Home » Eclipse Projects » Plugin Development Environment (PDE) » headless compilation: equinox launcher version
headless compilation: equinox launcher version [message #45567] Fri, 06 February 2009 05:11 Go to next message
I am experimenting the headless compilation following the Vogel tutorial.
Yesterday the build completed successfully but without the executable.
I suddenly realized that the I forgot to install the delta pack but now the build fails with another error.
The following (beautified) lines seem to be the relevant part of the output:
[java] BUILD FAILED
[java] .../eclipse/plugins/org.eclipse.pde.build_3.4.1.R34x_v200808 05/scripts/productBuild/productBuild.xml:28:
The following error occurred while executing this line:
[java] .../eclipse/plugins/org.eclipse.pde.build_3.4.1.R34x_v200808 05/scripts/build.xml:64:
[java] .../eclipse/plugins/org.eclipse.pde.build_3.4.1.R34x_v200808 05/templates/headless-build/customTargets.xml:12:
[java] .../eclipse/plugins/org.eclipse.pde.build_3.4.1.R34x_v200808 05/scripts/productBuild/allElements.xml:10:
[java] .../eclipse/plugins/org.eclipse.pde.build_3.4.1.R34x_v200808 05/scripts/genericTargets.xml:88:
Unable to find plug-in: org.eclipse.equinox.launcher_1.0.100.v20080509-1800.
The plugin in the last line of the output is not in my eclipse installation where
org.eclipse.equinox.launcher_1.0.101.R34x_v20080819.jar is present.
In the build.xml I have the following entry:
<property name="equinoxLauncherPluginVersion" value="1.0.101.R34x_v20080819" />
It seems that the entry in build.xml is ignored during the build and a wrong launcher version is used instead.
Where is the error? And why did it happen only after installing the delta pack?
Re: headless compilation: equinox launcher version [message #45595 is a reply to message #45567] Fri, 06 February 2009 17:38 Go to previous messageGo to next message
The deltapack contains the feature org.eclipse.equinox.executable. This
feature includes org.eclipse.equinox.launcher using a specific version.
Generally speaking, this is the version that pde.build will be looking
for, and could lead to this problem if that version doesn't exist in
your target.
I believe that tutorial has some extra scripting around the regular
pde.build, I don't know what he is using equinoxLauncherPluginVersion for.
-Andrew
Alessandro Caproni wrote:
> output:
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> installation where
> delta pack?
Re: headless compilation: equinox launcher version [message #45656 is a reply to message #45595] Mon, 09 February 2009 05:36 Go to previous messageGo to next message
Hi Andrew,
I was thinking to some configuration problem too...
In my installation I have 2 org.eclipse.equinox.executable features:
* org.eclipse.equinox.executable_3.3.100.v20080606-7H-ELQEDdVv 0SVkW65GwAA
* org.eclipse.equinox.executable_3.3.101.R34x_v20080805-7H-ELe E8hXnkE15Wh9Rz0yu
My build.xml calls the last one, whose features.xml looks like the following:
<feature
id="org.eclipse.equinox.executable"
label="%featureName"
version="3.3.101.R34x_v20080805-7H-ELeE8hXnkE15Wh9Rz0yu">
<description>
%description
</description>
<license url="%licenseURL">
%license
</license>
<plugin
id="org.eclipse.equinox.launcher"
download-size="0"
install-size="0"
version="1.0.101.R34x_v20080819"
unpack="false"/>
<plugin
id="org.eclipse.equinox.launcher.gtk.linux.x86"
os="linux"
ws="gtk"
arch="x86"
download-size="0"
install-size="0"
version="1.0.101.R34x_v20080805"
fragment="true"/>
</feature>
The launcher version is exactly what I wrote in the build. And my eclipse/plugins folder contains (among the others):
* org.eclipse.pde.build_3.4.1.R34x_v20080805
* org.eclipse.equinox.launcher_1.0.101.R34x_v20080819.jar
* org.eclipse.equinox.launcher.gtk.linux.x86_1.0.101.R34x_v200 80805/
The following part of build.xml (sorry for this long post) is what ant does:
<project name="alma.acs.rcp.test" default="build">
<!--sets the path of the properties file-->
<property file="build.properties" />
<property name="pdeBuildPluginVersion" value="3.4.1.R34x_v20080805" />
<property name="eclipseLocation" value="/diska/home/almadev/eclipse" />
<target name="pde-build">
<java classname="org.eclipse.equinox.launcher.Main" fork="true" failonerror="true">
<arg value="-application" />
<arg value="org.eclipse.ant.core.antRunner" />
<arg value="-buildfile" />
<arg value=" ${eclipseLocation}/plugins/org.eclipse.pde.build_${pdeBuildP luginVersion}/scripts/productBuild/productBuild.xml " />
<arg value="-Dtimestamp=${timestamp}" />
<classpath>
<pathelement location=" ${baseLocation}/plugins/org.eclipse.equinox.launcher_${equin oxLauncherPluginVersion}.jar " />
</classpath>
</java>
</target>
<target name="build" depends="clean, init, pde-build" />
</project>
Thank you for your help and sorry again for this long email.
Ale
> your target.
> -Andrew
Re: headless compilation: equinox launcher version [message #45905 is a reply to message #45656] Mon, 09 February 2009 10:33 Go to previous messageGo to next message
I think the build must be picking up the old executable_3.3.100, you can
try deleting it to be sure the new one is used.
Starting in 3.5 build will prefer higher feature version, but I think in
3.4.x and earlier, it might just chose the first one it found. You can
try upgrading your builder to 3.5 and still target 3.4.1 for your product.
-Andrew
> Hi Andrew,
> following:
> <feature
> <description>
> %description
> </description>
> %license
> </license>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> os="linux"
> ws="gtk"
> arch="x86"
> download-size="0"
> install-size="0"
> fragment="true"/>
> </feature>
> does:
> failonerror="true">
> <arg
> <classpath>
> <pathelement
> </classpath>
> </java>
> </target>
> </project>
> Ale
>> This feature includes org.eclipse.equinox.launcher using a specific
>> version. Generally speaking, this is the version that pde.build will
>> be looking for, and could lead to this problem if that version doesn't
>> exist in your target.
>> for.
>> -Andrew
Re: headless compilation: equinox launcher version [message #45931 is a reply to message #45905] Mon, 09 February 2009 10:48 Go to previous message
I have found a solution by installing a fresh new eclipse target from the following zip:
* eclipse-3.4.1-delta-pack.zip
* eclipse-rcp-ganymede-SR1-linux-gtk.tar.gz
Before I was building against the same eclipse installation used as IDE:
* eclipse-SDK-3.4.1-linux-gtk.tar.gz
I wander if there was an incompatibility between the SDK and the delta that I didn't figure out by reading the documentation.
FYI: I have tried deleting the old plugin but it didn't work either.
Thank you again for your help.
Ale
> -Andrew
>> Hi Andrew,
Re: headless compilation: equinox launcher version [message #591565 is a reply to message #45567] Fri, 06 February 2009 17:38 Go to previous message
your target.
-Andrew
> output:
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> installation where
> delta pack?
Re: headless compilation: equinox launcher version [message #591586 is a reply to message #45595] Mon, 09 February 2009 05:36 Go to previous message
Hi Andrew,
<feature
<description>
%description
</description>
%license
</license>
<plugin
download-size="0"
install-size="0"
unpack="false"/>
<plugin
os="linux"
ws="gtk"
arch="x86"
download-size="0"
install-size="0"
fragment="true"/>
</feature>
<classpath>
</classpath>
</java>
</target>
</project>
Ale
> your target.
> -Andrew
Re: headless compilation: equinox launcher version [message #591653 is a reply to message #45656] Mon, 09 February 2009 10:33 Go to previous message
-Andrew
> Hi Andrew,
> following:
> <feature
> <description>
> %description
> </description>
> %license
> </license>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> os="linux"
> ws="gtk"
> arch="x86"
> download-size="0"
> install-size="0"
> fragment="true"/>
> </feature>
> does:
> failonerror="true">
> <arg
> <classpath>
> <pathelement
> </classpath>
> </java>
> </target>
> </project>
> Ale
>> for.
>> -Andrew
Re: headless compilation: equinox launcher version [message #591659 is a reply to message #45905] Mon, 09 February 2009 10:48 Go to previous message
Ale
> -Andrew
>> Hi Andrew,
Previous Topic:Why the Unpack the plug-in archive after the installation doesn't work?
Next Topic:Incremental builders and source dependencies
Current Time: Wed Nov 05 11:42:53 EST 2025
Powered by FUDForum. Page generated in 0.04390 seconds
