Home » Archived » EPF » Index generation problem
Index generation problem [message #45741] Mon, 12 November 2007 08:44 Go to next message
since I enabled glossary & index to be generated few error messages
appeard on console:
No valid parameter named wwwroot
Parses directory: C:/Documents and Settings/smirarom/EPF/Publish1.0-int/
It may take a while ...
XE_Copyright reffered by the following keyword does not exist
KeyWordIndex:Copyright
SiteMap:Copyright
SearchEngine:Copyright
TreeBrowser:Copyright
XE_System_requirements reffered by the following keyword does not exist
TreeBrowser:Example
And the final index page doesn't look complete.
Can you please point me what is wrong?
Roman
Re: Index generation problem [message #45834 is a reply to message #45741] Mon, 12 November 2007 14:15 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
How and where did you get this error messages ? Is this from command-line
publishing ?
I don't think publishing thru EPF wizard will lead you this error/warning
messages.
Shilpa
Re: Index generation problem [message #45860 is a reply to message #45834] Mon, 12 November 2007 14:48 Go to previous messageGo to next message
Hi Shilpa,
I get this also via EPF wizard (launched from eclipse -> console
enabled). Any suggestion?
Roman
"Shilpa Toraskar" <storaskar@xx.xxx.xxx> wrote in message
news:13d22bf94e7517f39c879c06fc71a270$1@www.eclipse.org...
> publishing ?
> messages.
> Shilpa
Re: Index generation problem [message #45889 is a reply to message #45860] Mon, 12 November 2007 15:51 Go to previous messageGo to next message
Do you get these same messages when you run EPF build on the same library ?
Shilpa
Re: Index generation problem [message #45913 is a reply to message #45889] Tue, 13 November 2007 13:06 Go to previous messageGo to next message
Well it seems some sort of messages appear on stdout/stderr only - I can see
them (eg. related to publishing progress: Generating index.. Saving
index.html or something like that) in eclipse console or when publishing via
command line, I see just blank screen in case of EPF build or no appearance
in log files.
OS: Windows XP
Roman
news:a1424f28928b145530dfa7a49a9d6fb2$1@www.eclipse.org...
> Shilpa
Re: Index generation problem [message #45982 is a reply to message #45913] Wed, 14 November 2007 13:49 Go to previous message
It could be just debug messages which you see in std. output. You might be
running in debug mode. If you think the index site is not generating
properly, feel free to file a bugzilla.
Shilpa
Re: Index generation problem [message #585639 is a reply to message #45741] Mon, 12 November 2007 14:15 Go to previous message
publishing ?
messages.
Shilpa
Re: Index generation problem [message #585653 is a reply to message #45834] Mon, 12 November 2007 14:48 Go to previous message
Hi Shilpa,
Roman
> publishing ?
> messages.
> Shilpa
Re: Index generation problem [message #585668 is a reply to message #45860] Mon, 12 November 2007 15:51 Go to previous message
Shilpa
Re: Index generation problem [message #585678 is a reply to message #45889] Tue, 13 November 2007 13:06 Go to previous message
in log files.
OS: Windows XP
Roman
> Shilpa
Re: Index generation problem [message #585700 is a reply to message #45913] Wed, 14 November 2007 13:49 Go to previous message
Shilpa
Previous Topic:Agile Business Rules Development plug-in contributed by ILOG
Next Topic:Why aren't my Activity Diagrams being published?
Current Time: Mon Nov 03 22:57:48 EST 2025
Powered by FUDForum. Page generated in 0.06398 seconds
