Home » Archived » XML Schema Definition (XSD) » Base for relative schemaLocations
Base for relative schemaLocations [message #45882] Wed, 26 May 2004 10:09 Go to next message
Hi Ed and others,
I couldn't figure out -- yes, schemaLocations should be absolute -- in
the W3C specs which is the correct base URI when including/import.
./A.xsd
./bbb/B.xsd
./ccc/C.xsd
Be A the root schema including "./bbb/B.xsd" and "./ccc/C.xsd".
What is the correct import statement, if wants to see C?
"../ccc/C.xsd" (assert cwd == ./bbb/)
or
"./ccc/C.xsd"? (assert cwd == .)
Is XSDResourceImpl.XSD_TRACK_LOCATION related to this topic?
Or is this bad-style again?
Christian
Re: Base for relative schemaLocations [message #45938 is a reply to message #45882] Wed, 26 May 2004 10:15 Go to previous messageGo to next message
Christian,
From within B.xsd, you should use ../ccc/C.xsd. (The answer will be the
same as if these were .html files with href="..." in them.) The track
location thing is there just to be able to keep track of line and column
numbers for the DOM as it is created.
Christian Stein wrote:
> Hi Ed and others,
> ./A.xsd
> ./bbb/B.xsd
> ./ccc/C.xsd
> or
> Christian
Re: Base for relative schemaLocations [message #45966 is a reply to message #45938] Wed, 26 May 2004 10:29 Go to previous message
On Wed, 26 May 2004 10:15:04 -0400, Ed Merks <merks@ca.ibm.com> wrote:
> Christian,
Merci!
Re: Base for relative schemaLocations [message #587667 is a reply to message #45882] Wed, 26 May 2004 10:15 Go to previous message
Christian,
> Hi Ed and others,
> ./A.xsd
> ./bbb/B.xsd
> ./ccc/C.xsd
> or
> Christian
Re: Base for relative schemaLocations [message #587678 is a reply to message #45938] Wed, 26 May 2004 10:29 Go to previous message
> Christian,
Merci!
Previous Topic:Base for relative schemaLocations
Next Topic:Resource notifications
Current Time: Tue Nov 18 10:54:54 EST 2025
Powered by FUDForum. Page generated in 0.04264 seconds
