| Index generation problem [message #45741] |
Mon, 12 November 2007 08:44  |
since I enabled glossary & index to be generated few error messages
appeard on console:
No valid parameter named wwwroot
Parses directory: C:/Documents and Settings/smirarom/EPF/Publish1.0-int/
It may take a while ...
XE_Copyright reffered by the following keyword does not exist
KeyWordIndex:Copyright
SiteMap:Copyright
SearchEngine:Copyright
TreeBrowser:Copyright
XE_System_requirements reffered by the following keyword does not exist
TreeBrowser:Example
And the final index page doesn't look complete.
Can you please point me what is wrong?
Roman
| Re: Index generation problem [message #45982 is a reply to message #45913] |
Wed, 14 November 2007 13:49  |
Originally posted by: storaskar.xx.xxx.xxx
It could be just debug messages which you see in std. output. You might be
running in debug mode. If you think the index site is not generating
properly, feel free to file a bugzilla.
Shilpa
| Re: Index generation problem [message #585639 is a reply to message #45741] |
Mon, 12 November 2007 14:15  |
How and where did you get this error messages ? Is this from command-line
publishing ?
I don't think publishing thru EPF wizard will lead you this error/warning
messages.
Shilpa
| Re: Index generation problem [message #585653 is a reply to message #45834] |
Mon, 12 November 2007 14:48  |
Hi Shilpa,
I get this also via EPF wizard (launched from eclipse -> console
enabled). Any suggestion?
Roman
"Shilpa Toraskar" <storaskar@xx.xxx.xxx> wrote in message
news:13d22bf94e7517f39c879c06fc71a270$1@www.eclipse.org...
> publishing ?
> messages.
> Shilpa
| Re: Index generation problem [message #585678 is a reply to message #45889] |
Tue, 13 November 2007 13:06  |
Well it seems some sort of messages appear on stdout/stderr only - I can see
them (eg. related to publishing progress: Generating index.. Saving
index.html or something like that) in eclipse console or when publishing via
command line, I see just blank screen in case of EPF build or no appearance
in log files.
OS: Windows XP
Roman
news:a1424f28928b145530dfa7a49a9d6fb2$1@www.eclipse.org...
> Do you get these same messages when you run EPF build on the same library
> Shilpa
| Re: Index generation problem [message #585700 is a reply to message #45913] |
Shilpa
FUDForum. Page generated in 0.05289 seconds
