Home » Archived » OHF » Xds.b submit tests have the same errors
| Xds.b submit tests have the same errors [message #45378] |
Thu, 07 August 2008 22:16  |
Originally posted by: 322zx.163.com
I runned the test that the OHF provided,it occured the same the error.
Always it said :Undeclared namespace prefix "ihe".
The whole errors are here:
Eishay comment: output file is
D:\eclipse\WorkBench\OHFWorkBench\org.eclipse.ohf.ihe.xds.so urce\resources\logs\source.log
with append attribute = true
[DEBUG][B_SourceMesaTest.java:43] ***************** SUBMIT TEST
[DEBUG][B_SourceMesaTest.java:44] 2008/8/8 10:14:41
[DEBUG][Mesa12046.java:77] BEGIN MESA 12046
[DEBUG][Mesa12046.java:79] Secure URL is:
http://129.6.24.109:9080/axis2/services/xdsrepositoryb
[DEBUG][Mesa12046.java:83] Adding input document, and metadata.
[DEBUG][Document.java:109] Created new Document from
File=D:\eclipse\WorkBench\OHFWorkBench\org.eclipse.ohf.ihe.x ds.source\.\resources\sample_files\test1\input.xml
Descriptor=CDA-R2!text/xml MimeType=text/xml
[DEBUG][SubmitTransactionData.java:257] loadDocumentWithMetadata() adding
D:\eclipse\WorkBench\OHFWorkBench\org.eclipse.ohf.ihe.xds.so urce\resources\sample_files\test1\input.xml
[DEBUG][InputStreamDocumentEntryExtractor.java:62] Loading MetadataPackage.
[DEBUG][InputStreamDocumentEntryExtractor.java:68] Loading Resources.
[DEBUG][InputStreamDocumentEntryExtractor.java:79] Creating DocumentEntry
metadata with object from InputStream java.io.FileInputStream@19b5393
[DEBUG][SubmitTransactionData.java:278] DocumentEntry entryUUID generated.
[DEBUG][SubmitTransactionData.java:299] Document metadata loaded. Current
DocumentEntry entryUUID: urn:uuid:00f196ea-40f0-7440-e09e-001d7dab48a4.
[DEBUG][SubmitTransactionData.java:304] loadDocumentWithMetadata()
document was successfully added.
[DEBUG][SubmitTransactionData.java:587] DocumentEntry metadata found for
[DEBUG][Mesa12046.java:94] Done setting documentEntry metadata for:
org.eclipse.ohf.ihe.xds.metadata.impl.DocumentEntryTypeImpl@4e79f1
(availabilityStatus: <unset>, creationTime: 20060614, entryUUID:
urn:uuid:00f196ea-40f0-7440-e09e-001d7dab48a4, hash: null, languageCode:
en-US, mimeType: text/xml, repositoryUniqueId: null, serviceStartTime:
null, serviceStopTime: null, size: null, uniqueId:
1.2.3.4.133072049007104050.1218161682718.1, uri: null, existing: <unset>)
[DEBUG][Mesa12046.java:98] Applying Submission Set Metadata to the
Submission.
[DEBUG][InputStreamSubmissionSetExtractor.java:67] Loading MetadataPackage.
[DEBUG][InputStreamSubmissionSetExtractor.java:73] Loading Resources.
[DEBUG][InputStreamSubmissionSetExtractor.java:84] Creating SubmissionSet
metadata with object from InputStream java.io.FileInputStream@5a9de6
[DEBUG][SubmitTransactionData.java:943] Previous Submission entryUUID:
urn:uuid:00f175f2-40f0-7440-6816-001d7dab48a4.
[DEBUG][SubmitTransactionData.java:954] Submission Set metadata loaded.
Current Submission entryUUID:
[DEBUG][Mesa12046.java:116] Submitting Document.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:115] Setting attributes on
the Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:121] Setting Description on
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:127] Setting Name on the
Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:133] Setting Slots on the
Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:139] Setting
Classifications on the Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:145] Setting External
Identifiers on the Registry Package.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:401] No Submission Set
Associated Documents.
[DEBUG][EbXML_3_0SubmissionSetTransformer.java:429] No Submission Set
Associated Folders.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:343] All
submission set metadata added.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:117] Adding
document metadata to submission set. There are 1 documents to add.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:113] Setting attributes on
the Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:119] Setting Name on the
Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:125] Setting Description on
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:132] Setting Slots on the
Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:138] Setting
Classifications on the Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:144] Setting
ExternalIdentifiers on the Extrinsic Object.
[DEBUG][EbXML_3_0DocumentEntryTransformer.java:197] No parentDocumentID
for urn:uuid:00f196ea-40f0-7440-e09e-001d7dab48a4.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:324] All
document metadata added to submission set.
[INFO ][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.java:127 ]
Submission set contains no folders.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:142]
Verifying Submission Set associated documents and associated folders.
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:431]
Verifying associated documents
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:480] Number
of "forgotten" submission set existing associated documents: 0
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:485]
Verifying associated folders
[DEBUG][EbXML_3_0ProvideAndRegisterDocumentSetTransformer.ja va:526] Number
of "forgotten" submission set existing associated folders: 0
[DEBUG][Loader.java:132] Trying to find
[org/apache/axis2/deployment/axis2_default.xml] using
sun.misc.Launcher$AppClassLoader@82ba41 class loader.
[DEBUG][Phase.java:96] Handler RequestURIBasedDispatcher added to Phase
Transport
[DEBUG][Phase.java:96] Handler SOAPActionBasedDispatcher added to Phase
Transport
[DEBUG][Phase.java:96] Handler AddressingBasedDispatcher added to Phase
Addressing
Dispatch
Dispatch
[DEBUG][Phase.java:96] Handler RequestURIOperationDispatcher added to
Phase Dispatch
[DEBUG][Phase.java:96] Handler SOAPMessageBodyBasedDispatcher added to
Phase Dispatch
[DEBUG][Phase.java:96] Handler HTTPLocationBasedDispatcher added to Phase
Dispatch
Addressing
Dispatch
Dispatch
Phase Dispatch
Phase Dispatch
Dispatch
[INFO ][Utils.java:191] Created temporary file :
C:\DOCUME~1\postgres\LOCALS~1\Temp\_axis2\axis255416addressi ng-1.3.jar
[DEBUG][ProjectResourceBundle.java:236]
getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,nu ll,...)
[DEBUG][ProjectResourceBundle.java:412] loadBundle: Ignoring
MissingResourceException: Can't find bundle for base name
org.apache.axis2.resource, locale zh_CN
[DEBUG][ProjectResourceBundle.java:289] Created
org.apache.axis2.i18n.resource, linked to parent null
[DEBUG][ProjectResourceBundle.java:70]
org.apache.axis2.i18n.resource::handleGetObject(addingnewmod ule)
[DEBUG][DeploymentEngine.java:465] Adding new module
org.apache.axis2.i18n.resource::handleGetObject(deployeingmo dule)
[INFO ][ModuleDeployer.java:72] Deploying module: addressing-1.3
C:\DOCUME~1\postgres\LOCALS~1\Temp\_axis2\axis255417addressi ng-1.3.mar
[DEBUG][AxisService.java:716] mapActionToOperation: Mapping Action to
Operation: action: anonRobustOp; operation:
org.apache.axis2.description.RobustOutOnlyAxisOperation@b1aebf
Operation: action: urn:anonRobustOp; operation:
Operation: action: anonOutonlyOp; operation:
org.apache.axis2.description.OutOnlyAxisOperation@1c65216
Operation: action: urn:anonOutonlyOp; operation:
Operation: action: anonOutInOp; operation:
org.apache.axis2.description.OutInAxisOperation@1b6101e
Operation: action: urn:anonOutInOp; operation:
[DEBUG][AbstractXDSSoapClient.java:113] Beginning XDS SOAP Send
org.apache.axiom.om.OMException: com.ctc.wstx.exc.WstxParsingException:
at [row,col {unknown-source}]: [2,42]
org.apache.axiom.om.impl.builder.StAXOMBuilder.next(StAXOMBu ilder.java:239)
org.apache.axiom.om.impl.llom.OMDocumentImpl.getOMDocumentEl ement(OMDocumentImpl.java:130)
org.apache.axiom.om.impl.builder.StAXOMBuilder.getDocumentEl ement(StAXOMBuilder.java:359)
at org.apache.axis2.util.XMLUtils.toOM(XMLUtils.java:533)
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:116)
at org.eclipse.ohf.ihe.xds.source.B_Source.submit(B_Source.java :166)
org.eclipse.ohf.ihe.xds.source.test.mesa.Mesa12046.test(Mesa 12046.java:117)
org.eclipse.ohf.ihe.xds.source.test.mesa.Mesa12046.main(Mesa 12046.java:136)
Caused by: com.ctc.wstx.exc.WstxParsingException: Undeclared namespace
prefix "ihe"
com.ctc.wstx.sr.StreamScanner.constructWfcException(StreamSc anner.java:605)
at com.ctc.wstx.sr.StreamScanner.throwParseError(StreamScanner. java:467)
com.ctc.wstx.sr.NsInputElementStack.resolveAndValidateElemen t(NsInputElementStack.java:368)
com.ctc.wstx.sr.BasicStreamReader.handleStartElem(BasicStrea mReader.java:2945)
com.ctc.wstx.sr.BasicStreamReader.handleRootElem(BasicStream Reader.java:2093)
com.ctc.wstx.sr.BasicStreamReader.nextFromProlog(BasicStream Reader.java:2073)
at com.ctc.wstx.sr.BasicStreamReader.next(BasicStreamReader.jav a:1069)
org.apache.axiom.om.impl.builder.StAXOMBuilder.next(StAXOMBu ilder.java:153)
... 7 more
| Re: Xds.b submit tests have the same errors [message #45532 is a reply to message #45378] |
Sat, 09 August 2008 13:03  |
Hi Robert,
The more I think about this, the more I don't think it's related to the
document being submitted. At the point of failure in the call to
toOM(...), the document being submitted is not connected to what is
being "transformed" (and it's not in the SOAP transformation either).
The error indicates the "ihe" namespace declaration does not exist -
which may be a problem with the DOM implementation that OHF is picking up.
Please, could you add the following line of code to
org.eclipse.ohf.ihe.xds.source/src/B_Source.java at line 165 (right
above the sender.send(...) call):
logger.debug(new String(XDSUtils.serialize(ebXMLMetadata)));
Re-run your test and post the output. Also post what version of Java
you're using.
-Matt
> adding
> DocumentEntry metadata with object from InputStream
> Current DocumentEntry entryUUID:
> Submission.
> SubmissionSet metadata with object from InputStream
> Registry Package.
> Registry Package.
> Associated Folders.
> Adding document metadata to submission set. There are 1 documents to add.
> Extrinsic Object.
> Extrinsic Object.
> Number of "forgotten" submission set existing associated documents: 0
> Number of "forgotten" submission set existing associated folders: 0
> Transport
> Transport
> Addressing
> Dispatch
> Dispatch
> Phase Dispatch
> Phase Dispatch
> Phase Dispatch
> Addressing
> Dispatch
> Dispatch
> Phase Dispatch
> Phase Dispatch
> Phase Dispatch
> at
> at
> at
> at
> at
> at
> prefix "ihe"
> at
> at
> at
> at
> at
> at
> at
> ... 7 more
| Re: Xds.b submit tests have the same errors [message #586661 is a reply to message #45378] |
Hi Robert,
you're using.
-Matt
> adding
> Submission.
> Registry Package.
> Registry Package.
> Associated Folders.
> Extrinsic Object.
> Extrinsic Object.
> Transport
> Transport
> Addressing
> Dispatch
> Dispatch
> Phase Dispatch
> Phase Dispatch
> Phase Dispatch
> Addressing
> Dispatch
> Dispatch
> Phase Dispatch
> Phase Dispatch
> Phase Dispatch
> at
> at
> at
> at
> at
> at
> prefix "ihe"
> at
> at
> at
> at
> at
> at
> at
> ... 7 more
Current Time: Fri Nov 07 13:58:22 EST 2025
Powered by FUDForum. Page generated in 0.03759 seconds
