Home » Language IDEs » C / C++ IDE (CDT) » Build configurations
Build configurations [message #45923] Sun, 20 October 2002 09:41 Go to next message
Originally posted by: will.ideosync.net
Is there support within Eclipse/CDT for multiple build configurations:
Release, Debug and Checked for different platforms, for instance, with
separate build options, makefiles and output directories? I've been
looking at the docs but can't find anything that might support this.
Also, has anyone tried debugging from CDT with gdb under cygwin? I'm not
having much joy - I keep getting a 'Failed Launching CDI Debugger :
Error initializing: Timedout' message, even though I can run gdb fine
from a Windows command prompt.
Thanks for any help,
Will
William Osborn
mailto:will@ideosync.net
Re: Build configurations [message #45989 is a reply to message #45923] Mon, 21 October 2002 09:30 Go to previous messageGo to next message
Will Osborn wrote:
I have had the cdt working with cygwin. You may need to update gdb, as
I believe the default version they install is too old. You need gdb
5.2.1, which should be in the gdb package dateed 20020718-1
-Peter
Re: Build configurations [message #46283 is a reply to message #45989] Tue, 22 October 2002 11:06 Go to previous messageGo to next message
"Peter Graves" <pgraves@qnx.com> wrote in message
news:3DB40158.7010303@qnx.com...
| Will Osborn wrote:
| > Hi,
Thanks Peter,
This information has been added to the CDT user's FAQ and the Wikki Web
under installing the CDT
-Judy
| -Peter
Re: Build configurations [message #46829 is a reply to message #45923] Wed, 23 October 2002 14:08 Go to previous message
Originally posted by: dschaefer.rational.com
"Will Osborn" <will@ideosync.net> wrote in message
news:3DB2B2A1.5040205@ideosync.net...
We are looking at different ways to enhance the CDT build environment to
support the concept of build configuration and plugable tools and such. For
now, you could use the Make Targets view to define different targets that
are passed to the build command. For example, defining a Make Target of
Debug and invoking the Build menu item on that target invokes "make -k
Debug"
- Doug
> Will
> William Osborn
Previous Topic:Visual c++
Next Topic:Debugger Timeout
Current Time: Mon Nov 03 12:58:13 EST 2025
Powered by FUDForum. Page generated in 0.54012 seconds
