| Grid Row Span [message #45402] |
Mon, 07 January 2008 10:00  |
The Grid control has a code snippet for column spanning, and I can see
that the header can have spanned rows. Can I have spanned rows for a
column in the main body? Can that block span rows and columns? Does it
even allow for L shaped merges? Just trying to find out how far away the
merging capabilities are from KTable or what you would expect in a
spreadsheet like Excel or Calc.
Mark
| Re: Grid Row Span [message #45918 is a reply to message #45886] |
Tue, 08 January 2008 18:10   |
Correct. Grid is like most typical widgets. One widget, just drawing
content.
-Chris
Mark Proctor wrote:
> >>Christopher J Gross wrote:
> >> Hi Mark,
> >> Grid does not use other internal controls to represent cells or for
> any other reason. The entire contents of Grid are drawn on the main
> Grid widget. Adding this feature to Grid would require some reasonably
> significant changes. Currently the Grid only draws rows in the visible
> range, but if we allow row spanning, then it will also (sometimes) need
> to draw rows that are scrolled out of view. This would mean a
> reasonably significant change to the onPaint method. There will also be
> alot of other changes throughout the Grid.
> >> Regards,
> >> -Chris
> So Grid is not working like CompositeTable it is actually drawn more
> like KTable? KTable had full L shaped merging, hmm wonder if anything
> can be leveraged.
> Chris Gross wrote:
>> Hi Mark,
>> Currently the Grid only does column spanning (i.e. horizontal) but not
>> row spanning (i.e. vertical). That is a feature I'd like to add but I
>> don't have a timeframe for it.
>> Regards,
>> -Chris
>> p.s. I don't believe Excel even allows L shaped cells. AFAIK it only
>> allows rectangular merges.
>>> see that the header can have spanned rows. Can I have spanned rows
>>> for a column in the main body? Can that block span rows and columns?
>>> Does it even allow for L shaped merges? Just trying to find out how
>>> far away the merging capabilities are from KTable or what you would
>>> expect in a spreadsheet like Excel or Calc.
>>> Mark
| Re: Grid Row Span [message #60347 is a reply to message #45466] |
Fri, 07 November 2008 23:28  |
Chris Gross wrote:
> Hi Mark,
Just thought I'd check in to see if there was any news on this feature
and whether anyone had time to do it?
> -Chris
Yes sorry I meant it would detect and disallow L shapes, i.e.
overlapping regions.
>> the merging capabilities are from KTable or what you would expect in a
>> Mark
| Re: Grid Row Span [message #587214 is a reply to message #45402] |
Mon, 07 January 2008 12:52  |
Hi Mark,
-Chris
> Mark
| Re: Grid Row Span [message #587267 is a reply to message #45466] |
Mon, 07 January 2008 21:58  |
Chris Gross wrote:
> Hi Mark,
I won't to do a port of Drools Decision Tables, so we'll need this to
proceed:
http://labs.jboss.com/file-access/default/members/drools/ima ges/decisiontable1.png
I'll have a look over the src code see how difficult this is to add.
Does this in reality involve floating areas anchored to a point,
emulating a spreadhseet view with composites? How performant is that,
compared to the KTable approach?
> -Chris
>> Mark
| Re: Grid Row Span [message #587281 is a reply to message #45585] |
Tue, 08 January 2008 02:44  |
If you have found out something could you file a bugzilla and post the
id so people interest can attach?
Tom
Mark Proctor schrieb:
> Chris Gross wrote:
>> Hi Mark,
> proceed:
>> Regards,
>> -Chris
>>> Mark
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: Grid Row Span [message #587388 is a reply to message #45466] |
Tue, 08 January 2008 13:39  |
>> Hi Mark,
>> Regards,
>> -Chris
can be leveraged.
Chris Gross wrote:
> Hi Mark,
> -Chris
>> Mark
| Re: Grid Row Span [message #587401 is a reply to message #45886] |
content.
-Chris
> >> Hi Mark,
> >> Regards,
> >> -Chris
> can be leveraged.
> Chris Gross wrote:
>> Hi Mark,
>> Regards,
>> -Chris
>>> Mark
| Re: Grid Row Span [message #592662 is a reply to message #45466] |
Chris Gross wrote:
> Hi Mark,
> -Chris
>> Mark
FUDForum. Page generated in 0.04358 seconds
