Home » Archived » Visual Editor (VE) » 3.0m9 and ve1.0 install
3.0m9 and ve1.0 install [message #45528] Fri, 02 July 2004 01:12 Go to next message
Originally posted by: liujun10.goldeastpaper.com.cn
After install ve1.0m1 ,Istart eclipse i can find Visual Editor in
preferneces
but if i click it , it tell me " The currently displayed contains invalid
values"
ECLIPSE 3.0M9
VE 1.0M1
EMF emf-runtime-I200403250631
GEF-runtime-I20040330
!SESSION 七月 02, 2004 11:52:21.108
eclipse.buildId=I200405211200
java.version=1.4.2_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
!ENTRY org.eclipse.core.runtime 4 2 七月 02, 2004 11:52:21.108
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.jdt.internal.ui.wizards.dialogfields.ListDialogF ield.setElements(Ljava/util/List;)V
org.eclipse.ve.internal.java.codegen.java.rules.VCEPrefContr ibutor.createMethodListDialog(VCEPrefContributor.java:212)
org.eclipse.ve.internal.java.codegen.java.rules.VCEPrefContr ibutor.createPrefTab(VCEPrefContributor.java:232)
org.eclipse.ve.internal.java.codegen.java.rules.VCEPrefContr ibutor.buildUI(VCEPrefContributor.java:288)
org.eclipse.ve.internal.java.codegen.java.rules.AbstractStyl eContributor.createUI(AbstractStyleContributor.java:110)
org.eclipse.ve.internal.java.vce.VCEPreferencePage.createCon tributorUI(VCEPreferencePage.java:476)
org.eclipse.ve.internal.java.vce.VCEPreferencePage.styleSele cted(VCEPreferencePage.java:565)
org.eclipse.ve.internal.java.vce.VCEPreferencePage.populateS tylesTable(VCEPreferencePage.java:535)
org.eclipse.ve.internal.java.vce.VCEPreferencePage.createSty lesTab(VCEPreferencePage.java:616)
org.eclipse.ve.internal.java.vce.VCEPreferencePage.createCon tents(VCEPreferencePage.java:181)
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:217)
org.eclipse.jface.preference.PreferenceDialog$12.run(Prefere nceDialog.java:1006)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:608)
at org.eclipse.core.runtime.Platform.run(Platform.java:758)
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1001)
org.eclipse.jface.preference.PreferenceDialog$8.selectionCha nged(PreferenceDialog.java:528)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:452)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:450)
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:710)
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:728)
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:200)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:195)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 349)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2693)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2385)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:72)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:899)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:850)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:769)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2716)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2382)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1363)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1334)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:253)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:97)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:307)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
Re: 3.0m9 and ve1.0 install [message #45649 is a reply to message #45528] Fri, 02 July 2004 07:17 Go to previous message
VE 1.0M1 runs under Eclipse 3.0 M8. Please install the latest stable
build under Eclipse 3.0 final rather than using 1.0 M1.
- Jeff
> preferneces
> values"
> ECLIPSE 3.0M9
> VE 1.0M1
Re: 3.0m9 and ve1.0 install [message #593504 is a reply to message #45528] Fri, 02 July 2004 07:17 Go to previous message
- Jeff
> preferneces
> values"
> ECLIPSE 3.0M9
> VE 1.0M1
Previous Topic:Attempted tu begin rule error
Next Topic:Attempted tu begin rule error
Current Time: Thu Nov 13 07:06:50 EST 2025
Powered by FUDForum. Page generated in 0.03437 seconds
