrWku13t1nRVVyiFVHBdNGoVTZca TCXEVqDT1nXF
13w10m+d1UET1/FDGjXV14El2B9t134FNHgF2KPB1IJ12Hzl1637V/8WEtiH tVhuZRLQiNR9
U1gWuk4bdTgbQljzG9U6TNNPG1k+69j7BFlWlNiSlcQM7byVlVnJm9ialTya xdnDu9mdPTyd
9dm421EQJVoRNdqiRdqjVdqkZdqldVoQrVOraNmppdqqnUBCddegjTfv09rK +72udTyuBVvH
+9qxzTuxNdu8K9u03Tq0ZVuJJb233dq4lVthTLx6tb66xbO9ey+yQ42jwr5S xVu9jTTFSkBz
XYqQzFvCZTIDpIwenELS5MfU5Cfn9DCmmUJk1Ud5adrOfdrP9dzQBd3RFV39 g1lUvK0mNLmh
DMrvUkzKfRuQPMxFsdratd1KBNrl2q4RTFb/3h27mXpdIERcxtWpnoXc30U5 xRVe/wreECTe
wMpd4P3Br3Kw15VemoNApHzeTDtdYhQ/j+THjLvcB/TAuNpBk7u5wd1eUwJa A1Lf9f0k462f
wIVfoGrf+n01+cXf/ozaWtxfSOzewPxfXLvfHOGZAT4p/TXgWeFPBN6lAv44 tnPghlJgA03Z
4JzgeGrfBb1g6MxgbNJfDm6fBv5gUNpgEekRZHw6PiphEA5g4ryJocFWeVxc HiPhFsakE86u
1UUKGobdzO1HsYtWHE6mEA7C53IlQ33CnGuwCHwnIk4mHa7UyMVH4IQUnVje o8wtD4biVjLi
HbYd1vVGcMni7M0t//Ds4lbr3+nkpiBEX9UVwRjGYudVS93h4jQGpS+eYuQF XE1RYvGFr3JV
YTTGY0qS4uM9yyNeUDu+4UIOJD0+Xia+VfolT/rFYEf+pEPejg5uZEzOtRce TzkOkQsmZE8W
JE22pGwz5fgFZfvcS/og5U5eZTbS2SrK09vF5VzGOjMy3gue5cl6xFr+5Te7 414eZjYL5jX+
Tz8+ZjQr5lbG0Ctu5jNLZtC0U2ae5jF7ZqwlVd/M5i+rZva8Zm/+5i3bZgLt 5lcu5y0L5zIT
S3Le2YkBxL2ZZ32pZzm5Z2yZz3OOlUKFZ5yF0DselVkBzwUt6KMQ6Bwl5HZW vvZUZ5+F0P+D
VuU21pN5PgqJXqB95mVoPtHNUeEG1L2AtugRFmWZK2mqOOnRiyMYFudNxGZE /cbii+iRlmCK
/ryUPiScjiGNVlBuNtl/LkyDilzKRdXOE2mdnjia5hylZuGXVmlPYml3dmhp /rdJZmLBhbD3
vbUOIlf5ROoSSejYqc6wvmimhoyE1hwKReeffuhxnd3BdOLMW5rDBWn1tGkh Num7huPEfI2U
JiwCeZ+Ulgwpm0+GbqapHuhvtF7Z9UbJm+vvbexg1Ou4PmumZi3ttWun9g+o durl6AilQOuv
VOt+RlOgdt23ZuzWlGu+/Em8ri3LXkG88rqK8xvYHt/GSdaV7mz/3BjsSdLr rCgTB4EIjCAS
YORsV969cW7r245C+LvcBxvetGOX0nzA+EnpXDXMOkZess4u2QU47p7RC1EJ f/Fr3l6J4ZgL
KKmLkeCkzA5v0k5nqg7a6W7N6n7t644roMTe5PI3jLbHMO5rva6OBWnv32YQ 6cCIL4nmhTYj
Ye5afOpb7LXuyYZuqttv1fZtpybXN1YepvYNAUml8v6PD6mLvyBwz1yl0ea4 0l7uml0w7Z7e
DCdn7CbMjazwJ6bw6rXWeSVvAedt50hrzd6QMZGJJCFyuGBwAW5p/21xmX1x J4TyCq/t62au
spxca21H8DZNsYPCGC9wpz6MJ1ELP/Hv/zAXCSURCzABctFOcQ5d65g17Qw9 ar0eJLPOjjKX
wOe4FC3Pc0hhqYH+lMRO8qhuaOWWb4gGFjtHFUWv7K9GbhwH8512byx9c1SM dBcHa0afFk0v
MU5P7C+Pc00q7AZX5p4O9QidaUevaFU3GU/X7VNPitDm5xWP70+P50xn9aXO dVHf9TaHdaQY
9FBecjZucjlP9F6/Mle3TmXXSTqX9MBWcXFi8UOPZ6KdZ6edZxDN9te59gEc dSWXakO3dZxl
0Ztw0fIwdxVNd+hZ90OcdEqV9lrP2nU+LMNObpf+dXo3slmPd7amdn2PMnuP JHGfd4BPK34v
pGkfd4NvXFK3Zv98L3aG3/eN9mk4j3iJFzKBD3HELniMzzSKh3Z5BxfSJfnS LfmTN/mUR/mV
h9pXj+YxKgkm/3dOOveat/mbx/mc1/md5/mepx44BPkUF3nBqVFdBqGi9zik N3pQJEJwl2yC
BxdyITOpdyKqPzV4NHWh9/eFLztqbo0n6pNVa3pCh3mOj/qv12a0LyKrJzWs j3bfHnrQJLOw
dyK6v3qX7+geh3qdi9fewurpYvsgttTujuwVrmhfhjK3d3Ott/iZ7/q6huzS hC67j27qLfzI
33TEf7KxF/Zm33usDWrMVULwYk2tjl+1/yqhHn33OlaLO9T5U9/ABzXFf2+L jHv2fO7/msur
9kLtSkN90rzH3U/MJVZeOjar3599vN9Crof3zJF9M059MPZbq3p+GOcvETzU 1LbvWEd+lH13
G2R+Ehn57rf+3jfWtKL8/5JwhXvjrm5izM4i8t80zn/0jf98Am3BxSbMG1er 6i9jBwMIaigE
Uis40CDBggkJHmSosKHCiBInUkw15R/FjBo3cuzo8SPIkCJHkixp8iRGjRYn pkqZcSU1lxT9
yCxYc6KfixJR8GzYE+FDiD4N8owI8STSpEqXMlWYs2ZPn0UXChT6E6FVqQeL bp06lOnTpmLH
ki1r9izImxFz4lTrdIrNjS0nulVosW7Zo2j38u0b8a7fwCMB/wsubPgw4pB4 Yf5dDDfmRpp0
OYYNrDcx5swZK2tOzLkz6NCikeJlK1GyRtOLb+KldtdPKtiyY9Oebbs27tu6 c/Pe7bs38N/C
gxMfbrw48uOwLypP7rw59Oe4mUuPbr069uvas3Pf7r04ZJWPG8t9XJo15Snq 17Nv7/49/Pjy
59Ovb/8+/vz69/Pv7/8/gAEKOCCBBRp4IILthbfZeE6VZp5c6JX3D4WtjXYh hhlqSFeFHXr4
IYghijgiiSWaeCKKKaq4IostukjhghU1WNBc4sWVmoSpXVThhj36+OOFLwo5 JJFFGnkkkkbG
iNOM1KDG4I0v5fjSjjCS9NNAl2mYZf9VWgL5JVUZJjkmmWWaeSaaS0rEmF2O RTnTlDNVaWFG
Q3EJVJh3Iqanl2CSNRVTemKIJqGFGnooomqu1eSTcr7JUpwszVmSnQt9tRNm fPrpF6BL9Qka
oqGKOiqpKSpqV5M1UvnoaZGeNqlDXQK1VZh4VsrlVbkm9FVUQXWVpVZ1bsoX rUT9aqyxWuF6
VZef7lUqtNFKm+iDbUUGoUqu/gWrVw/tipWwuBIFrq1VeTvrud4Wq+lEzg6b 1LpGyUturA5V
iudh0+q7L79Enkpjqm7+66S2b3VYLrjiaqlwucoKShGvWKIb1WXuvnvSupc2 q+mt6qabb78h
izxyiAObtlb/tQOrqlBrd/FoqccMQ2xvwx/Xiim9d9L6qcUXX0lxUFQddS/N OWNGMtJJ96ty
wOWlYnLBBT318qXFfisswvUSDTPM9+5sM74+NyWUvGQb3bHRiSm9Ntukmsxo yqtNNiHVRgHK
q0ZVn+tVt+la/avOs3Y6r9hikc1srn3vKnHEgxfWNuSRpykweTZCPbeOB19Z OOGcF95zWZKL
PrqSKaN8LauVR9QyrCMxe/Hrng8bu2Gk2377ikxDWl7qDmIOpezBCz888cX7 aLrvOvZOY9Su
zYk79NLGFL2Q01N/PfW6rynweb/LiT34olofvqnkmy/629Yqr3LzLp///pjj wz+i//zz28+v
9qrLCMvlErU29f0C6KL6CZBHBTxgtNLXqmttg33ekxQCI2giAh6QghK8IJny 1yan9W916cEg
CD1kQQGOMIQmfJECT6ejBsrNfxxx3wkvWML7zTCGNjyRBpk3oQ6y7IM3lGAN 5xfEHxLxQylM
HoMw0kIP0q2IBRzi+6DoxCLm0DWOUWJkmgfAKdIwhFLk4g2PKLUHwcCBLmwi GIXoxTSy0YiU
26B4WJjFB76qjWoE4RftiEfkjfFaWMwWHbelxyiucZBsrOLKIMjD5UmtScZ7 JCQjKclJloSP
BPOjGZkoHkOaL4/h8yQnK/hGHYrnad07Y+ZCCT5QYo+Vqv/sIuoWuL4l9hCN r4SeK7N3Syci
kntzRGUSdxm9XA5TmEQU4yVnGaFAosqYuCykM2PYS94tcmBOel40JUfMZ2bz hMhsFJMYmUhr
wrCbkdsm7tBpznSO0oocPKUmg7nOc0JznkC0JDjrmMlabtKekFOn7QDqT222 c5yCrOb/sDlQ
kgl0dA1dKNu++aA/SomZAIPo2h5KUIw+saBXRKgPOcrQeopUjbFUYRL3yUjn lXSke2yp/aa5
SZCelJI2vSlOc0o8fE5UpeRUKEylR9Kgkk+mVKIonCx6TaIubahMbSVPMUnL lZbzqdDSKD2t
WlSP7hCe/JSnVq/q1LCys6Z9zJz/T1lH1gSOda2kM6qMkKq+eH7PrW5rq10J atZkpnSqP83r
qLD6T8A+k5r6U6RXV7pFwhZKsG1zLGMnt9d8Lkqu21NqVSNrJshmVLNv5epM E2vNxXq2TJxV
2mlLiySJSnWZwIyras+UWqTNNrb+Au1RaZpK22YQr7xt6mR76le1/jZ+vi2u vuCK2F/SNZw6
fS50oytdMQW3tYB8LQSRu9rjapethoVjbkWb0O4eqbYjMy95UcRatA73hUBN b+64C1/x4Tau
ugXrfFuE3pDtN78iWm9fXdvcNb3XvxOUr4EbW9/l4kippE0wDhEMYdlGlb0C /ipsJ1y+l2q4
VMolsGVR/4phJnV4wxjsb4kB/L20urfE6pWwi7f7XVKGl7kjrmOMS4Tife1Y wyomMYttmWMQ
9XhaRYbwhw8q3pAOuWQwbvKQfqzP9goZygbksJUla7nDgvi+jpoumMMs5jGH rroWvu6ABZll
N2J5zaZdcJeX7Ec3H+zJdFaRlCsb5H7eWYlt7nN54axkGyu2wE0+MlsBbVwz BxjNN1ZznxEt
VkUnKcnN9DKJAS1pD1O60hVudEWxC2JN27nT9BP0peW82ztv+q6mLh2jV0xl PrO61K8mMqov
imkcR9rWtxbhp2V9YaoaesitDuyvbztjd4aW0KMtdo6PTd9kVy/YQJ71UUn9 Z/9q4znXLN31
osgs7nGTu9wZsfaUh/1XbZ+Y2yj0NmBUjV83SztU9SZvng2252z3etvujvCy DZpqZ4+X3TL8
t37RrWdsZ7jW/kY4iSyta3nXtd/thni3Y31tdRPX4gfHePkC/lGKZ9rj9wT5 izWebkcTW9H3
PtTLtSvxb5Oc1w6/OMoPrPKFc7zFBj95znUM7ykMpOaV/XkEY47cfDey6D2v cpaVTiip/3bm
FnF6g0UdbnNzvetef67C34L1UKe5mUhHINV5a3WdGN1gZxdl0IW+c30zPLsm T3rc5b5l8Nq3
7Y10ua+5zfSl7rvhdE77ZvMe8aGHGImPdvvd0a74U8///e+Ft/vNPz55XIu8 qwRn8uEDT+3B
h6Xuo4483Dfvxs43O+tl//vbO6r61a9PxBtn+bpRL/vZ15n1NXb942GvexLy HtiVJ7zpIZ15
oBe/8QDbXes3o0VHfr361r++2MJu+eSbffgBRHxs1+58vgZ/qbEnfvNhpH3k P53WoX/45MUP
bsgvH+/pH//JHH97spc/s1EXfbLJn9+Zn/d10f2RHtu1H7/Vn+QdIOPNn/Ax YOo1HwKO3zh1
nATuHgU+4AA+2P/Bn+JV4OWdXgaiX/oJ4OfNWQHG1P3hH9xYF/+13Pl9Xwui IPAVGvbloA7u
IJCsX+kpoOHRGwD+mg1Kn4NB/1uMgV9vOeDx/SDuYeD74dwG+l7fpeCqRaHm TWHt6d/KxWDu
lSANMuHe0VgV3uCzAR4I5p0Ict9FzaABniAHWuG8rZkSGpcYAo/tdWFFtA8S ulgdetodygj0
/Z4Rah39YSHzFd8aAiHmIaL9wSEVMlghvh4BguEbaiEeciHPPaHPreAdQeIY MhshJpUhNhIP
niIqpuLRNGECciLUWdkfblcgSsogluEklp8HwuIQ3toiuqL7CWEaxl0RkiIl 5iKUxWKgzeKr
zJWw+eICOmIDguKqXFb0ESMu9mGK7eKr9aIXQiEwSqEixqEZFpwnwg8yMhY3 7iFmYWOHnWOR
uCNgDf8jMxYaGoIj76VjLcpgORKSMm5LPsaZHFacJbJgP77FPOrhP3ojHWqj qcmjLBWjKkak
RE5kmW3hWYGaOpYiPLbgAYaiwE1cQFKkSI4kSZ5F/l1kM3ZjSa4kS7YkUrAJ GUqiNa6US9ak
TbbkSZLf/mUkJd6kT/6kRMKkKNriTFoTUB4lUuZgTlIW3TFiUj4lVFafUH4k zYVkVF4lVorb
UgqXU2alV37lc03lyFklWJalWUbSVsIgT5bfWbalW4qNWHreOHYHXX6HXdYl Xt6lXuYlX+6l
X/YlYP6lYAYmYQ6mYfbGC56ZFyYIYzamYz4mZEamZE4mZVamZV4mZr7HPw7/ mhm+pWd+5iMx
5fapG2iWpmlyDlXGm7OdJmu2JpiIJvvhnmvOJm1iSGq24i3Wpm7upmbAphN6 IW8Gp3D2xW3i
X2Ee52EmJ3Iup3I2J3M+p3NGJ3ROp3QKJldqBEdmJxjJ5XB2p3dmyG9+p3iO J2aoJnmeJ3oG
RnimJ3u2Z1OYp3vGp3yaxHrOp33eZzXip37uZ2zyp3/eJ3z+p4C6Z30OqIGO Z4AeqIJ+Z4Eu
qIPuZoI+qITWZoNOqIWaZoReqIaCZoVuqIeaZYZ+qIiCZYeOqIlCZYieqIom ZYmuqIvaZIq+
qIy6ZIvOqI2KZIzeqHtSDI/2qI/+KJAGqZD6qP9A/w/1jaaO7icK4A7RaeSP CCVnJil+LqnP
5MRR0EmP5OQmSul9UunFXJ2T+giUDpxIqEIh/MEfFIIqcGlteum7WGmYZumR 9udH/MGawogq
/MHTsGlruumwgGlPiumc5uiaVANGqIIqbMM/VMOe8ulp+ummwGmg9gXoLKNi dsQfGGoqaAGa
akFLVMMfOOqjYqlIIA7YvGSTTmre0I7rmMSYgqRHICpGaEEhUAiaUgiiimpp QqpS4M3NIIWk
suVGVCpHEKtBXupGFML0bIOi/sOtYoSy6upn8ipSDE29vGeqCivW7ATf3E23 hk1IvGpVesQf
iBCaWk+oSqtnUivGYIrjLP9FsNJk3gxr1xDOw4SEljYluXrIuXZIuqqrW7Kr SVjruyoFoGrr
zLSLxNDLxvyqR4groRaEsvKIFqjCwUQrwLalwFKKuzrsScSrUc4rzmiN0Izs SOQrknaErFLI
NtxpheRqxmosqYKErxqre11pu9prvfqNx7oXd2Kqof6DKlRshYBqzAbszNLs 3Zzqx2arvA5r
4nDF3nxrz+7VlnZEKqRC0GpBszLq0SKtzxzs024IxOJmnbosNeTp14LtxYBs 0mIIytLpR5gp
mqrp2rLtu4htyPZI2Y7f3bbp24qG2xZO3Nbo3/Zp4IaG3iauaPTt3h7uqFJn YTrt42pI4Zot
5PKQJgpk5oBcaXUe56Bibubq5pCWrumeLuoeBecSiFqOrutOUsS+ruxyjuHO ru3mrejeru4S
bu7uru/+ae/+rvACSe0Or/EqbvAer/KORvEur/MaRuw+r/QKRvNOr/WeRfRe r/aWRVh8rvdK
7veGL/iOr/iWL/mer/mmL3ZcxOq2r/u+L/zGr/zOL/3Wr/26R0AAADs=
name="sorted_name_report.GIF"
filename="sorted_name_report.GIF"
R0lGODlhtgHWAPcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAAC2AdYAAAj/ AKkJXPavoMF/
0pYJXMiwocOHECNKnEixosWLGKv5SYWxo8ePIEOKHEmypMmTKBkSPFhQWsKU MGPKrFitWiqO
M3Pq3Mmzp0+dp/5NGTr03zSXp34q7UmUYVOHNpdKnUq1qtWQQVkeTHpVJ4qc UwpOERhWKESb
OLuqXcu2bcqgN+Le+Cf3H1e3Ar9i1NuQb0S/HcsKFTw2Ylq8iBMrTpxVa8G7 eAFTlEyNMkrB
BgtLvLm4s+fPS+HWrQs5L4rTC0/rXZ334dfVqCurTh37tWzAtlXD3r2btu3b r2dPxKx54mHQ
yJMr/8gxVaht0KNLD0WteXUUzbFjv55q+9fu1rN//98Onrz27N3Hh7+unrt5 9O/JV57P0Xb9
6vjXE1/PXyDn5QAGKOBDz0Xngw/TOcRXcLPlNp+CvqG24IPzTQhha61ZWKFu sqVG4W8UPoSZ
WBcdN+CJKCrWXIHQHbgNGGBsQ1148dFYHnj5cacjeu7Bx6ONO54XJI40Onjf d/TlyBFhhPW3
XnUmpijllF09N84427gIo4wXVujhhxBpCOKYYH4pZpleYpghmBo6VFZhb2IU JZV01rmTKniG
Us2V1RxYDYzVhILnoKqgMKihhZ526KKEMoqnao9CGimiiEb66KWTVqpooptK 6mmmhTraqCpE
EVrqqKjiCaWdrLYq06B91P8k66zV9JHqrbjmSmiluurKa6/AhhrssLji5+qx yIo0qB99NOvs
s7YSm6pum04r7a2/XtuopNp2q8pNfiQr7rgUeWvuueimq+6wAoVL7rvwUrPu vPTWa2+w1Gw0
Z7z8TnnvvwAHTG8qG/VrMJ0CJ6zwwsQS/N/BEAPI8MQUV0yowxtljPHGGnfM 8ccehwzyyCKX
TPLJJqeM8soqt8zyyy7HDDPKFtds880456zzzjz37PPPQAct9NABR2z00Ugn rfTSTDft9NNQ
Ry311FRXbfXVWGet9dZcd+3112CHLfbYf1Fr9tlop6322my37fbbcFNL9txW oeDY3Xjnrffe
fPf/7ffffU9hGd2Ee/WP2KkIXvjiPtktth+KMy55To6Hnfjgk2cuUuVgQ465 5qB3xLlrV18e
+ukjjQ5ciB5xSJJkrsP0uUSeo277R6PjtvmXu/fFO0qzGxb57cRXlHtfwt2G IWu8L1hb8sLl
FpuavaUZvYTOVx/9g8nnO3zx4Id5OEPbr2k+89SnP+H66Dfv+/QeMk/mmbU9 ZHr4+Cs4PoTr
x++lX7GTW//Mx7rVmUZC5GvQ8oAzJg45zyG1y58E87K/9/lvTQ4y0+/YdMEC 6o6AA2TNB1mH
G7/cb4L5U10HyYSm9HEQhC1Uk/rcJ78X2vB3EUQh/nJXPu5Nr00h0h70/+pH G/IpSIER4t7y
fqg93zTkhDoEnwp/Erzl5DCKxZti4+wERSzeTotau6IXbQfGrHVxjKcrI9bE iMbQ2U1mcJxZ
HOcoxzpq7HttdCNR9sjHPvrxj4AMpCAHSchCGpKQVczj3OLGyEY68pGQfJsi J0nJSlrykpjM
pCY3yclOevKToAylKEdJylKa8pSoTKUqV8nKVrrylbCMpSxnScta2vKTgMul LnfJy1768pfA
DKYwh0nMYhrzmMi8W0PoyEw7OrOZ0HymNKNJzWlas5rYvKY2s8nNJybzm+AM pzjHSc5ymvOc
6DTIMtPJzna6853wjKc80enNedrznvjMpz73Of/OdfLznwANqEAHis96EvSg CE2oQheqS38y
9KEQjahE+WnQiVr0ogv1BxxUIwZiqCYFsfiHR1WwDZb4QxMgxWguHarSlrqU n/dgAgpwUBB7
oCClBWlGSU2K0pD+wx+qeGneKirUohrVncu4qU89StN/3MMQfCOGGI6qFZZS 9apYBWdMUTDV
fyQ1BiVlhk/zltSuZpWoWU2rWoN5UhSA1R+ogANI/TGKktoUBYyAgwpOcZpG JPU0Kf0rSf9x
17ySlKkFQexdw7DRrv4VBYNd7EZxsFWzCnanx7TqWjfL2VwmFaT3gIUmuPrU gmgUstJQgTY2
2giRcrUgSW0tMd66URX/pHYbiHUtTdtqW8huI6ZgRSxvpyHTGEjDrSWNrUjB iky0dva50L1b
ZXX6VbGadrRdPa1sX6vRwca2rWbFG3htOliDJHW32NUoSMm7je4mFwWtzSxD /BDd+tpXKx6F
AVRjqoJC7LSt8dWua6e6Vd2IAcB7G69vr3sa9HJVvbFgb4E52lyGpOK+GLbv XVsLXoMg+Kes
HTCIccrg+OZNwYMlBkjP+9P0yjXCvoVwODWb4Rqn1b2JJbGAQQzfAQfVo8xd RiN27NWZwtbI
KN4GebUxWgcf+MXsdW2QTVxM59r4ylQlRlMJW17CnibIX1ayUhNL4bsyt8hN ZfFdUyCF04hh
/6spQEVf76oCPpwGBnZwM5n1XOGF0BfLgA50Z60s6EIbuqU0PrSiFw1RQjP6 0ZAOaKIjTelK
39PRls60puk53017+tPpxDSoR01qYE661KhO9UotrOpWu3rVfj7IXd2qjbpq lMoJhgOu9XZa
am351o4B9quHHVGDqtin/F1tj/tGZL8to7xJHaywD/JhYltbof5Urofl8Fsm 7DpvMf223p6N
WZueWbrevra6EepNjZ47p90WN7rljTdyH+TY4E73uvct6U7HNLwHiSkjmnzk BjuVCYYlLodH
+9oiL/gg9jYvfIHdViOH27VIZvhUNTpwIzu8y/wOuXwXcmGbAtwgMf9dL2jT bY84n2aw4fbH
JkIa7ntUoaQ6ZUnEa4oCxk5cE1O1aSMuXgyfypzmCN+oymNhc5xjVuRQH+Y6 TT5vpzZhrJ9l
ur7DPWs3x3TLOgd5bLkOcoHr2iBdJ22673H1r0f97VVmtUbBHvC1p7usbNd6 fLn+7oN7HOIg
Pzbfn15gE9vj3RdPvEzpDvfGN7TTIiUxbIdu90bYA+Zt37q3L/90tC/bvF22 KU25LvlwLwOn
nK97ay/Oc3o7/vV4q2e1pXrw1W8+sCvfu7dPylx7vHmpAI94tEsac0009akX J4a0NdH7N1f+
HsCHvfT9xtLH9vi0KXiFTFMg2tNoQaaqGbL/0mPR69GDH+y9NrBpx9/rGBBX qZctP/a1f1P6
/336+I89q/PP/wyfuv8AmFaiFoAEaFT/V4AI+FIDmIAMaFEH2IAQWGz7F4EU qFIPWIEYSFAL
mIEc+E8X2IEgmE8bGIIkKE8fWIIo6E4jmIIseE7+NGt9N0wVpxuSd2JnF04w WGud14KWZlAa
dXLG1HJjZV18M23JhG8HB3I82IOQ12JAWExCqE/aZlrctoSb5oNAh4MpBVT2 5G6dl3NWmGkO
dVKOpRo01XLdhwNt1VQVV4YPh3ZbCAgepnEg1nG7pWto2GRryGDIdXCG1V50 WHdP2GJhxofM
JXCjhVNt6Id6tYNh/+hSWEhgLJd92wdjS3d0tdd0/wCGnmeGpjVzjKhUaLhR hVCJNnWJWch7
x7VgmMh6PPeEZNhib5WKzLeKKaV87QWKMeUHL+eIjwiJTRiLEpd7tWd1MGZg bucYUegPcuhl
yLh2mUd5trd6V5d6mahvaRdeVKeM5UV2O1Vzmmd51OJ8rveLFxWJR/Zm0ViM g8cSW8V4yxhU
hIV4z+dtijeNEfeDrHd4vjh3d5OPcCAGAEmO6ycG/Kh65khVY6gJrZV6eXeP tWeNLCF0E1mD
EsmO9piR0xiRy3Zr+6iE91aDQkaRICaOAaZrrHdrF+mKCSlU3qR82lCFUXh6 eoeRQ8Z8dv/1
e4kFcFFIbThJWAQJjtJokyflXWCVkj/pezz1ebRXlMk1i0bZbU01W4DYfCzZ ksAYa38VYAz3
fbpRiqcBlnO1URZ3fj7pidRGlmqodPZnNmCJAmJJfgxHW321fgbnGNZnYhV3 ZntJfEwgOH3I
YzPVa+WIlQ+1goJ2lYa5VidYaIq5mAI4gZlWeJDJWY1ZmZg5VJKZmZz5eLHW maAJa/4RmqRJ
fU1YmqipTJuZmqxZEJfZmouJmLBpmK85my0pm7aZkC+oGjFohAnGcMtmZr6Y m9PngwEZbCEG
OEhYUzFInPm3kE/4mHrDkkLmnAWIjo4hnSf2kz9VV9ZJgNC5YRv/dnGL+HE7 2JOlxYeSaFir
ZYfq+Z2vho73GHO6aI83t4k7eFJNZQz/VZ+8GGPjJ4StqG/wmWrQaZNcN47J +I8kxYydyFGs
l3jVOI4FqmryWY+W13fveDc/SITzSHjhGJHNWaGktpAbKZQX6XnidnpbUG5l F6LeSKKu9pKq
VYU/WGTSyHs5CX07WXVzaJUwuntJOYgyyoRaWZd75pWARX5q6Xf3pxX8aVJq SZjzV4nlV6Sl
hptYSoK1uaUhqKVe2oFdGqYcCKZkioFjeqYVaKZqGoFp2qYQyKZwyoBvOqcJ KKd2ep2nmact
6E0wmJ836GFk6XqECXFIWnBU5lFPahCK/8p4Tkp3B3k3PUmInydxgcmnFAV5 N6oVzeYPnPBe
8uapoFpTDXqDnCdsVClSjJeqWqYVj0VlXog3HsWTl0qIhYmp8CR7WZidBOpU Rmd8eMOjLYZe
8cWPJ1Wss9hVkXpdyvpuDuoYxnAKI+oPcsAH72YPvEhl9mADgYqr++RPwqgV 2tmqUTV6V1cQ
D3muxqijXgVw7LoMtFqphOVXIwqvk0pYA3duxQAL3eqtIrh/ZCiefSWdx1qE DMll/4WH5QVs
X+cPebCDDfuwXnZgwPlrcrgMzXl0m1pTlodTNrdat+qv7ASuWTifvRpw97k3 mmiNKrmwpvqG
EwmzZxlfUYqxjv9oD1MZeuKXZuIXsiLLaSTHrAh6sgZRdH1jtAiLrpvXjenm qasFkk7biLI6
ej5ls45BDMX6efbQWjRJre3Vrz87TyQridP4mNXJN2drjOjaduqadyLVVal6 b3A7ojiLcbqB
axN2l/MKYjiglL4ZtiYIsAdrsrumlL6aN4YLfQXrVbMYXzYrbF6blgFWhcqI a1arc+GFixwL
WykwBSH1t4Cbq/MFkzZ6nGN3sl0Hkg+6YMZqqrS1cL3nrEnZnJoIcRrqBCCq rLrHhmAbuu/0
RFvJqN4HfmNWcJ7IX09nfX8XvJaql3OZn887sQUWg5ertMVbYHhWiFjrcLXq uyq4p8CnJKze
u254un6OOr7DVqfo+3blu74ip77u+76rGb8ICL/0u2/te7/qZr/6e23527/E xr8AnL7zO8DP
Cb4GfMBBm8ABKMAMbKAF/MCv58ASXKIRXMFwR8EY/Gn/u8GgpsEerGkdHMJX iMAkDHUjfMJG
2i4q7Hgp3MKRBsIw/GgvPMOMJsM2rGg1nMOHhsM8XGg7/MOC5sNCDGhBXMRY RsRIbGNHvMQ1
FhAAOw==
--------------030306040402030302030506--
| Re: [ODA Ecore]How to sort query [message #46133 is a reply to message #46006] |
Wed, 02 July 2008 13:51  |
Hey Eduard,
Right now the Ecore ODA Driver only supports entering boolean OCL
queries followed by the selection of columns on the next wizard page.
One of the major enhancements we would like to do would be to support a
full OCL query that would identify columns within the query itself.
Another benefit of this feature would presumably be support for sorting
within the OCL expression.
No guarantees on if or when we'd implement this feature but it's
something we'd like to do. In the meantime, Tim's response will
hopefully help!
-jeff
Eduard wrote:
> changing.
> Thanks:)
> Eduard.
| Re: [ODA Ecore]How to sort query [message #591662 is a reply to message #46006] |
Hi Eduard,
Thanks.
------Tim-------
Eduard wrote:
> changing.
> Thanks:)
> Eduard.
FhAAOw==
| Re: [ODA Ecore]How to sort query [message #591679 is a reply to message #46006] |
Hey Eduard,
hopefully help!
-jeff
Eduard wrote:
> changing.
> Thanks:)
> Eduard.
FUDForum. Page generated in 0.06684 seconds
