| how to set up Eclipse & JBoss to hotswap [message #45485] |
Tue, 11 February 2003 03:18  |
Originally posted by: please_do_not_reply.hotmail.com
I'm using Eclipse with Tomcat (using the Tomcat plugin) and I'm curious how
to set it up to use JBoss so I can add a Session Bean to my project. With
tomcat I have tomcat use the WEB-INF directory under my project. But with
JBoss it needs to be under the JBoss directory. If I could tell JBoss that
my server directory was my project directory it'd be a piece of cake but
JBoss can't do this.
| Re: how to set up Eclipse & JBoss to hotswap [message #46841 is a reply to message #45582] |
Sun, 23 February 2003 14:48  |
Previously I have configured JBoss to look into my Eclipse project's output
directory for an exploded EAR structure. As I recall it worked fairly well.
Wayne
"Michael" <please_do_not_reply@hotmail.com> wrote in message
news:b2aqng$pf5$1@rogue.oti.com...
> I found the JBoss-IDE "plugin" for Eclipse and installed that. It starts
> and stops the server, other than that it doesn't do much that the EASIE
> plugin from Genuitec does. Now the only "problem" is that every time I
> recompile an object that I deploy to JBoss, I have to run an ANT target to
> copy the files to the jboss server/deploy directory. It'd be great if
this
> last step could be eliminated. Some ideas:
> 1) Make the eclipse project within the JBoss folder and set the output
path
> to be inside the server/deploy dir
> 2) Modify JBoss so that a server directory can reside outside the JBoss
> hierarchy (and inside the eclipse project)
> I'm curious if anyone has any ideas on this.
> Michael
| Re: how to set up Eclipse & JBoss to hotswap [message #590113 is a reply to message #45485] |
Tue, 11 February 2003 08:01  |
copy the files to the jboss server/deploy directory. It'd be great if this
1) Make the eclipse project within the JBoss folder and set the output path
Michael
| Re: how to set up Eclipse & JBoss to hotswap [message #590124 is a reply to message #45582] |
Tue, 11 February 2003 08:22  |
I believe you can set the project output folder to be a link to the JBoss
server/deploy folder in Eclipse 2.1 (M4).
Sten
"Michael" <please_do_not_reply@hotmail.com> skrev i meddelandet
this
path
> Michael
| Re: how to set up Eclipse & JBoss to hotswap [message #590169 is a reply to message #45612] |
Tue, 11 February 2003 10:21  |
You're correct, this is a new feature since Eclipse 2.0 (I believe, never
noticed it before).
I actually took the opposite approach, I downloaded a win32 app called
"junction" to make a symbolic link from the jboss/server/deploy directory to
my project/deploy directory. That way I can better manage the
configurations and stuff. So far it's working great.
"Sten Rosendahl" <sten@mindware.se> wrote in message
news:b2arvk$qdu$1@rogue.oti.com...
> Sten
starts
to
> this
> path
> > Michael
| Re: how to set up Eclipse & JBoss to hotswap [message #590181 is a reply to message #45582] |
Tue, 11 February 2003 10:58  |
The JBoss-IDE mods to Eclipse broke the refactoring so I had to uninstall it
and go back to EASIE which works just fine. I heard that soon the JBoss-IDE
will integrate nicely with Eclipse (now it's a hack) so hopefully this
problem will go away.
this
path
> Michael
| Re: how to set up Eclipse & JBoss to hotswap [message #590693 is a reply to message #45729] |
Fri, 21 February 2003 07:26  |
we were using jboss and easie plug-in. it does hot deploy automatically. we
did not need to configure anything. Hot deploy work with jdk 1.4.1. Right?
It is a feature of the JVM.
news:b2b2v4$rr$1@rogue.oti.com...
> noticed it before).
to
JBoss
> > Sten
> starts
EASIE
I
target
> to
> > this
> > path
JBoss
> > > Michael
| Re: how to set up Eclipse & JBoss to hotswap [message #590720 is a reply to message #45582] |
Wayne
this
path
> Michael
FUDForum. Page generated in 0.05921 seconds
