| An eclipse platform cut down a lot? [message #45306] |
Fri, 23 May 2003 08:31  |
Originally posted by: l.dobrev.efficient-soft.com
Hello group.
Excuse me if I offend someone, or if this question has been answered
earlier.
I decided to trye an duse Eclipse Platform as the base for my desktop
application bundle.
However there are a lot of extras/plugins, that I want to exclude from my
oproject.
Basically I need the core, the base pluging/fragment scheme, the SWT
packages, the HELP packages.
I don't want to see the Project menu at all, and saw no way to exclude
that.
I don't want perspectives. Instead I want a single custom perspective, and
thus I want to remove the Resource perspective, the Update Perspective and
so on.
Basically I wanted to build a simple view-driven application (not so
simple though).
Question: Can I remove a number of plugins from the Eclipse platform So
that I achieve what I want, or is the Eclipse platform built entirely of
required plugins.
Question: If the answer to the first question is true, what plugins should
I remove.
Please reply to group.
Lachezar
| Re: An eclipse platform cut down a lot? [message #46010 is a reply to message #45306] |
Fri, 23 May 2003 15:57   |
Originally posted by: gsrt.terra.com.br
--------------E43FC1BF7AEA8916FBFA7557
Content-Type: text/plain; charset=us-ascii
Removing plugins is not enough to get your intent. You must "hack" Eclipse code.
Take a look at org.eclipse.ui.iternal.WorkbenchActionBuilder.java. This file
create a lot of menus in a hardcoded way.
You can create your own Action classes and recompile workbench.jar.
TIP: Put your Action classes in the same jar (workbench.jar), otherwise your
code will not be abble to access a lot of usefull classes inside workbench.jar.
Seems that eclipse does not support circular references (PluginA needs PluginB
wich needs PluginA).
Create your own perspective, and change the file
<PLUGIN_DIR>/org.eclipse.platform/plugin_customization.ini to point to your
perspective at initial stage.
Perhaps I miss something, but the bare minimal set of plugins I've get are (and
someone correct me if I'm wrong, please) :
org.apache.xerces_4.0.7
org.eclipse.core.boot_2.1.0
org.eclipse.core.resources.win32_2.1.0
org.eclipse.core.resources_2.1.0
org.eclipse.core.runtime_2.1.0
org.eclipse.jface.text_2.1.0
org.eclipse.jface_2.1.0
org.eclipse.platform.win32_2.1.0
org.eclipse.platform_2.1.0
org.eclipse.swt.win32_2.1.0
org.eclipse.swt_2.1.0
org.eclipse.text_2.1.0
org.eclipse.ui.editors_2.1.0
org.eclipse.ui.views_2.1.0
org.eclipse.ui.win32_2.1.0
org.eclipse.ui.workbench.texteditor_2.1.0
org.eclipse.ui.workbench_2.1.0
org.eclipse.ui_2.1.0
org.eclipse.update.core.win32_2.1.0 // could'nt drop "update.XXX"because they
are used to update something in the first startup
org.eclipse.update.core_2.1.0
org.eclipse.update.ui.forms_2.1.0
org.eclipse.update.ui.win32_2.1.0
org.eclipse.update.ui_2.1.0
This takes 11Mb (!). All help plugins could be dropped, but you must edit
dependencies to other plugins.
You can hide editor area by program, and create your views, wich must be shown
by your Actions.
I could'nt find a way to hide shortCutBar by properties, but is possible to hack
WorkbenchWindow (take a look the method updateBarVisibility).Splash screen,
icons can be changed to your look (org.eclipse.platform).
See wich I've take so far (nights without sleep after) in the attached ZIP
And feel free to contact me (gsrt@terra.com.br) to exchange ideas and snippet
codes.
Usefull links :
http://eclipsewiki.swiki.net/2586
http://eclipsewiki.swiki.net/46
BTW: There are plans to make Eclipse "program centric" instead "tool centric" in
the version 3.0, scheduled to the end of this year.
At least I'm not the only going crazy guy on the block ::->
[]s
Glauco Reis
Lachezar Dobrev wrote:
> Hello group.
> earlier.
> application bundle.
> oproject.
> that.
> so on.
> simple though).
> required plugins.
> I remove.
> Lachezar
Content-Type: application/x-zip-compressed;
name="zap.zip"
Content-Disposition: inline;
filename="zap.zip"
UEsDBBQAAAAIAE9cty7x85APzjsAAC4VCwAHAAAAemFwLmJtcO2dCbwkRWH/ +x17sQvEqP9c
mj9Go0BAxRjRaGQ9Y6IxmhijMQaPGI0HKoJ4oKyIN4qKF14IIorK4X2syovH +kREDLCwsIgc
ex+wLLDLXpXqrpl+NV1H99T0HD31/X5+DN3V1cfU7Kvvqz7mPf4fHnzvxUnK I+R/B8v/Fk8m
yWUTSTKR/GFWvvNei5OfHpBk/7V56jOfSQghhJiRjli3cfMyAACATnJHCCFm L7+SEEIIUcER
hBBCXOmfIwQAADSWfjtCbrnGrRFCCBlYcAQhhBBXcAQhhBBXcAQhhBBXcAQh hBBXcAQhhBBX
cAQhhBBXcAQhhBBXcAQhhBBXcAQhhBBXcAQhhBBXcAQhhBBXcAQhhBBXcAQh hBBXcAQhhBBX
cAQhhBBXcAQhhBBXcAQhhBBXcAQhhBBXcAQhhBBXBuMIAABoIoNxRL0bJIQQ MuDgCEIIIa7g
CEIIIa4M2BFf+NJXCBmzmP/4+71HQvqaQk8+MEe89/2nETJ+KfxM9Xt3hPQ7 +j/pgTnilJNP
IWT8UviB6vfuCOl3hugIATBemD9QsmQGoLHgCIAawREwZoyUI4rPbMAAMbu7 8nWix2w0HAFj
xqg5wvyhgwFgbXk+Dj84AmIAR4DAEUHgCIgBHAECRwSBIyAGcAQIHBEEjoAY wBEgcEQQOAJi
AEeAwBFB4AiIARwBAkcEgSMgBnAECBwRBI6AGGiKI+TxeEoSjUKJGBZy1yr5 rGtRxZJ+0q0j
hv9x5O1jttKgmhFHQAyMgSMKvZO1ZNAUuin/oiolfaZGRwzo4/BsJ1/U52bE ERADY++I4YAj
tOl+fRxmwyaOkYVZuQ5wBMTAWJ5rwhHd0tdzTX38OKwNZd0djgAIokGO0Lsd 4eh5zE5paL5w
/UJrLnJ1dK7V+0CAI0bl4zBbz9+w9YEjIAYaPY7QOyh91loyUDy9k6dP85T0 mVrGEUP7OApS
MD3bn/3iCIiB5jpipInPEcOk0FwFZfQNHAExgCP6Ao7oN64mwhEAtdLE6xHN 8EVS+XpExZJ+
0sv1iKF9HK4m0h2hp25wBMRAUxwBfaVbR4DAERAHOAIEjggCR0AM4AgQOCII HAExgCNA4Igg
cATEAI4AgSOCwBEQAzgCBI4IAkdADOAIEDgiCBwBMYAjQOCIIHAExACOAIEj gsAREAPNcoT5
SG/hUd+KE31/Otj6hK8521XlgT8y3ICPQ1+rMG02lH+2e3AExECjHaHPqunS TslcpS+YW3b1
ZuassFXu36Fm1OKIIXwc1lVcTY0jALpnbBxRKBmyI4S3R/JLwbWon0dbuyMK JTgCoKE03RE6
eoXhO0JU7qw8haLCinVQlyMG/XH04ghrSTfgCIgBzjX1l3wXVbr6Qnni/VLT Whmrc02i3XRm
e5rVegBHQAyM3zXrvPMpTLtW6TtqR1UcYV00EE3075p1fz8O61qupi6t3CU4 AmKg6Y5oADE5
YtDgCIA+gyP6gtk1eTqrKpUrKiaU5jkicd8GbG09V2UR3p44AmKgKY5IOnFV GyHMfsnfrZVW
9nd0vdGtI0bl4/B0+2ZbWRuzhybFERADzRpHQJ8IG0dEDo6AGMARIHBEEDgC YgBHgMARQeAI
iAEcAQJHBIEjIAZwBAgcEQSOgBjAESBwRBA4AmIAR4DAEUHgCIiBpjvCenN+ Y56hGBnqckRU
HweOgBgYS0d4ysFKXx3hKW80OAJioEGOSDQqFgaUiFqwPsZrzpr1PSXmKp7K FTfYJsARiUbF
woAS4aGrJiqU5OvqW/DvzgBHQAw0xRGF7iKfLfQqvZeU9EsV8fRO5lJzkauy 9diqrF62kW4d
MfyPo6smMpeWtmQFcATEwHg7onods2aveDZVWOTv4ko7wOqru0oG5Yjqdcya Pqo0UVJh1NDl
p48jIAaidYSOWa0eXBsslPu7uCodoKdCtZ5w6I7o6eOo3kSelneVuMEREAOc ayqUdNE1VcHa
O1m7psRx+aB6B5hPW1exbrBN8841tRcX346rvtkyerlr1guOgBgYA0fk6EuD S0Tt5L2Tq4vW
S8yuzDXtqWDuq2wjNTqil8Y3S0QVSpsoLy9tQFcdGzgCYqDpjmgAnt5Jr6BP 9+6I0jqd1OWI
4VDFEWoRjgDokhgcoSp38Xtp71TptwsV9GlrSZUurgmOqOfj6KqJ8mr5Un+D VDswHAEx0PTn
IyqSrzVQTRQ6JT3+ytYS4e67quzLteuMbh0hRuHj6KqJzKVVGs0LjoAYaJAj oH8EOAJwBMQA
jgCBI4LAERADOAIEjggCR0AM4AgQOCIIHAExgCNA4IggcATEAI4AgSOCwBEQ AzgCBI4IAkdA
DOAIEDgiCBwBMYAjQOCIIHAExECzHFF4LDefLTztWygPexa4V8zHeF2LqpSY x1+obNLNWw5z
xPA/jsJ2qjdjXp4vNUusG9TAERADY+AIvQsyZ60r9p1CN+VfVKXEpLRON2+5 RkcM9ONwNUJp
M5oH4C+xHTCOgBhokCMKfY5runmOcC21liSOX3dNunnLAY4YiY/DtR1V3ntT uxZl4AiIgfFw
hKenyhGDxNO91NVxeTbrKnFTryMG93H04ghroWsVHAGx0hRHePoi16zOEByR OE5luxYljnGB
qx8zV7dWq0a3jhiVj8PVvPq09VPQ67tKylbHERADY+AINeGZHrQghLd/9h9M 3v97eqe8jrXc
NeulRkeIQX4crk25msiKqyXLVscREAONdkRpzaHRuyP8WPUxbEeU1qwfHAHQ ZxrhCLOf8fQ8
I+cIT9dt9kW9OEJoq7sqOOjKESPxcZjvsUrDdlXZs3oGjoAYaLQjRkIHLjwd tbV/00vyWdcW
hCiv3E3j1OKIIXwchT2WNmy3lb0fAY6AGGjW8xHQJ7o91wQCR0Ac4AgQOCII HAExgCNA4Igg
cATEAI4AgSOCwBEQAzgCBI4IAkdADOAIEDgiCBwBMYAjQOCIIHAExACOAIEj gsAREAM4AgSO
CAJHQAw0yxHWJ3wVZp1Ew7pufyk8oqs/Cq0Ku33C19ygv7KJuwXCHDH8j6Ow kW4bzcTcoBsc
ATHQaEeYfZHeI7kWDQKzL/Ls3V/ZVWKdtXaG1pqd1OKIIXwcrmYpbTRriVno PUgcATGAI/qO
v98uUKUr82wHR5jT1UvMQhwB0TOujlDTOea6g8PfdxWoyxHWasNzhOjTx9GL IypW67LRcASM
GWPsiCqL+kti+8pQf4marlJinR1hR1RZ1DWF95u4r0dYd9ftp9MJjoAYGLNr 1ua0PiuGQmm3
Y/ZjVUo8q+uLPLMafbpm3fePQ9+I/+27dleliRzr4giIgaY7onqFkXaEv4K1 JGBR/x1RvQKO
AGgEOKIvmL2Tp7/qnyOEtvfEcb4lo3mOMN9RV22uU6WJbOU4AmKgKY5IOnFV 8zDocYS1E7P2
Qnl5vrRKSVer5zUddOuIUfk4XE3hKSmUe5rI0+YZOAJioFnjCOgTYeOIyMER EAM4AgSOCAJH
QAzgCBA4IggcATGAI0DgiCBwBMQAjgCBI4LAERADOAIEjggCR0AM4AgQOCII HAExgCNA4Igg
cATEQHMdMehn4sYaHBEAjoAYaJYjXM/25rOuCuAn2BFmOxfaf4w/CBwBMdAg R+i9jbUXKlQQ
UJm6HGF+BDgCR0CjaaIjCp0PjuidMEeYFsAROALGjIaOI/RZHNE7OCIAHAEx MGqOMMmXhjnC
uk0wEQb+atbW9jjCurWmIwxwBIwZI+UIPx5HFKb1EugTnuFD4RMprjnW4AgY M8bDEaWVoXZc
jvBUiwEcAWMGjoAAzOZ1NTiOwBHQaBrkCIDRB0fAmDH616wBRhYcAWNPg+59 BRgpcATEAI4A
CANHQAzgCIAwcATEAI4ACANHQAzgCIAwcATEAI4ACANHQAzgCIAwcATEAI4A Hzyu7gZHQAw0
xRH6N2/kuOroJYWag/hqiMIu5KyKa6mnsrVOXzEPoMrBmMdcC+Y2XQdW2m7W 6d4OG0dADDTR
EWZh6ax19X5R2jXpVKnc12Pudqd6B+uaqAu/I6yF1ad7PmwcATEwNo5Q0y4F DM0RpeVNcUSS
dKRQJxnGOMJKt+3Zw2HjCIgBHFE/TXGE2e17dmp6wTpbL/12RG8HjyMgBsbj eoRn2qxp3UKd
WHu2KuIo9NjWOrVTpVPVSwL67WC62pe/3fSlhTcSevw4AmJgPMYRpYXmUk+d XqmiA2thVyvW
Re+OcBX2jt8RXbVnfvAucXQPjoAYwBFmnV5pliN0qvTArj52MC1Zuhe/I2oF R0AMjIEjzH7e
LHeJo2ZHJN4bRwv7qlLZrNNXSjtVqxTMid6xNo6rKaq0Wx/aEEdADIzB9QiX I/TK+iJzCzVT
2Ky/n69SuU/HacV/tMLokPt6bObGPc3obzccARBEUxwBMGrgCIgBHAEQBo6A GMARAGHgCIgB
HAEQBo6AGMARAGHgCIgBHAEQBo6AGMARAGHgCIgBHAEQBo6AGMARAGHgCIgB HAEQBo6AGMAR
AGHgCIgBHAEQBo6AGMARAGHgCIiBUXMEQIPAETD2jJQjAJoOjoAxA0cA1AiO gDEDRwDUCI6A
MQNHANQIjoAxA0cA1AiOgDEDRwDUCI6AMQNHANQIjoAxA0cA1AiOgDFjuI4g ZPyCI2CcMP9J
D3gcUeP2CRl6cASMGTiCkBqDI2DMwBGE1BgcAWMGjiCkxuAIGDNwBCE1BkfA mDFqjkgc1HUM
YRn6AZCmBEfAmDHKjjDLe9l7L8ERpGJwBIwZo3muyWqEUk34/WIW+uvos9Yt WwvJmOWoo48q
fL5miR4cAWPGmDnCnLYWlk4XVvdUKEyT8YsuBb8gZnEEjB1xOsIqAs8GcUTk UWooFcQsjoCx
oymOSNp4tt+LI3Q8K7rW8hwVGY9UEcQsjoCxY5QdUaB0+9bK5nRXJa4Khf2a B0PGKYwjIFpG
9vkIs6sv/fH0qEFf3VqtUKewx0TDtVkyruF6BMRMUxxhLTFXsU4TEhzua4LI wRGE1BgcAWPG
mDkix1ONkP4FR8CYMWqOSLzUdSSE9Ck4AsaMkR1HENLE4AgYM3AEITUGR8CY gSMIqTE4AsYM
HEFIjcERMGbgCEJqDI6AMWPojgAYJ9QPlP7PHkdAoxmuIwgZvxT+2Z+CI6DJ nDI8RxASQ3AE
NBocQUhfgyOg0eAIQvoaHAGNZuiOkLsmZMyi/wvHEdBohusIuWtCxi/6DxSO gEYzREf0cusI
ISMbHAHjhPlPeojPR6gKAI3A+s8VR8CYgSMAwsAREAM4AiAMHAExgCMAwsAR EAM4AiAMHAEx
gCMAwsAREAM4AiAMHAExgCMAwsAREAM4AiAMHAExgCMAwsAREAM4AiAMHAEx gCMAwsAREAM4
AiAMHAExgCMAwsAREAM4AiAMHAExgCMAwsAREAM4AiAMHAExgCMAwsAREAM4 AiAMHAExgCMA
wsAREAM4AiAMHAExgCP6SoL0amIEWxJHQAw0yBFLly3LYy0slLvWXerdS4/I rkxFL/EsCijp
BfO9qxJP49CSLnAExEBTHGH2VNZys4K/Wr1YOzTXorCSHvE4wlWHlnSBIyAG InGEp2aNNKJn
sw4EqjvCWlI7jWhJHAExEI8jXIU10oiezaqDrhzhKqyRRrQkjoAYiMoRnvJa aETP5nLEUscl
BlrSBY6AGIjNEf5FPdKInk20W8A1dqgyjihd1CONaEkcATGAI2qkET2bwBE1 HTWOgBiI8L4m
HCG6aR9a0gWOgBgYP0csdT8xsdR2vr1eEvdN+OaisJJaMNvT02K0pBUcATHQ FEcAjBo4AmIA
RwCEgSMgBnAEQBg4AmIARwCEgSMgBnAEQBg4AmIARwCEgSMgBnAEQBg4AmIA RwCEgSMgBnBE
f0mS8jrQTHAExEBTHLHUWKRKrOWuyoNASkFFL/EsCiipA1e7LXU8Um1t1b6S 9OcB8xrBERAD
jXNEYWK0HGFVg2tRWElNFBrENTtgL+ToahhZTeAIiIGmO0I4ftfVO7fBdXQN cYSpVxwRAI6A
GGiWI8xX4e7rzJ6w7+CImsARACPCGDvCnO07TXCEtblwRAA4AmKgQY4odG6l QwZrYX/BETWB
IwBGhHF1hGu6v+CImsARACNC0+99tc6WVu4XI+8IV8vgiABwBMQAjqiZxP04 g7korKQHPC2z
1PF8hBgSCc9HAIwATXEEwKiBIyAGcARAGDgCYgBHAISBIyAGcARAGDgCYgBH AISBIyAGcARA
GDgCYgBHAISBIyAGcARAGDgCYgBH9JVRfgQMegRHQAw0xRFLjUV5iTnhWmUA JMbTwfm0dVFA
Se8srfxI9VDaUNGPN14vOAJioHGOqDIh2t2gGCxWNbgWhZX0jsukI+WIfrzx 2sEREAM4okZw
RF3gCIARoVmOMF89EzjCCo6oCxwBMTB+jvB3en2l6Y5YalynwBEecATEQIMc ofdX1n4MR1TB
4wizHEd4wBEQAyPlCICmgyNgzBi1cQRAg8ARMPY05VwTwKiBIyAGcARAGDgC YgBHAISBIyAG
cARAGDgCYgBHAISBIyAGcARAGDgCYgBHAISBIyAGcMSAGdmnhkecEWw3HAEx 0CBHLK38Vw88
5QPA7M0KJfls4v5jE3qJWSfp4Q8rmC2jN2yhbc3CgeFpnCptUnu7meAIiIGm OKLQTeWzTXSE
Waj3fv461rW6wuqI0moDbk/P26zSJv1oNxMcATEwlo5QhcPSxFg6YsDgCIAR AUfUTi+OKJ3G
ETgCYJCMgSOWdp4z12sOpaOr7ojEdoZ8AI4wW6xQInBEBXAExMD4jSMa5AgX +aI+OaK0xFU4
MHAEwIiAI2oHR/QOjgAYEcbMERU7wD6RdHO/pb/X6l9fF+aIASvD8zartEk/ 2s0ER0AMjMHz
EYWYa4nB4urwTQoGyWetha61usVsLlcDelp1AHjeZpU2qb3dTHAExECDHAEw UuAIiAEcARAG
joAYwBEAYeAIiAEcARAGjoAYwBEAYeAIiAEcARAGjoAYwBEAYeAIiAEcARAG joAYwBEDpsZn
uKJiBNsNR0AMNMgRSyt/Pam15sAwe7NCST6bDPx5YbNBVImnxYbShsLxxj2L +tpuVnAExEBT
HFHoqfLZ0j5t8F2c2QtZ+yWz9wsr6QqPI1x1hu7ZwtscSrtZwREQA2PviMEz yo4Qjm9nwhEB
4AiIARxRO6PvCHMaRwSAIyAGxsARnl+Jh0J1RySdZ8grluhbCMDliEIzWusP DM/bNBeFlfQO
joAYYBxRO2YXZO2UqlTzlwT3daqJXGMHxhEVwREQAziidnBE7+AIgBFhpBwB 0HRwBIwZozaO
AGgQOALGnqacawIYNXAExACOAAgDR0AM4AiAMHAExACOAAhjxB0hf4RL60TF KDRIklFabaTA
EQBh4IhmUdogA2uxZn00OAIgjCE6ImnjKdQn/PX1cs9GChM6hS1YS2ZseyzM 6lSsnNiwbsGs
4CrMy2dsB6/XcS3S65iLzNkqm/VM5LhW8S/ygyMAwhiWIwo/+K5C/dWs41nF WuLvW7ralKfE
OuuvbD0ea53SknxWnyhd13MwrkWufZmz/kUVd+dfVAqOGDRJUl4HDOp6OLpG RuFck6u7yEu6
6jdcG7FOFOoUKvg33uOxeSpbC0sPwDrb1bqlmPXNbbqWVq+TU1hk3VdFGuSI pY6/MeQqt21j
IJgWKJTks3JCRV8UUNIN1uYS3q83GQoJf2OoAnp3oeNaZF03n/ZvxFyrsK51 tqsSnUSjSuUZ
g9ItFNbKZ/01CyVJJzMOzI17djdj26x/xQKFRdZdVKQpjui2QxtpR5iFajqs pEtcJh0pR1jV
4FoUVtI7Q3SE3nXkJYVpsyso7Tc8JeaEOauvkh1dxypVdmelYuWALRRWKRyw q2ahxH9gSRuz
jnU7VY7BWse6SpVFpeCI+mmOI4StJXFERYblCNfPeNKmUK1QbtZPOjuQwkby WddGCtOF18S2
8cS2/QLmIk/lvEJhVq+faLjqm+Xm6vqsdZG5rrXQsyl92jqrl+ckGuYi63QV cET94IiewREe
uv0Zd1HXdgLo36672nKhci/rBtcp0EvLeNbFESbNcEQeV4lemM/qi7qniiOW 2i5YDBIc4aGX
n3edsXTETDcbH6QjKm4cRwgc0VU1xhE4wkbSxl/Hs7RKhTC67Tx7JLFRulZO 2FrV6evGC3S2
QeJaalnTC46oHxzRMzgCYETAEXVSeqaoULkwHVbSJXrLWKdxREVwBMTA+Dli qeOJicFRcRwh
qjmlK+9UwNU4epMOuQEzEvfjDOaisJIewREQA01xBMCogSMgBnAEQBg4AmIA RwCEgSMgBnAE
QBg4AmIARwCEgSMgBnAEQBg4AmIARwCEgSMgBnAEQBg4AmIAR/SX0CfdYPTB ERADDXLEUvcD
wp7CpQP2jvWxaM8i1xPTPTxJ7cdsKH3abDRrfbNV+9HOiW2TeaG+NOn/U9Um 1R1hVgNoCk1x
hKtns/Zmnm6wv3i+TMlc5CkxJ+qjSkuWlo+CI6wlatos6QfVHbEMoLFUdIT5 sxDAsj44wlpo
XToIenREYWKw44iA8qV9HqwVuno9/lVGzRHl43mAUaWiI2Shf4xQGoEjCtOu yv1RQ06NjjAL
68Xa1fv7fBwBUC9dOULNin375MTeHULsSn8o9u2VL3cKIef3ZVkvxAb187Jn T5rWWn1zhPmr
bLMdYc7WytLO3/+ruMCsLIyPQPSBQvdu9v+FpVaP4AiAXuh2HCFLpiYnJ5Jk KjlgOjlwIpmc
mpxeNJ3ILJhIFk5O7LckOfAeiSyXmZ4+YPfuubNV/XCEtXdqvCOsJTVRsSVL y/Pp/rW23xHW
zt/0yNg4IuCPiCUapZWHgtmANbEv/VV2X87eNHvz7Mmzd4/K7o7s3mVmTyt3 79llzc40d3dk
dys7WtmpcldHdqTZteNOI3ekuUvP9rtV7tRz+1zuuH1nmm1z2a5ymzbRyo70 9dYdMrfr2Zq+
btuaTmxrJWAcMTkh+/+JiUXJ1OJkfjKxcGIqSQ5Ikv0nkwMmkv2T5KAkud+8 6Xmyzu9PJGqw
gSO6uB5hXpuoleY6QnQOFqzgiJxRVkOO2YA9o6lBM0JLBLt3t3r7vGNvdeZz vfeune1e+i6V
Vhfd2Tm3+uS78z65sxMu9r1ZZ3vXti133aayOc2tMpvuTLPxzq1atmyQuWPL +js2y6yT2b5p
3fb0da3M7RvXyGzPXm/fcEua9Ten2XDTtvVZ1t1027obb1sr8zstN9y6Jsst Mr/Ncv3Wm6/f
esvqrTfLXJe+3nSdzJabVmev12696dotN6YJGEdIlCPm7Z+IvelnsudusVeq 4G4hdootd4jN
29M6e3bvEXt3SkcMbBxRpVvrLz06wrRDHzRRoyPM2bpIHNemXYWFaRzRCEHM 9HEcAbURcj1i
z24phvkTctSwaHp6/t694pat4ohHnzCV7N5vSkxN75qcuntqUixcILJBRD3j CJF1R0uNs+J6
eZXKfScpe+ShoAZrST/xdPLWRtMLzcbsa/Nau3dXYUEfLsvUSIAjEjfWCjNa b1+YyGcLJJ34
K8wYNvGvbi6yru6aNTEbsAY6xhF79uWnkuZGEO1TQHLUoM7ztIcJO9PRgRoX tE7IaCOC1lhg
xzZ9ILD5Tm0scMdW+ft/ls0y67erUcDmtelAYGNrCHD7xlvU7//bNty8bf3N 8tf+LK3f/G+V
Ub/tr0l/29+a/ra/Wvsl/9qt8nf738ms2ixzwzWbb7g6y8pN18tcJbPx+is3 rr5y43VXbFx9
xYbr/nfDtTK/SbPq8g2rfrN+1a/XX/PrddfI11+tu/qyNCt/tfbqX6696tK1 V8nXX6656pK1
V12y5opL1l55ydorZtdcMRsyjti7R34Mu+4U08mSycnpJJlcc2uqiSXzxKJJ kUzsWLSfkI5I
kt2ZIHbWMo4AGDWCHeHqMM2lSZvCtLW+q0L1VapUnukkYBUdswHrID/d1DrX 1D7RNOcI/fxS
+8xSdsL/zu2t00fZiSPtZNHc+aKCI1qaaJ0pajuidaYo1UTLEZvWtjXRdoQU xPr8BNGNt61r
nRe6de0Nt0lBZNmqzgjddP0WdUZImiI9/7Nqs8zvrkkjBfHbqzdJR/xW2kFz RJrUEeuvVZq4
PHPE5coRmSYuszniUqWJNVeq/GJtl45QsyuvEfe7/3k33yJk0pNOycT+C+Sv vrfdvUU85THH
LVl42+IFt04n+xZMCrE7S03jCICRIsARM95u098J+5f2XqH37ZfOmpgNWA/5 Beu9uSacQ4mW
JuRQQl1omLvEoF/VTS/j3rVNpe0I/ZrC1k2tccTWTBAq2QWFzBFrNUesMRxx Y+aIGzuuHdxS
GEe0hhLZOGJVNo64JhtHpJrYJJM6Qg0lrtyUCUIOJTRH/CYTxG/agpCvl62/ +lfKEetWXro2
y5qVUhPpOCIbRMjXwHHElSvFgw658CEP/cBNN6efxvTU9AELkyXzk11bhYwU xP6Lts2fEAun
5GAjDeMIGEvCHDHj7jn9nXDA0ip1Ki51VegRswFh1AgYR1x/rTj80C8eMG+b zNptYt3tIklv
Z1q8KJkv9ohrbxAPO/Kj8yf3zpvYI8TOveIuwTgCxpHaHWFdVLEPr7LNgC3o hZ5dBGM2YJ2U
nXGyXZW4Y+50UzaU0MYR6nTTlvbtSWocsal9b5Jxuik90aTONa3rHEfc0jrd lN6PpJ9ral+S
WJOea7pNjiPWXJ/efdQ63dS+JHHjdVvU6SY5mpi7HiHHEa1LEu3rEe1zTde1 zzW1Lkm0xhHr
Vv06O9f0qyyXrpMjCDmUSM81XbImSzqOuOIXa678RcA4YvUqceiDzvm9Bdvv sfCORz3x2PXb
xZ5dYjI5cGEyb3Gy8IZbxDXXi4XTaXbt2871CBhXgh0xU9bfJgauVfxLq9Sp uNRVoUfMBqyV
jjNOe/UzTvarEto9rq2rEsVr1i1N5Lew3ipNsalw2bp15+qW9du3aDevGo7Y tiG9YfX29eqa
9U35uab29YgbWneodjgiux/1d9emF6xvbDvit21H/Paq7IxT+3rEdVdslILI HLE+u2y9XppC
nWtSprj6svUr2464+tK1mSbWpFclMke0L0kEjCNWXy8OO/zsxRM7lkzuXDhP DiL23LpFbNkk
liQLF6cP0iWy2trN4ogjT1Sfkqg8jgBoOtXvfa3Y5Vbswz1b62ULeqFnF8GU N2iP2IcSuzsu
XndeuW49AdF2hHblemvnYw7tSxK3OcYRW9JxRNsR+SWJ/Nam9KGGba1kjlib O+J3t61p3dfU
dsTqLTerxxZa44jNN6YXrLfIqHGE1EQ2jtioHHF9dj1ideHWpss3KEes+nXr ynVrEHFZNo7I
BhHpVYlL1rbHEakjrggZR1y3Whxy6JlSEPfaTwpi14JpsfSxb5aOELvEgROL 1VPYN29INaGo
Po4AaDpdPR9h9rqFErOL9i+dsZEvstbxbMQ/WwvlDQrDJmAcsWWjePQjT7rv H1980H1/fPD9
L3rg/S44/JCzDzv4rOwhul3zlyQL9k/mz5ufjiB2p0/Vie7HEflt7eb97dab 3gs3xptLzbXy
Qlc5QAA9OiIvzDEr+5eaFFZ0LdVnc1zliWNf3VLeoL3TcY/T3FUJ44yTdlXC GErsLH1EYmvh
XFPrkoQaR9xhnGva1n5EOr8esW2d9mR0dkkieya6da5pS+sRiWu33ti+/bV1 a9PV2iMSV236
7cqNc7e/dpxrUknvblLXI1qPSLRvbbr60jWt218vUckGEZesDboeIR2xeYP4 zWVpVl0prr1K
XHe1uOE60X5i7hbpiKnJqYlkIhVEN9/XlFOjI6yLXHX8rgEopStHzNT6y7l1 U/3efo+UN2gt
+C9eF2+C7bwP1jjddJdx2Vo/1zT3GF3rdNO67Em69jXrTa1zTds2ZGmfaGo/ Rjd3rum21rmm
1u2vW26Sya5HtL4iI7tmnWqifa4pe0Qiu2atXbaWglitNHH5+vZl69wR+iMS 6fWI1BGpKdQ1
a+WIbu99VbNJMjE1Nb1kQSKzaGpqwcRE9uV+S5JkvsyC5J5TyYGLJpP9ppJU ExnBjnBN66MA
jxQKlDqitBDAT7eOmKmv703aeEp6ocGO8DxVl31xk3aDU/uqxF3asxK5JlrX I7bu2NZxPeKu
jmvWG/XH6Lbr37m0sfgYXfHWJm0ccau6tUl7RGLLzepR67nH6La0HrVWj0is VLc2ZU/StccR
qzNHpOOI9mXr7BEJzRHZUCJ9jC5/hq79wHXQNevZ9vc1Zd8OvjWN+u7vbABx l8juc92RnV/a
u7P1+Ny+nsYR+mypOKyz1kU4AvqE3xGJG3c/2h192uwM1yNiJWAcEfwa7Aiz pCtHmMMN/9bM
sQlARQLGETFT3qA14jzjVBhKdHyDkxxNtG6C1b7BdUfh1qaO000bWqebNm/I v47jjvy+pk1r
9HHENjWOWNf5qPWa9FHr1tdxqHFE8RGJ9vWIG6/RLkmoe19Xare/th61bj9t 3b4esSp7OGJV
No5YmQ8l8usR6lubfrlWfWXTlSHPWQe89ugIcxzhKnRVq1gHNUCP4IiuKG/Q eilqouNxCcuz
EpojOk83bdmhPR+hfx2Hdvvr3CMS2/NHJDYVvtnvZu2ydesRiVtb3+P927kv 8Z5zxLXZ13Eo
TVyTfmtT+xGJ/Os4Nra/jmNT/nUc6vbXVXOP0XWca1r5K3U9onX7a/vKtdTE muwxum4dERxR
6/WIfBpHwEiBI7qivEHrxXGP055dHRev86HErsLzdPpl69uMW5vafwZC+/ZX 9a1N2mN0mzq+
skkXhP6IRDaOyC9bX699a5PuiFVzjlCaaA0iVm7KH6Nb3RpHtB+1vjwbSvx6 7tYm/VHrq9U1
61+uUV/rpy5JdOOIHhHVHFE41eNXQFf9v3C7wFqOLyAAHNEV5Q0Kw6aiI2pJ FUcowhyR+yUx
rj6YJYUVPZUBqoMjuqK8QfuI8fdMO/+YqeXPmGa3y7b/bmmlP1q6ey76nys1 /mJp687bwh8t
vSM/66Xn7vyPls79abziXyy9u/AXS9vfdm5mh/4V6HN/sXQuo+kIgIaCI2DM GK4jCBm/4AgY
J8x/0h5HlPwK5cblCDn78gfs94o/X/zKB+3/qkMOPObQexxz2D1fffi9X/OQ P3jtEX907MP+
5HUPv+9xj/jT44886PWP+rMT/voBJzzmgW947MFvPOrQNz3usDc/4cEnPvGh b3nyw976lL88
6e/+6qSnHrnsaY9629MfffIz/ubtzzzqlH9+3Dv+5QnvfPaT3vWcJ7/7uU95 9/P+/j3Pf9p7
/+Pp73vBM0590T+9/8XP+sBLnn3aS5/zwZc990Mvf96HXvH8D7/q6NNf/cKP vObFHz32JR87
7qUfP/6/P3HCK854w6s++aZjPnniaz71lmM/fdJxn3nb6z978hvOPOVNn3vn iWe9661nv2fZ
59/7ts+f+vZzPvCOL5z2rnM/9J4vnv6+L33k/ed97LQvf/xDXznj9K9+6iNf /fTHzv/sJy74
3CcvPOvTF33+s1/7wue+fu7Z3/jSOd8879xvfeVL3zr/vG9f8JXvXHT+d79+ 4fe+8bXvf+sb
y7/9rR989zs//P73frR8+Y9++IOLL/5R63P6n/+R0fjx//w4z09a+UmaH//k p3P5qczPOvKz
FTI/mcvPf7JCz2yan6f56c9/MZdZmUs68otfyvxsLpf+7BI9v0rzyzQr0lzW yqUyv+7Iry6X
+flcfpPmsjz/28qv/3c2zRVz6e3Xlf7F6ghCGp3qjnBdjy4lXx1H4IgIHSH/ nbt+SYsckd3K
0qfPgtSSrhzRY3AEjsARoIMjRj8j5YjEAY7AEThiZAluqxkc0YSMmiOEgdIE jsAROGI0CW6r
GRzRhIy+I3JTDMYRanc4AkeEpboj5I/D0V7MVUaT4LaawRFNyCg7Qp9Vo4nB jCNwBI4ITleO
MAtzcAQZkYysI/KLEXpJqSOERu6IvCR3hJxWjtDr6+MISe4IvY5yRD6LI8be EUcdfZT8h+cv
0dOVI4SDi2+4AUeQEUmAI0rHyBLrvqo7Qk3or6KCI2QdfRwhZ6Uj5Gs+jpDT 0hHyVY0j5EQ+
jhCZI+Rrfj1CTktHyNd8HCEyR8jXfBwhp3HE2I8jdCn4BTHbf0cknX9CyFyq KFQolPtrlq5b
oNACqnKVwhkc0YSEOUL+G1Y56aST8uk8vTtCkfTmCDWOEKGOUOMIgSM419RW Q6kgZrt3xLJl
yZlnHp3n4ovPFKGOMBfpr2a5taQw4dldjtkISYZrNs8MjmhCwhyRd+PSEaKT BjnCPNckDEeY
55oEjojyekQVQcz2eRyh99tV+nCzjlmzUKcwYa5rYm2HJGPWLYhZHNGQjKwj kjZ6Se2OKD3X
pF+zFjiCccRQxxF6v2324Ukn1jr6dvTpvKQwYW7TxNUU+VquCjM4ogkJc8RJ GqKTWhyRdI4g
8sIAR5jXrNV0YRxRuPdV2K5Z5/c15SVcs+Z6RCH9G0ckRsdemDYL9Vez3FpS mHDtVMfVFEkb
V4UZHNGE9DKOUNcjTHpxxKmnnipqumbtuvdV2MYRPEOHI6zp931N1ccRru66 MK0oLCqUW2vm
s/6aJtZ2UKvMcq6p+Rmdc03SDknbEaKOc00iu6+pR0eI7Jq1OgAcEfP1iIoZ 4jjCxLOoRsxG
KHjBpYkZHNGE9MMRrg+9dByRC0KRdHmuyfV8RI/fxaG2ll+PwBE4wpPgcYQa QSzTbizXK/t7
e9fSoTjCagRr4QyOaEJqd8SyNq4V9V2LznFEgcSA72vCEeM9jpCFZ94g/IMI k5FyRPXM4Igm
JMARR7uZmfvtaJn5j6fKOOKYw+4pX/lucBwRgyOkDkxHmIIYcYLbagZHNCFh jshFoDjzzDMv
vvjifFY4RhN+R6SCOPQe8vXVh99bvuIIHDH2jrBi1hxxgttqBkc0IXWNI6Qm lhlj564cwd8Y
whF8N3gTCW6rGRzRhAQ4wpX8F6GwcQSOwBE4ookEt9UMjmhCanTEbPah544w //HgCByBI0AH
R4x+6nXErDaasC4yHQEwTqgfqMKPWPlqsYIgRj/mP+keHeGJ6QhCxi+Ff/b9 3h0h/Y7Zkw/G
EYQQQhoXHEEIIcQVHEEIIcQVqyOc15wAACAOPI5YBgAAceNxBCGEEDKLIwgh hLjjcURhxEEI
ISS2eByhZl2OWNEm/3MPK7xYN1L+9H6b5cuXzzi+K6Z03QLWjcxqf5C3gKu+ 60jkm/UfQI51
I/5mNOnfRmpJ+b47qbgR/7+6Go+fkMjToyP0H1Kzd9UrWDdS3o22GYwjzCv7 XWnC7Kz8DGUj
hQ/Is5FaYt2v9Rg8R1Koo1ZUf5dqhY0aj5+QyNOLI8yf0EJJomnCupEZ7W+s l+Lq3kuUYGDd
yKzDEbkpXGvpkW+zfPcarsPoCteRmKj6j89IsjebL/K8qa726zmSxK1g/SBL 345axfq3C/0b
IYQEJNgRieNXuMSG68d2JnOE2XWYJAN3hD6r3oVrxTzybZbvXsN1GNaGteI6 KrNa0rZD3rsq
U6gKnjelf45muWfFwpFYP2hZKEeISVn3Xngv+t+31cv9GyGEBKQXR5g/8i5c nclMHY5IusG1
kcI7yuvrJa4Vw44kcWwwaQ++SllRzRGqcm4H/R2p1yqdqtpIlULXkeS7c+Hp 3gtvB0cQMrD0
4ogTKuPqSepyRPn6GZ6N6NtJ2r1Z/ioqO8K1axPXBpN2559X01fRp1eUOUL1 vaYdJLIwf634
1sxq1kLrkazwOiJ/O67ufYVGgiMIGWBGwREVGZgj8spC65aTah3pTPaHVPJO TDj+3Ixng0m7
88+7Qb1LLHSPno3knNpphwMPPFCpQR2Dmq7y1sx9WQsL0ftwgSMIaVpwhGs7 ybAdUcqKMkfk
x5C/haT9dvLL1kmmiSpvrbCv/DD8K+p9eH4MBUQPjshXTHAEIX0IjrBuJ9+p XuJaMeBIRJ/P
NSXa8CFpX57OZwvHWfGtmZSuNWs44lQb+dtxde8rNBLGEYQMMOPhiOpUcUTS OYLoqiO1doP6
RnRcG9F7wqSzS9SnV1RwRKKO6dIz9iYvUTvV31R+0qn0rc0aQwnPW9Cj9+HW xjkVRxAywhnB
a9aq81m+fHmhcADjiLy/KryKYTiilBVuR8hF97nPfVo7FXOOyI9E3QebT5e+ tVn36Sb/Wnof
Lve13IbAEYSManCEyqnt39Lzmgp9XeuKYUci+nyuSXWVBx10kDDey5Oe9CR1 p5Nom6Jip6o2
4i9xHckKHEFIM4Mj8ui/8IvQc01d4dqI3hMmnV1ioXt0bUTvOfV3kdtBTXfV qZrH7HkXpUdS
IOneEWrvenk+XfpeCCEVwzVrlVMNzAOwrlh4O13hejsr6jjXlJO/96TdUPnw oUqn6j2E8jbJ
d5HU6gi190J5Pl16VISQiunFEV1h3Uh5N9pmufs7/cr3reHayGymifw1LCXv wcC6kaSz6/OT
VHBE0nmGyrr9sPdbJfph+PEciX6ohfp6eT5d4/ETEnl6+U6/8vGDhnUj5d1o G48jStfN8WxE
F0SwJkoPoIB1I84+1IF1I2b/qVjhIOz9Volrjy5KN+JpCv9GCCEB8TtC4nIE IYSQsY/HEYQQ
QiIPjiCEEOKK1RECAADixuOIZQAAEDceRxBCCCGzOIIQQog7OIIQQogrOIIQ Qogr/XBEUu2v
z4xI9Ad1+70vQghpVnCEHjRBCCF6KjrC7DxViV5u/kKeT1srF7YW8Ju8uUdz U+ZOzUXmdvLp
wiqunfoP0lpi3WmhQpXtE0JI/1KXIwq9aGGR2elVmfanUNO1C/+BlVYofZul KW06636rb58Q
QvqX6ueakk7ywsLErK2L8/eBAR2vq2Yvh1F9Fc8BWJN04tqU58AIIWQo6coR 5nSVHs8sqavj
9Rd2exjVS3LMA7DG+ga7OjBCCBlKBu+IKjWrxFrTunFX31v9eEr35Y+/6cy9 eHZKCCGDTFf3
NVm7UL1nyzGruVYvrOs/APNgrOWFo8oL9QrWvRfKPavrdarEuuXCpgoHELAX QgipNz06YogJ
PoyhHL/VEf3YESGE1Jhun48YnZ6tcCTVD2xYbyH4gAkhZFgZpCNq7xUTjW5X nB14L13dEeiD
EDIi4fuaCCGEuIIjCCGEuIIjCCGEuIIjCCGEuIIjCCGEuGJ1xMsfsF9P+fPF WZa84oEq+7/i
QTIHvFLmYJkD0xzye69SOfQeaf7i949Jc89jDlO516sPl7l3mgfL/L/XyDzk D1p56B/KvPaI
P8ryx699WJpjH/Ynx/6lzH3SPPw+r3v4fdP81Z+qHPeI/5/myIOy3O/4R6r8 2fGPkrn/62X+
WuYBaR795yeoPOaBaf7mQTJvkHnswVkOecNRh7zxqEPTLJX5C5k3Pe6wVh5/ uMybH//gNz8h
yxMfInPiEx964pNkjkjz5CPe8uSHpfnbv2zlKQ9/a5q/euvfZfn7R5yU5siT nirzSJllT5N5
VJp/+GuZt8k8/dFZHvO2f3zMyTLP+Jssjz35mY99e5qj3v5PMktlTvnnx7Xy rMdnecI7/iXL
s5+Y5Unv/FeVJ7/zOTJ/+y6Z5z6llX/7u3en+ft3P0/lqe/5d5mnvef5Kv/w 3v+QeXqao/9R
5n0yL3hGlme+74VpTn3hP536Ipl/PvXFad7/4me9/z9l/iXNS579AZX/+tcs zzntpSrPPe1l
Mv/2wf9Wed4HXy7z7x+SeYXM89O88j9kPvzKoz/8KpUXfPiYF5x+zAtPf7XK i05/zYs+8poX
p3mtzH/KfPTYl2T5r4++Ls3HXvfSjx0n87I0x7/s48f/98dfL/PyNCe8/BMn vCLNG16Z5VWf
eOOrzkhzzBlvknm1zCffLPOaT54o81qZT71F5tg0b32dzKdlTjouy/GfXnb8 Z5a9Ps3bZE74
zMknfPbkN6R5u8wb05zypjNV3vHmLCd+7p0yb0nzLpm3nvVumZPSvEdm2dky 731bK+87+fNp
3v75U2VOkTnn/TLvSPOBd8p84TSZd6X54LtVzv3Qe7K899wPy7zvizKny5ya 5iPv/5LMR2U+
kOZjp52n8vEPZvnQlz+h8uEvnyFz+ldkPvmRNJ+S+ehXZT79sVY+83GZ8z/z ifM/q3LG+Wee
ccGZn0zzuU+lOetTF5716TRnf0blos9/NsuZF52T5mvnfO5rX5A5K825Z39d 5YufT/Olc2S+
IXPeF7Kc+40vn/vNNF/85ldkviTzra/KnJfm/C/LfPuCr7Ry4VdlvnPh+d+5 SOWC73ztgu9+
7cI0X5e5SOZ73/hamm9+vZVvfeP7ab75/W+rfGv5d2S+nea7Mt/5gcz3vpvm +9+T+aHM8u9n
Wf7DHyz/UZof/OiHMj+UufhHMj9KkzEz8pQ6QuzbJ0v27hBil/y/2LdXvtwp hJzfl2W9EBtE
xp49aXAEjsAROAJHxOOIqcnJiSSZSg6YTg6cSCanJqcXTScyCyaShZMT+y1J DrxHIstlpqcP
2L0bR+AIHIEjcER3jpDdb18TtpeKjpickP3/xMSiZGpxMj+ZWDgxlSQHJMn+ k8kBE8n+SXJQ
ktxv3vQ8Wef3JxI52AhzhBqJ4IhRcIT6LHAEjsARA3OE/IlbVhnZV3dbP2wv FR0hZ5Uj5u2f
iL3p6aU9d4u9u4S4W4idYssdYvP27ETT7j1i786+OkLVwRGj5ghVH0fgCBzR iyNk31v92nG3
9cP2UtURe3ZLMcyfkKOGRdPT8/fuFbdsFUc8+oSpZPd+U2Jqetfk1N1Tk2Lh ApFdsdiVm8WK
ckShMHdETu6IQrk+jigsUo7QS3JHqFnlCL1Ct45QaylHqOmCI/SNK0e0pjNH 6EtzR+iFyhFq
WjqiNfHUR6oJ5Qi9fkVHCAfKEYXC3BE5VkcU6ujjiMIi5Qi9JHeEmlWO0Cvg CBwRsyMSA7P3
zuublQtrDcIRe/dIR+y6U0wnSyYnp5Nkcs2tqSaWzBOLJkUysWPRfkI6Ikl2 Z47YqTvCOo5Q
i9Q4Qk0XxhFqWjpCTahxhGijC0KOI/LyXBBqHKGmdUHIqGk1jlDTNTpClahx hJrWHaEm1DhC
TUtHtCaycYSa9juiNZGNI9R0dUdYxxFqkRpHtKY7xxFquuAIVajGEaKNcoSa luOIvFw6ojWR
jSPUdIcgXvLs1nQ2jlDTOAJH4IhCb+9yhLWTL3WEuWWXWUodsfIacb/7n3fz LUImPemUTOy/
IBHitru3iKc85rglC29bvODW6WTfgkkhdqfJzzWpH/ZaHCE0Co547RF/pKa7 dUS355qEA6sj
8nNNqrDgiPxckyoMc0RX55rUirU7QmgUHPG+FzxTTXfrCM414QjONXlSlyMK UigooytHXLlS
POiQCx/y0A/cdHP6gzw9NX3AwmTJ/GTXViEjBbH/om3zJ8TCKTnYSKNfj1A/ ++b1CNFJlXFE
4XpEazrIEToFR+TlwY7Q6ZMjdAqOyMvN6xGq3LweUdhgt+OIwvUINR3mCB0c gSNwhDU1OmLW
/aXZXTni+mvF4Yd+8YB522TWbhPrbhdJejvT4kXJfLFHXHuDeNiRH50/uXfe xB4hdu4VdxWu
Wasfedc1a7V0wI4IONekKqtr1q3p7Jq1mh7xc035NWu1iuuatVo6REdwrglH 4IjS1OuIWdtJ
p9kuHbF6lTj0Qef83oLt91h4x6OeeOz67WLPLjGZHLgwmbc4WXjDLeKa68XC 6TS79m3Pr0fo
9zWpn3rXOEK/rylHXbNW09UdYb1mnc/2cs1a1fc7ot5r1gXy+5r0woD7mtSK rnGEfl9TjnnN
WpVXd4T1mnU+yzVrHIEjRJPHEauvF4cdfvbiiR1LJncunCcHEXtu3SK2bBJL koWL0wfpEll/
7WZxxJEnpj/e++zP0Kmf/W6foVNr9Xjvq1qrx3tf1UZKHWHe+6oqjNS9r+qQ enmGTm2hx3tf
1Vrc+4ojcMSwHKGroaCJrhxx3WpxyKFnSkHcaz8piF0LpsXSx75ZOkLsEgdO LFZPYd+8IdWE
wuoITRPNc4Taguv5CLW0QY445VlPUEeFI3AEjhgDR7jwO6IghUJJV47YslE8 +pEn3fePLz7o
vj8++P4XPfB+Fxx+yNmHHXxW9hDdrvlLkgX7J/PnzU+/uml3+lSdflOTSbff xVFYfSjPWatd
N9cRwkEv38VR2BTPWeMIHNEsR1TZS3VHbN4gfnNZmlVXimuvEtddLW64Tqgn 5oS4RTpianJq
IpmQghB8XxPf14QjcASOCHJEleiOqF4/bC8VHZEkE1NT00sWJDKLpqYWTExk X+63JEnmyyxI
7jmVHLhoMtlvKkk14T7XhCNwBI7AETjC5YjqKEdUR3dEdao7Qs5m3w6+Nc2e PenK2QDiLpEm
/Y5wOXzYmw0hhPOaNY7AETgCR+CIsfxu8PDgCByBI3AEjhhfRxBCCCGzOIIQ Qog7BUcAAADk
6I4ghBBCClGO+D9QSwECFAAUAAAACABPXLcu8fOQD847AAAuFQsABwAAAAAA AAAAACAAtoEA
AAAAemFwLmJtcFBLBQYAAAAAAQABADUAAADzOwAAAAA=
--------------E43FC1BF7AEA8916FBFA7557--
| Re: An eclipse platform cut down a lot? [message #48482 is a reply to message #45306] |
Mon, 26 May 2003 12:44  |
Originally posted by: simon.ibm.oti.lab
We are working on Eclipse as a "rich client platform". That includes doing
some of the things you talk about below (removing the resource perspective,
workbench actions, etc). All without having to hack the eclipse code. Add
yourself to the CC list of bug report 36967. You can also monitor the
eclipse ui dev mailing list.
Simon :-)
"Lachezar Dobrev" <l.dobrev@efficient-soft.com> wrote in message
news:bal49g$h2k$1@rogue.oti.com...
> Hello group.
> earlier.
> application bundle.
my
> oproject.
> that.
and
> so on.
> simple though).
> required plugins.
should
> I remove.
> Lachezar
FUDForum. Page generated in 0.04625 seconds
