Home » Modeling » M2T (model-to-text transformation) » Re: package explorer doesn't show source folders
Re: package explorer doesn't show source folders [message #45617] Fri, 16 May 2008 10:46 Go to next message
Felix,
Was this property on by default or had you previously selected it?
Paul,
In the org.eclipse.jet project checked out from CVS the src folder in
the Package Explore is hidden. Is that a related issue?
Felix Dorner wrote:
> It wasn't mylin. The project contains some jet templates, but also
> hand-written code. In the filters, the point "source folders from jet
> transformation projects" was checked...
> Felix
Re: package explorer doesn't show source folders [message #45647 is a reply to message #45617] Fri, 16 May 2008 11:00 Go to previous messageGo to next message
Ed Merks wrote:
> Felix,
Think it was on by default.
Felix
Re: package explorer doesn't show source folders [message #45677 is a reply to message #45647] Fri, 16 May 2008 11:02 Go to previous messageGo to next message
Felix,
It's usually a bit confusing to have filters on by default because as a
user you might might not know about the option and might be thinking
something is wrong that you can't see the files...
Felix Dorner wrote:
> Ed Merks wrote:
>> Felix,
> Felix
Re: package explorer doesn't show source folders [message #45737 is a reply to message #45677] Fri, 16 May 2008 12:23 Go to previous messageGo to next message
Ed Merks wrote:
> Felix,
Hey, I didn't turn it on...
Re: package explorer doesn't show source folders [message #46174 is a reply to message #45737] Wed, 21 May 2008 21:06 Go to previous message
Felix:
JET turns it on by default. The assumption was that people using JET
wouldn't want to be bothered by the generated Java code, much as we aren't
bothered by the Java compilers generated .class files. Submit a bug if its
really bugging you.
Paul
"Felix Dorner" <felix_do@web.de> wrote in message
news:g0kcdl$or2$1@build.eclipse.org...
> Ed Merks wrote:
>> Felix,
Previous Topic:<java:class> in non source-folder
Next Topic:[jet] error reporting
Current Time: Fri Nov 07 09:48:17 EST 2025
Powered by FUDForum. Page generated in 0.04304 seconds
