Home » Language IDEs » Java Development Tools (JDT) » Sources with > 127 ascii literals
Sources with > 127 ascii literals [message #45744] Sat, 31 May 2003 09:59 Go to next message
I was developing a application under WinXP that contains litarals with
greater then 127 ascii code (tipically latin words). It compiles well.
When I imported the project under Linux, there are some compiler errors
and some characters are not shown. I used another text editor (unix vi)
and that chars still there. Does anyone knows what's the problem and how
to solve it?
here some code example:
// Under WinXP
class A {
char foo(char ch) {
String str = "prêmios";
switch (ch) {
case 'á' return 'a';
case 'â' return 'a';
case 'ã' return 'a';
default: return ch;
// Under Linux
class A {
char foo(char ch) {
String str = "prmios"; // The char still there
switch (ch) {
case '' return 'a'; // Error: duplicated case
case '' return 'a';
default: return ch;
If you navigate from keyboard, it seams the char still there because you
have to type twice to move from 'm' to 'r' in "prmios".
[]'s
Gatis
Re: Sources with > 127 ascii literals [message #45988 is a reply to message #45744] Sat, 31 May 2003 15:14 Go to previous messageGo to next message
There's no such thing as a "greater than 127 ascii code". ASCII has 128
values - 0 to 127.
I suggest you work out what encoding you *actually* mean, and set the
workbench preference (under Workbench | Editors) to use the right
encoding.
Jon Skeet - <skeet@pobox.com>
http://www.pobox.com/~skeet/
If replying to the group, please do not mail me too
Re: Sources with > 127 ascii literals [message #46272 is a reply to message #45988] Sun, 01 June 2003 16:14 Go to previous message
> values - 0 to 127.
Ok, I understood.
> encoding.
Thanks, It solved my problem!
Igor Gatis
Previous Topic:which eclipse.?.? for product ideas/discussions
Next Topic:How can I foirce a stack trace on a running program within Eclipse
Current Time: Sun Nov 09 04:41:20 EST 2025
Powered by FUDForum. Page generated in 0.03385 seconds
