Home » Eclipse Projects » DTP » Execute SQL in the run toolbar button?
Execute SQL in the run toolbar button? [message #45391] Sat, 14 June 2008 17:09 Go to next message
Would it be an idea to have the "Execute SQL" context menu become part of
the "Run" toolbar button. As a Java developer I tend to go to the "Run"
button in the toolbar to re-execute the last thing I ran (e.g. Java
program, unit tests, server, etc.). With my SQL scripts I tend to do this
whenever I made a mistake in my script, only to realize that I have to
right click and execute the SQL on the file in the navigator instead,
which is somewhat inconsistent imho.
I did a quick scan of the groups and bugzilla and could not find anything
related to this. Dunno know if I'm a dupe... Obviously this is a minor
issue, but if this is regarded as something that can add value to DTP, I
can add a bugzilla enhancement request if you like. Let me know what you
think!
Emiel van Rooijen
Re: Execute SQL in the run toolbar button? [message #45510 is a reply to message #45391] Sun, 15 June 2008 22:35 Go to previous message
Originally posted by: hui.cao.sybase.ocm
There's a Data Tools launch configuration which allows you to run ad-hoc sql
statements, but I don't think that's the feature you want, because it won't
pick up any changes you made to the sql in your file. So I guess you're
requesting some kind of "Run SQL file" launch configuration, right? Sounds
like a good idea, please go ahead and add a BZ entry. Thanks!
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
"Emiel van Rooijen" <emiel.van.rooijen@gmail.com> wrote in message
news:fa0ad4b3c302c2ec8c38e4b55c9efb21$1@www.eclipse.org...
> think!
> Cheers,
> Emiel van Rooijen
Re: Execute SQL in the run toolbar button? [message #591481 is a reply to message #45391] Sun, 15 June 2008 22:35 Go to previous message
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
> think!
> Cheers,
> Emiel van Rooijen
Previous Topic:Stored Procedure and User-Define Functions
Next Topic:SQL Editor multiple select statements
Current Time: Fri Nov 07 09:39:19 EST 2025
Powered by FUDForum. Page generated in 0.05705 seconds
