Home » Eclipse Projects » Technology Project and PMC » Package Explorer Pane does not refresh
Package Explorer Pane does not refresh [message #45789] Tue, 11 February 2003 23:23 Go to next message
I am running Eclipse build 200302061700. on Windows 2000. When I upgraded
to this release, I unzipped the download, and then copied my workspace file
to the default directory.
My problem is that when I add a new java project, or add a new package to an
existing project, the project / package is not shown in the Package Explorer
Pane until I shutdown eclipse and restart it.
Is this Eclipse' problem or my problem?
Also, I noticed a post that suggested that it is a bad plan to have your
workspace directory under your eclipse directory. How does one go about
having the workspace in a separate directory?
Thanks much.
Leon Webster
Re: Package Explorer Pane does not refresh [message #45821 is a reply to message #45789] Wed, 12 February 2003 06:28 Go to previous messageGo to next message
I am having a similar problem. I am using the 2.1 M5 build.
My package explorer does not synchronize with the editor view ie. selecting
another file in the editor does not move focus in the package explorer. It
worked fine in the 2.1 M4 build.
Is it a setting that I have overlooked or should I file bug?
Suggestions appriciated
Thomas Berg von Linde
"Leon Webster" <leon@leonwebster.com> wrote in message
news:b2cgp9$19q$1@rogue.oti.com...
file
an
Explorer
> Thanks much.
> Leon Webster
Re: Package Explorer Pane does not refresh [message #45851 is a reply to message #45821] Wed, 12 February 2003 07:03 Go to previous messageGo to next message
OK I found the answer in eclipse.tools.
Please see http://bugs.eclipse.org/bugs/show_bug.cgi?id=30002
Sorry for the inconvinience.
/Thomas
"Thomas Berg von Linde" <tbvl@sundhed.dk> wrote in message
news:b2d9er$i6b$1@rogue.oti.com...
selecting
> Thanks
upgraded
> file
to
> an
> Explorer
> > Thanks much.
> > Leon Webster
Re: Package Explorer Pane does not refresh [message #45881 is a reply to message #45789] Wed, 12 February 2003 09:48 Go to previous messageGo to next message
What do you mean by "not shown" (not selected or not there)?
If it is not there then you might have enabled a filter which hides the
element. If this isn't the case then please file a bug report with steps
to reproduce against JDT UI.
Dani
>Thanks much.
>Leon Webster
Re: Package Explorer Pane does not refresh [message #46033 is a reply to message #45881] Wed, 12 February 2003 19:43 Go to previous messageGo to next message
I mean that the new project is not visible in the Package Explorer Pane
until I restart Eclipse. Similarly, if I delete a project, it remains
visible until Eclipse is restarted.
I checked and enabled/disabled filters to see if that made a difference; it
didn't.
so I am off to file a bug report.
Thanks much.
Re: Package Explorer Pane does not refresh [message #46154 is a reply to message #46033] Thu, 13 February 2003 23:24 Go to previous message
Just to follow up on this for any later parties searching the newsgroup...I
believe my workspace was corrupt -- I reinstalled Eclipse and imported the
projects again, and now everything works fine.
Re: Package Explorer Pane does not refresh [message #590189 is a reply to message #45789] Wed, 12 February 2003 06:28 Go to previous message
file
an
Explorer
> Thanks much.
> Leon Webster
Re: Package Explorer Pane does not refresh [message #590215 is a reply to message #45821] Wed, 12 February 2003 07:03 Go to previous message
/Thomas
selecting
> Thanks
upgraded
> file
to
> an
> Explorer
> > Thanks much.
> > Leon Webster
Re: Package Explorer Pane does not refresh [message #590223 is a reply to message #45789] Wed, 12 February 2003 09:48 Go to previous message
Dani
>Thanks much.
>Leon Webster
Re: Package Explorer Pane does not refresh [message #590279 is a reply to message #45881] Wed, 12 February 2003 19:43 Go to previous message
didn't.
Thanks much.
Re: Package Explorer Pane does not refresh [message #590312 is a reply to message #46033] Thu, 13 February 2003 23:24 Go to previous message
Previous Topic:Eclipse 64 bit support
Next Topic:Save files twice
Current Time: Wed Dec 03 14:50:44 EST 2025
Powered by FUDForum. Page generated in 0.05501 seconds
