| Sources with > 127 ascii literals [message #45744] |
Sat, 31 May 2003 09:59  |
I was developing a application under WinXP that contains litarals with
greater then 127 ascii code (tipically latin words). It compiles well.
When I imported the project under Linux, there are some compiler errors
and some characters are not shown. I used another text editor (unix vi)
and that chars still there. Does anyone knows what's the problem and how
to solve it?
here some code example:
// Under WinXP
class A {
char foo(char ch) {
String str = "prêmios";
switch (ch) {
case 'á' return 'a';
case 'â' return 'a';
case 'ã' return 'a';
default: return ch;
// Under Linux
class A {
char foo(char ch) {
String str = "prmios"; // The char still there
switch (ch) {
case '' return 'a'; // Error: duplicated case
case '' return 'a';
default: return ch;
If you navigate from keyboard, it seams the char still there because you
have to type twice to move from 'm' to 'r' in "prmios".
[]'s
Gatis
| Re: Sources with > 127 ascii literals [message #46272 is a reply to message #45988] |
Sun, 01 June 2003 16:14  |
> There's no such thing as a "greater than 127 ascii code". ASCII has 128
> values - 0 to 127.
Ok, I understood.
> I suggest you work out what encoding you *actually* mean, and set the
> workbench preference (under Workbench | Editors) to use the right
> encoding.
> Jon Skeet - <skeet@pobox.com>
> http://www.pobox.com/~skeet/
> If replying to the group, please do not mail me too
Thanks, It solved my problem!
Igor Gatis
FUDForum. Page generated in 0.03871 seconds
