Home » Modeling » GMF (Graphical Modeling Framework) » Adding Custom properties.
Adding Custom properties. [message #45736] Tue, 12 September 2006 04:30 Go to next message
Originally posted by: sayed.shoed.tavant.com
I have been going through the following links to get the property sheets
http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03326.html
http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03328.html
I want to remove the "Appearance" and "Rulers & Grids" properties from
the property sheet. Also I want the "Advanced" property to have only
the EMF data and not the View data.
Follwing the previous mails i overrode the getContributorID() method
but was not successful in adding the "Advanced" property tab.
Could anyone help.
Thank You
Sayed Aamir Shoeb
Re: Adding Custom properties. [message #46830 is a reply to message #45736] Tue, 12 September 2006 23:09 Go to previous message
Hi Sayed,
GMF Runtime activates the tabbed properties view by providing an adapter for
IPropertySheetPage
Add
public Object getAdapter(Class type) {
if (type == IPropertySheetPage.class) {
return null;
return super.getAdapter(type);
to your generated XXXXDiagramEditor to turn off the tabbed properties view.
Then you can bring over the original properties view contribution as you see
in the EMF editor.
Cheers...
Anthony
"sayed" <sayed.shoed@tavant.com> wrote in message
news:ee5r3j$clt$1@utils.eclipse.org...
> Could anyone help.
> Thank You
> Sayed Aamir Shoeb
Previous Topic:Dynamic model loading in GMF
Next Topic:Adding text between VXML tags using GMF
Current Time: Thu Nov 06 12:21:25 EST 2025
Powered by FUDForum. Page generated in 0.04054 seconds
